Question about Amana ASD2620HRW
My amana asd2620hrw side by side refrigerator is buzzing/humming loudly. noise stops if pressure is applied to any side?
  • 4,793 Answers
The unit is out of square (not level)adjust feet to comppensate using spirit level.
Posted on Aug 25, 2010
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
Amana ASD2620HRW, buzzing and vibrating at the filter area when it cycles to fill the ice maker tray, does not fill. Water runs from under the freezer when the water button is pushed.
Pull the machine away from the wall far enough for you to move around. With a 1/4" nut driver or drill with a 1/4" adapter, remove the lower portion,(on some models all you have to take off is the left side only) this will expose the water valve. Check for broken lines, also have someoine press the water lever in the door and see if water runs out and where at exactly. With the back off you should be able to isolate the problem.
May 06, 2012 | Amana Refrigerators
Our Amana ASD2620HRW fridge is not cooling or freezing. Fan is running, lights on etc., but compressor not working. Any ideas on how to fix?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Amana ASD2620HRW
My Amana Refrigerator Freezer Model ASD2620HRW is making a buzzing noise every few minutes and now the freezer is not freezing?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Sep 26, 2010 | Amana ASD2620HRW
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
Apr 24, 2009 | Amana ASD2622HR Side by Side Refrigerator
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Apr 21, 2009 | Amana ARS2464B Side by Side Refrigerator
Buzzing noise near compressor on an Amana refer. PARB1917CSO
I can help , It was the relay , they can blow when they experience a hard start , by replacing it and having the same issue this means the compressor is locked up , they sell a booster for this that can sometimes free the compressor up , its called an rco410 , this part will be your only chance to get your compressor going again. let me know if you have any other questions and tell me how it works out.
Phil
Jan 07, 2009 | Amana ARB1917CSL Bottom Freezer...
Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Nov 08, 2008 | Frigidaire FRS26H5AS Side by Side...
Buzzing intermittent
It sounds like the ice maker. If you don't have the water hooked up, and the ice sensor bar is in the down position, the ice maker assembly will attempt to make ice continuously.
Solution is easy: raise the ice sensor bar until it clicks in the up position. It will lock in this position, and the ice maker will not cycle anymore.
May 04, 2008 | Amana ABB2227DE Bottom Freezer...
Refrigerators Logo
78 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
