Question about Samsung BN5900696A Remote Control
My TV is a Samsung 40" flatscreen. The sound is working fine, but the picture is now nothing but multi-colored diagonal lines, and is confined to the top left quadrant of the screen (the rest of the screen is black). Did I press a button and not realize what I did?
  • Samsung Master
  • 11,800 Answers
No, there's a defect on it. And the only defect that looks like that is a bad synchronisation circuit in CRT projection tv's on an activated PIP screen. Knowing the exact model of your tv will help.
First of all you should try to exit the PIP - there's a button on the remote for that. If the broken image doesn't spread to the entire screen then the defect is probably in the control processor.
Next you should check that the tv behaves the same whatever the source of the signal. If it does then the defect is in the mainboard, and to fix that a repairman is mandatory, there's nothing more you can do.
Posted on Aug 25, 2010
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Samsung flatscreen tv model LN46C600F3FXZX has sound but no picture
Video section has become compromised and no longer functional. Audio being separate from the Video may work perfectly, but the Video portion sustained damage to the circuit board or the inline safety diode blew. If any parts of the Circuit Board fail, you need to replace the mainboard. The cost to generally fix a circuit board is usually more than the replacement cost for a new unit. Check all fuses or circuit limiters inside the TV and if there are no shorts, burned parts, or obvious smells on the mainboard, transient current may have trickled in and damaged sensitive electronics. Have a professional Technician do tests to locate the source of the problem.
Dec 25, 2013 | Samsung Televison & Video
I have no color on my Samsung Flatscreen TV
This means absolutely no color - equivalent to a black and white picture. Not even a hint of color.
First, confirm that the source is actually in color - try another channel or input device.
Next, check the settings of the color control - it may have accidentally been turned down. If your TV has some kind of automatic picture mode, try turning if off and adjusting the color control. Try adjusting fine tuning if you have such a control and the problem is with a broadcast or cable transmission.
At this point with a confirmed color signal source, there is a problem with the chroma circuitry.
Note that to the average person, the obvious question becomes: is my color picture tube bad? The answer is a definitive NO. It is virtually impossible for a defective CRT to cause a total loss of color. A defective CRT can cause a lack of a primary color - R, G, or, B or a short between two colors which will mess up the color but is not likely to result in a black and white picture.
Some possibilities in no particular order:
Weak signal or defect in tuner/IF causing loss of signal strength.
Coler killer set too high (internal control) if it has one.
Defective part around the chroma chip/circuit. Faulty color oscillator.
Bad connections in area of chroma chip/circuit.
Defective chroma chip (don't suspect this first just because it is probably very expensive).
Try prodding the main board around the chroma chip with an insulated tool to see if you can make the color come and go.
I had one set where a $.02 resistor decided to open up causing just this problem - perfect BW picture, no color. Another had a coil with a broken wire.
Jun 14, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Screen has color. but no picture. only moving multi colored vertical lines. tv does have sound, but no picture.
Unscrew the cable off the cable box on the out to TV end, then screw it back on. You may also try a different type of cable, like HDMI or component cable.
Dec 27, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Boys wrestling in the living room and knocked my 32'' Samsung LCD LNS3241D from the tv stand, fell flat to the floor and now there is no picture, just different color lines on the screen,no sound, nothing...
It can be fixed by only by replacing whole LCD Panel. It is expensive (usually about 500-700 for a 32"). You have to take the whole TV apart to replace the part. It will not be covered by any warranty because it is physical damage and very easy to tell just by visual inspection.
Oct 05, 2009 | Televison & Video
The picture on my tv (mit. 1080) is made up of
Convergence ICs Two of them STK392-570 ,they are big black ICs,Replace with same Number on ICs.You can order them at MATS 1-800-628-1118.
Aug 07, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Colored vertical lines with sound no picture
im afraid to say that your display has gone the best thing you can do is call the supplyer of the tv if its under warranty or call samsung. the cost of a new display will be 400 - 500 pounds so you may have to buy a new set.
Mar 10, 2009 | Samsung LN-S4092D 40 in. LCD HDTV
Samsung BN5900696A Remote Control Logo
55 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
