Question about Nintendo Wii Console
We get an error code 51030 when we are trying to update netflix instant disc- asking for internet connection---we have wireless internet with cablevision
    Genius:
  • 1,234 Answers
Error Code: 51030The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
  • If you are getting this error after completing a system update, this is usually because the console resets to using the first connection slot after an update. There are two things you can do:
    • If you know which connection file you were using before, you can select that connection file, then select "Use this connection" to change that to the default. You will need to do this each time they download an update.
    • If you don't know which connection file you are using, or if you would prefer not to update the active connection file each time, try to clear, and then re-create your connection setting in slot one before doing the remaining troubleshooting.
  • Check to see if the router you are using is a known to be incompatible. Click here to view our list. If your router is known to be incompatible, we recommend using a different router if possible.
  • Make sure that the SSID (network name) matches exactly to what you have entered in the Wii console's settings. To verify:
    1. Login to your router's settings (click here and select your router, if available, for information).
    2. Look for the section for SSID (typically in the "wireless settings" area).
    3. After you find the SSID (network name), verify in the manual settings of the Wii console that the SSID appears exactly as listed in the consumer's router. This includes making sure capitalization, spaces, or special characters match exactly.
  • Look up your router, if available, in our list of wireless routers, and check for any special notes that may be necesary to get the connection to work properly.
  • The router may not be assigning an IP address to the Wii console, and a connection using the "Manual Settings" may be necessary. Click here for help.
  • Your router may require a firmware update to work properly with the Wii console. Firmware updates can usually be found on the router manufactruer's website; consult the manufacturer for more information.
Posted on Aug 27, 2010
How do I get Netflix on my TV. I already have an account with Netflix.?
Assuming you are trying to connect to netflix using the WII. That error code means the WII is not compatible with your wireless network. You should test your wifi connection to make sure it is working.
Dec 29, 2014 | Computers & Internet
Netflix connection error code 51030
if this is on a wii that error code means no internet connection check your wireless settings
Sep 09, 2011 | Computers & Internet
I just signed up for netflix and am trying to hook it up to my wii to watch movies. The wii is properly connected and hooked up, and we have a wireless internet connection in my home, however when i go to...
Error code 51030 means you Wii is unable to connect to your wireless network.
Try unplugging your modem and wireless router, then plugging them back in after a couple minutes.
While you're waiting for your modem and router, delete your network setting from your Wii, and set them back up once your router and modem are back up.
Your wireless router's setting might have changed and your Wii might not be able to properly connect.
May 08, 2011 | Nintendo Wii Console
Up until about a week ago, our wii was connecting to the internet with no problems. No when we try to connect it gives us and error code or asking if we would like to set up internet connection. I have...
Your error code indicates that your Wii can't connect via wireless to your router. I would check to make sure your router is functioning properly and to restart it if required. I would then check to make sure that the configuration on your Wii matches that of your router. I would also check to see if any other devices can connect to your router, if so, then the wireless card on your Wii may have died and is something you will likely need serviced by Nintendo.
Apr 01, 2011 | Nintendo Wii Console
What does a 51030 error code mean on netfilx
Error Code: 51030 The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
Feb 28, 2011 | Netflix
Trying to hook up to are nintendo so we can get movies from netflix, ran at test got error code 51030 please let me know what to do if anything. thanks
The error code 51030 means that you have and internet connection error. Possibly caused by being too far from the wireless source, or your wireless settings on your Wii need to be adjusted. Here is a link to Nintendo's Customer Support to show you the steps to set up, or reset your wireless connection.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Oct 28, 2010 | Nintendo Wii Console
How do I connect the WII to wireless internet. It is giving me an error code 51030. I am trying to connect to Netflix
Go to wii options, located in the lower left corner.*
Then go to Wii Settings. On the second page, somewhere it should say Internet. If Parental Controls, enter you PIN and continue. Then look for a wireless connection.
Sep 01, 2010 | Nintendo Wii Console
Making connection between WII and internet and Netflix
Sounds like a netflix issue.Contact them with any information you have from them.Here is the link.
http://www.netflix.com/HowItWorks
Jul 12, 2010 | Nintendo Wii Console
How do I connect to the internet to use the netflix disc on my wei error code 51030
Go to Wii Options in the lower left.
Click on Wii Settings to the right.
From this first list, click the right arrow.
Now on page 2, click on Internet.
Then click Connection Settings.
From this list, click Connection 1.
Then, click Wireless Connection...
and then click Search for an Access Point.
It will briefly search for any access points and when this screen comes up, click OK.
The following will be a list of nearby access points. If the one you are looking for doesn't show up, click Try again.
Then, click the one you have access to...
click OK once you've selected your connection, it might ask for a security key if you have one set up.
it should test the connection.
If this is the first time you've connected your Wii, it will most likely update your system
Apr 15, 2010 | Nintendo Wii Console
Cant connect my wii get error 51030
This might be handy: http://www.nhotspot.net/wii-error-code-51030/ and http://www.wiierror.com/wii-error-51000.php
Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed.
Verify that the proper Connection File (1, 2, or 3) is selected in the Wii System Settings.
If you have multiple connection files setup, and you have recently received a system update, it is possible that the update has caused the Wii console to select a different Connection File. Click here for step-by-step instructions on viewing your connection settings.
Make sure that your network's name (SSID) matches exactly to what you have entered in the Wii console's settings.
Log in to your router using the default IP (consult the router's owner's manual for assistance).
After you find the SSID (network name), verify in the Internet Settings of your Wii console that the SSID is appearing exactly as listed in your router. This includes making sure capitalization, spaces, or special characters match exactly.
Oct 19, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
35 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
