Question about Danby DCR412SS Stainless Steel Compact Refrigerator
I was chiping ice from my danby fridge freezer section, and chipped a notch out if the freexer, and now its leaking something that smeels bad, and the fridge now does not get cold and the freezer doesnt work?
  • 4,793 Answers
Guess who is going to buy a new unit....NEVER USE ANY HARD/SHARP OBJECT TO AID A QUICK DEFROST.use only car deicer,then wash out with clorine bleach then dry thoroughly.
the cost of repair/recharge/callout, is going to be nearly the cost of new.
Posted on Aug 25, 2010
My danby refrigerator model # DFF092C1BSLDB stopped cooling, the freezer is still working fine. This is brand new
Cold freezer air is not properly being diverted to refrigerator section. Check out damper and controls for same.
Sep 02, 2017 | Danby Refrigerators
Freezer gets cold but refrigerator does not
blocked air flow from freezer to fridge. Could be ice build up. May have a faulty auto defroster. Freexer is only part that gets cold. The fridge gets it cooling from the freezer.
Aug 02, 2014 | Whirlpool 21.0 cu. ft. Top Freezer...
The freezer section of our Danby DFF8200W freezes well. However, periodically the refrigerator section freezes everything in it with the temp control turned as low as it will turn for me. The dial does not...
Make sure you clean the backside of refrigerator at bottom from dust. Make sure you have the recommended clearance from wall. Also make sure the food in freezer and frige have clearance to allow air to circulate around food. Keep playing with your controlls...The dails might be on wrong
Aug 11, 2013 | Danby Refrigerators
My whirlpool fridge makes a loud humming noise when the door is closed. It is not freezing items in the freexer and is not cooling items in the fridge section. The freezer is above the fridge section in...
The fan is hitting ice build up...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 11, 2010 | Whirlpool Refrigerators
Water is leaking into fridge, ice maker making hollow ice
Make sure when the icemaker fills its not causing the leak ...... other than that you have a clogged drain in the freezer section .... easiest way remove everything unplug for 24 hrs with door open .... manual defrost ....hehehe ..... plug back in u should be ok if reoccurs call for service
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Chiping ice out of freezer section with chisle and entered a "cavity" under freezer shelf...seemed like freon gas came out of it. Is the refriderator toast? It is a Magic Chef mini-freezer.
Sound like you punctured one of the molded channels in the freezer shelf that carries the refrigerant.  Probably can't be fixed.  Possibly could be replaced.  Consult a service technician if the fridge is new enough to keep.  If it does not have an auto-defrost or frost-free function it is probably too old to be worth repairing.
May 19, 2009 | Refrigerators
GE Fridge with ice maker. Water is slowly leaking
drain is clogh at the bottom of the freezer
Mar 29, 2009 | Refrigerators
Fridge getting warm, defost not properly working...
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Danby Designer DAR1102W Refrigerator
Danby DCR412SS Stainless Steel Compact Refrigerator Logo
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
