My Philips model #27pt543s37a is dead I'm getting a humming sound from the rear what so I have to replace
    President:
  • 2,712 Answers
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). This could have happened during the moving process. The sound comes from the flyback unit. I guess it must be a high pitched squeal, actually...
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
It may be worth getting fixed up. If you decide to do so, call around, as shops have different rates and different expertise. Many shops are hurting for work because so many of the smaller sets are never repaired anymore; they are just thrown out and replaced since the cost of a new set is sometimes as low as the repair expense.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
I have a Philips 32
model is a 27 inch and what is your issue or problem?
Mar 31, 2012 | Televison & Video
Philps model 27pt543s37a will not power on
Hello
Open the tV and check the fuse inside. There is a glass cartridge type fuse on the power supply regulator section. If found blown out, repace it with same ratings.
Feb 29, 2012 | Philips Televison & Video
I have an TV Phillips L01-1UAC-7638, the issue is, when I turn on the TV, after 15 or 20 seconds the TV turns itself off, but if I change the chanels the TV does not turn off, I mean if the TV is showing...
Hi, you don't mention the full model number, there should be a number on the back of the TV something like this 27PT543S37A, the problem you have seems to be fairly common and if this is your model number you could try this, on philips model 27pt543s37a will not power-up without changing channels for 5 minutes, transistor number 7461 is leaky between collector and base - needs to be replaced, and a capacitor rated 47 uf (microfared) at 25 volts, should be upgraded to a 47 uf at 63 volts, with a temperature rating of 105 degrees vs 85 degrees.
Hope this helps, I am assuming that you are able to use a soldering iron etc.
If you have no experience in electronics/soldering or how and where to get parts please consult a TV technician, dangerous voltages can lurk about in a tv even when not plugged in so please be careful and if at all unsure leave it to the people that know!
Feb 09, 2011 | Televison & Video
No color in DLP tv
Sounds like it is the Color Wheel !
Encompass Parts Distrubtion 1-800-638-3328
Visit Website and type in your model number.
Mar 29, 2010 | Philips 50PL9126D/37B 50" DLP TV
#27PT543S37A philips tv model-the tv video channel is not working
In short your tv has a problem on the AV connection, RF using coaxial cable is working okay.
get the tv to the w/shop, let him check the AV panel and AV processing IC.
Apr 30, 2009 | Philips Televison & Video
I HAVE RCR312W REMOTE AND NEED CODES FOR PHILIPS TV .
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0081 1149 1154 0288 0456 0003 0008 0068 0075 0086 0087 0141
Feb 12, 2009 | RCA Universal Remote Control
No menu access without remote
the channel selection buttons are supposed to pressed at the same time. the menu page will appear on your screen, use your volume for moving the pointer. entering using one of the volume button. thanks
Dec 28, 2008 | Philips 27PT543S 27" TV
Humming sound from TV
take your tv to a technian and ask him to check the power supply filter.
some of the ac ripple are passing through to the main amplifier.
a filter comsist of ( semi comductor, inductops and capacitors.
Sep 26, 2008 | Toshiba TheaterWide 62HM94 62" Rear...
Philips TV model number 27PT543S37A
TV turns on but doesn't stay on goes in and out then blank screen. LED light stays on during the entire time your problem is called hunting you can check power supply of your tv .It common problem in Philips T.V. Thanks
Sep 11, 2007 | Panasonic CT-32SX12 32" TV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
