Question about Peg Perego John Deere Turf Tractor
Only one rear tire is powered and the tractor won't run in the grass when a child gets on. I tried holding the spinning tire but the tire not working did not engage. How can I get power to both back tires?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Bad motor, you can order a new one here www.powerwheelsoutlet.com
Posted on Jun 06, 2012
2 Suggested Answers
  • 156 Answers
SOURCE: tractor won't go in low gear or reverse
I had the same problem and replaced the shifter which I found at
http://www.mypegperegoparts.com/switches.html.
This fixed all the speeds and now it runs great.
Hope this helps
Posted on Jun 08, 2010
Mower deck adjustment ride on mower MTD 13538 cutting deck a lot lower than rear of the deck shaving the grass to dirt.
Are all the rods that hold the deck on all the same length. Has any been replaced with the wrong ones. Did this machine hit something that things were bent an out of shape.
Are your tires blown up where they should be? Soft tires will do that.
Dec 07, 2016 | Mtd Garden
RELEASE SWITCH ON REAR OF RIDING TRACTOR.
Double check the drive axle keyway and make sure key is still in there. Without it the drive axle just spins without driving either wheel.
Also if hydro static make sure the neutral lever is re-engaged. Operators sometimes put these in neutral and then forget to put them back when they to use the mower.
Nov 10, 2014 | Garden
Have a craftsman DYS4500 with a front mount snowblower only one rear wheel on right side will turn on ice with chains on both rear wheels you cant move machine just spins on right
yes this is correct that is called a " differential" it allows you to turn in circles without one wheel dragging in grass, larger 4wd drive tractors have what is called a "diff Lock" that can be engauged this pins both tires on same axle together and keeps them both turning in low traction surfaces,
im unaware of any craftsman that is made with a "diff LOck"
Dec 05, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Hydro-tranmission want engage
i have seen many times when the wheel was removed you lost the square key that locks the wheel to the axle and is covered by the clip that holds the wheel on the axle
Sep 01, 2012 | John Deere Garden
I need to check the motor wire. I cant get to the darn thing. HELP!
take the seat off by removing the two screws from the bottom of the rear of the tractor, then you should be able to see the motors
Mar 21, 2012 | Peg Perego John Deere Turf Tractor
Gator lacks power when running in our front yard grass.
sounds to me like you have a bad motor, yes both wheels should turn
Dec 30, 2011 | Peg Perego John Deere Gator HPX Ride on...
Gears won't engage
when you removed the tires is the tires bolted on or do they have a clip around the axle if it has a clip around the axle then there should be a long sqare key that sits in axle as well as the wheel that key keeps the axle from just spinning in rim if that key is missing then replace it & you should be ready to go
Jun 26, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Rear wheel removal from craftman riding mower
Do you have the rim and tire off and you want to remove the hub?
I believe every rider mower and tractor I've had and worked on had the rear tire attached to the hub as in a car, with lug nuts or lug bolts. Check to see if there are four or five lug bolts that hold the rim onto the hub.
Jul 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Peg Perego John Deere Turf Tractor Logo
85 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
