Question about Garden
I have a Simplicity Zero-Turn 20 hp 50" cut. Just recently when mowing I have "clumps" of grass all over the yard. Any idea what would cause this? Also, the mower is supposed to stipe the lawn - I have never got this to work - any ideas?
  • 12,061 Answers
Hi, well you have the cutter too close to the ground, try raising it up a couple of notches.
Now as for the "clumps" on the lawn. Well IF you mean GROWING clumps, that's because the mower is dumping the cut grass in a pile, somewhat, and that's adding nutrients to that particular Patch, and it simply grows faster because it's got more "Food".
If you mean, CUT grass patches, then again your Cutter is Too Close to the ground, and it's dragging the cut grass, and then when it gets too much, it is "packeting" the cut grass, every now an again when it builds up and is left in "piles" instead of being evenly distributed, and driven into the ground, behind the mower.
Posted on Aug 25, 2010
It ran mowed a hard lawn of grass now it wont start to moe soft blade grass
while unplugged try turning the blade by hand . it should turn easily . then check to see if grass or string has gotten wound around the shaft.
Oct 17, 2015 | Greenworks 20" 12 Amp 3-in-1 Electric...
Tip
What's the hurry
What's this marketing ploy now days about cutting your lawn mowing time in half. I can understand that if u have a bunch of lawns to mow. Beings i only have one, I'm really not a big hurry. Take a look at your yard, do some thinking, and don't over spend. I only want to have to sharpen 2 blades not 3 or 4, and the less drive belts the better. U get your exercise with a walk behind, and get the grass cut too. Last time I was mower shopping, one salesman tried to sell me a 6,900.00 lawn mower. He said it would cut my mowing time in half. I said I'm not buying a mowing that's worth more than my pickup, and for 6,900.00 I could pay someone to mow my yard, and cut my mowing time down to zero.
ballping
on Jul 29, 2010 | Garden
Why does it bog down in grass maybe 6 " high?
The likely cause of this is that the grass is too high for your mowers deck. You should try just mowing about 1/3 of the blade at a time (if you can) until you reach your desired length, so if you grass is 6" high, only take off about 2" at first to reduce the stress on your mower. Set your mower deck to it's highest setting and give it a shot.
Also, be sure that the blades are sharp, and if you don't have mulching blades, you should get some! Grass this high will leave long clippings on the lawn which can suffocate the grass, mulching blades will chop up the clippings into smaller pieces, which is beneficial for your lawn!
Finally, make sure you aren't mowing wet grass. If you mow when the grass is wet the clippings can stick together and clump up under the mowing deck which will cause excess strain to the mower and maybe even cause it to shut off.
If none of this works, you may want to use a string trimmer to remove the first two inches of your grass and then continue mowing as normal!
Hope this helps! Happy Mowing!
Aug 03, 2015 | Garden
Craftsman GT6000 54" stalls while mowing
Sounds like you have dulled the blades with your aggressive hill cutting
Aug 12, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
During mowing grass will gather underside of deck leaving 2 streaks on r and l if you turn deck off grass will fall out of deck before restarting u need tgo move or mower will stall from grass build up...
There are a couple of things going on here. First, the blades are likely worn out and need replaced. As they wear and loose some length they can leave a trail. Second, if you have regular blades on a deck configured (by having discharge plugged) for mulching and you are using regular blades, then you can have a problem with build up. Third, you can have clumping problems if the grass is not dry when you are mowing.
I hope this is helpful for you.
Aug 24, 2011 | Ariens 48" Riding Lawn Mower Blade ...
Lawn mower wont pick up the clippings
if you have ever mowed your lawn when it was wet, you might have formed a clog in the pipes to the clipping catcher. Make sure that the mower is OFF (so you don't chop off your hands) and take a look at the bottom of the mower -- if there is a lot of grass stuck there, you probably have a clog. Clean out the grass from the bottom of the mower, and remove the bag. Make sure that the opening from the base of the lawnmower to the bag is totally clear and give it another shot.
If it is not this, are the clippings just clumping up on the ground as you mow the lawn? or are they being thrown around the yard like they have no direction as to where to go?
If the connection between the mower and the bag are clear, and the grass is just clumping as you cut it, there might be some sort of blockage that you did not notice, keeping the clippings from going where they are supposed to. Make sure you have your bag hooked up properly, and that the clippings have a clear path to the bag. If there is still no love on it, you will probably have to see a repair professional so they can give it a good look (it's tough to resolve complex issues over the internet).
If the grass is not clumping when cut, but is being tossed in all directions instead of being directed to the bag, then you will have to take it in for service -- this would seem to indicate that the mower blades have somehow become distorted and the air flow that you need (to direct the clippings) is not being directed properly. A professional repair person would have to have a chance to see the mower in action to find out what is wrong (once again, it's difficult to fix something you can't see). Good luck ... hopefully it's just a clog (it happens to me all the time).
May 29, 2011 | Toro Power Lawn Mower
The mower is mowing uneven in the front. what can i do? it seems that it is scalping the grass but both sides are level
Look under the mower deck. If you can't see well and work on it, you may have to remove the mower deck and flip it over on the ground. Grass and mud buildup in the decj could cause a blade to pinch grass, 'scalping' the lawn. Clean it all out. Dull blades cause cut grass to look torn and brown. Remove and sharpen. Bent blade will cause uneven cut. Replace it. Good luck! Please rate if you found this helpful, thanks!
Jun 05, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Garden Logo
179 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
