Question about Heat Controller BHD651 Dehumidifier
I have a heat controler BDH-651-G dehumidifyer. how do i hook up a hose so it drains without stopping?
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
Dehumidifyer freon leak
You can choose to ignore the toxic Freon leak and continue running your dehumidifier until the compressor fails due to lack of Freon, but why wait
Jul 01, 2013 | Kenmore 54701 Dehumidifier
Don't see anywhere to hook up hose to the bucket? So that it will continously drain. Model HDN655E-rb
The drain plug should be on the rear of the unit about 1/2 way up the back of the unit. It has a screw off cap and rubber plug. Keep these & don't lose them. You will need them, whenever you stop using the hose drain. Most folks put them in the water bucket for safe keeping.
The garden hose can not exceed 48" in length and slope down and straight to the floor drain. Drainage relies entirely on gravity.
Hope this helps you and thanks for choosing FixYa.
Aug 27, 2011 | Haier HD656E Dehumidifier
I got a new Whirlpool dehumidifyer (AD50GEUSX) I put the hose in and the green light on "continuous" and the water will not go through the hose. The machine stops when the bucket is full. Your...
Christianeta, first let me clarify one thing. The FixYa website you posted the problem on, is not the Whirlpool website, nor the Canadian Tire website.. And we don't sell appliances of any type. But, I can help you with your problem.
Despite it being a new unit, there may be some packing material clogging the inner tubing of the the hose connection. Or the hose you're using is to long (over 48") or is kinked or is not sloping down and straight to the floor drain. It relies on gravity to drain, so it will not drain up. When any of the aforementioned happens, water is diverted into the water collection bucket.
To clear any potential packing material or a clog from the inner hose connection tubing, please do the following:
Turn the unit OFF and Unplug it and disconnect the hose.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the hose end for water flow. It may take 10 to 15 minutes for water to start flowing. So, be patient.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
I hope this helped you. Thanks for choosing FixYa.
Aug 24, 2011 | Whirlpool AD50USS Dehumidifier
Is it possible to attach a hose to drain the water continuously without my having to empty the bucket every day? If so where and how do I do that? Thank you.
The easiest way is to put a hole in the bucket( by using a a hole saw) and attach a pvc fitting(male adapter with a rubber washer and nut) and hook a hose or pvc pipe that will drain the unit of its water. Good Luck
Jul 25, 2010 | LG LHD45EL Dehumidifier
How do you hook it up to a floor drain?
With most portable dehumidifiers use a bucket to catch the condensate. Then the bucket is full the dehumidifier stops, then you need to empty it and replace the bucket to get the dehumidifier to start working again.
To make this unit run continually, the bucket can be modified so a garden hose can be attached and the hose can be feed into a floor drain. To do this look at the bottom of the bucket, there should be a hose connector where you can attach a standard garden hose. You will need to drill out the center of the hose connector with a 1/4" drill bit. Then you can attach the hose to the bucket and the other end into the floor drain.
Jul 01, 2010 | Whirlpool AD25BBK Dehumidifier
Our unit is hooked up to a hose drain had has been
proably trash in your diverter (the thing that allows water to run to tank, or hose) try a pipe cleaner or blow with air, is it electronically controlled? or is there a valve?
Apr 03, 2010 | Dehumidifiers
DeLonghi DH250R dehumidifyer - operating instructions?
http://www.delonghi.com.au/support/instruction_manuals/DH250R.pdf
Apr 05, 2009 | DeLonghi Dehumidifiers
Dehumidifiers Logo
20 people viewed this question
Top Heat Controller Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Heat Controller Dehumidifier Expert? Answer questions, earn points and help others
