Question about Hotpoint Aquarius WF000 Front Load Washer
Not freeing the water at the end of process. cleaned the filter .help
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on May 29, 2008
  • 975 Answers
CHECK THE DRAIN MOTOR PUMP , it could be clogged, look inside washer and look at a small motor with 2 hoses connected to it , take it out , clean it , replace , and start again ,hope this helps AJ
Posted on May 05, 2008
How do I clean the filter on the Novotronic W 310 Miele washing machine
Cleaning the fluff filter and pump
Check the fluff filter initially after 3 - 4 washes to ascertain how often it is likely to require cleaning. With normal cleaning approx. 2 litres of water run out.
If the drain outlet is clogged, more water will be retained in the machine (up to 25 litres).
Caution: if laundry has been washed at a high temperature,
water draining out of the machine will still be hot!
Take the (yellow) filter flap opener from behind the detergent drawer facia panel. Open the flap.
Place a dish under the drain fixture. Turn the fluff filter lid round 2 - 3
times. Do not take it right out.
With large volumes of water when the dish is full, screw the fluff filter back into position and empty the dish before repeating the procedure.
Once the flow of water ceases, remove the fluff filter completely and
clean it.
Remove any foreign bodies (e.g. buttons, coins, etc.) and fluff.
Turn the impeller by hand to check that it is free to rotate. Any foreign objects causing an obstruction should be removed.
Clean the inside of the fluff filter housing. Remove any deposits of lime scale and detergent or foreign bodies from the thread of the filter housing and filter unit (as these objects can cause a leakage
of water). Put the fluff filter back and screw it in firmly.
Cleaning and care
To clean the water inlet filters
The washing machine has two filters to protect the inlet valves. These filters should be checked every 6 months or so, or more often if there are frequent interruptions to the water supply.
To clean the filter in the union in the open end of the inlet hose:
First turn off the stopcock.
Unscrew the threaded union connecting the free end of the inlet hose to the stopcock.
Remove the rubber seal from the recess. Using pointed pliers, take hold of the plastic filter bar, remove the filter and clean.
Put the filter and seal back in the reverse order and reconnect the
hose. Turn on the stopcock and check the connection is watertight.
Inspect the inlet hose which is subjected to high pressure while the machine is in operation. The hose should be replaced if there are small cracks in the surface, or if it has been otherwise damaged.
If replacing the inlet hose only use a hose able to withstand pressure up to 70 bar. Miele's own hoses meet this requirement.
To clean the filter in the water inlet valve:
Using pliers, carefully loosen the ribbed plastic nut on the inlet valve,
and unscrew.
Use water pump pliers to withdraw the plastic filter by the bar.
Clean, put back and secure.
The two filters must be put back in place after cleaning.
Mar 08, 2015 | Miele W310 Front Load Washer
How to clean humidifier
I generally use White Distilled Vinegar. Clean your unit out the best you can with warm soapy water first and then soak or add the straight vinegar into the filter containment area and use a mild bleach solution for the water tank and soak and swish a little for 15 minutes then drain and rinse with fresh cold water and let air dry. The mineral deposits will slowly dissolve but will still take some scrubbing with a blue pan scrubbing pad or hard toothbrush. Depending on how hard your water is and if you use a water treatment additive will make a big difference in the cleaning process. Some people prefer to use distilled water in cool units as well as steam since it is almost completely mineral free and doesn't cost to much. Regular cleanings based on useage and water condition will greatly help the life and good operation of any humidifier including periodic filter changes if required.
Sep 26, 2014 | Humidifiers
Calcuim build-up in Hansgrohe 06128830 - what is best fix? (CLR Rx done)
It sounds like you have already checked the obvious places at the cartridge and the filter screen at the end of the hose. If you have good flow through the hose with out the sprayer attached I would suggest the blockadge was in the sprayer. If you look into the hand sprayer from the hose connection you will see a yellow ring with a white plastic flap in the middle. This is the first check valve as well as the flow restriction device. This little assembly can be removed [for cleaning] by pushing in on the white plastic part and hooking the yellow ring and simply pulling it straight back and out of the handsprayer. A cork screw or dental pick works well for this. Once removed you will need to hold this little assembly over something other than the sink and unsnap the grey end from the yellow housing. You will most likely find some debris in this little grey end around the spring at the flow restriction device. This is common after a water heater replacement due to the amount of debris stirred up during the flushing process. Once cleaned you will need to reassemble and reinstall the check valve assembly for proper function of the unit. If you need any further help feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'll be happy to help.
Feb 08, 2013 | Hansgrohe Plumbing
Slow flowing hansgrohe shower head
First thing to check is the filter screen at the hose connection on the hand shower. If this screen is clean and there is no debris in the flow restriction device inside the handle end you will most likely need to clean the hand shower spray face. You can remove the unit from the hose and soak the spray face in CLR. Follow the instructions on the container for use and dilution. Soak for no more than 10 minutes at a time. After soaking, rinse the unit well and reconnect to the water source. Run water through it and while running rub the rubber spray channels to further clear up any deposits. Repeat the soaking and cleaning process at least two more times to clear out all deposits that may be limiting your performance. If you need more help feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'd be happy to help.
Oct 29, 2012 | Hansgrohe Shower 28504 Raindance S 100 Air...
I have a Bosch classixx 1200s Expresss. When I press the start nothing happens and a get a 12 beep alarm (4 then 4 then 4) every 60 seconds. There is power and water
I'm not an expert. I just had the same error (on a Bosch Maxx 6) and fixed it by chance.
My area has a lot of debris in the water supply, and it turns out that the small filter in the hose connected to the water supply was completely clogged up. You can either replace this filter, or clean it as outlined below.
Here are the steps to cleaning it:
1) Unplug washer
2) Turn of the water supply, either by a turning the handle to the washing machine water supply or by turning of the water main.
3) unscrew both ends of the water supply hose
4) Screw the washing machine end of the water hose into the water supply outlet
5) On the other end of the hose, there is a small filter. Hold this in place with the tip of your finger, and turn on the water supply for a few seconds, while keeping the free end of the hose in a bucket. This will flush water through the filter in reverse, thereby cleaning it. Do NOT reverse water flow with one end still attached to the washer machine, as this will flush all the debris into your machine!
6) Turn of the water supply, unscrew the water hose, and reconnect both ends as specified by the manufacturer.
Hope that helps!
-Dennis
Apr 07, 2011 | Bosch Classixx WFL 2066 Front Load Washer
2008 Samsung front end loader develops a 4E error
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Jul 12, 2010 | Samsung WF337AA Front Load Washer
Our front end loader stinks and we have to leave the door open. We have the exact same problem where I work. How do you get the smell out?
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 21, 2010 | Kenmore 44042 Front Load Washer
Cr 500 carburator
This sounds to me like a carb float being stuck open. Turn off the gas and drain the offending carb. Next, turn the gas back on and sharply tap the float bowl with the plastic handle of a screwdriver as the fuel bowl refills. The goal here is to vibrate the float to free it up. If doing this process a couple of times does not free the float I would remove the carb and clean it with a spray carb cleaner. Clean the air filter then re-mount carb. Next Remove the water trap bowl at the bottom of the petcock, (gas valve). Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ). Install an inline fuel filter.
Please rate this solution. Thanks!
Mar 28, 2009 | 2002 Honda CR 125 R
Cleaning light came on and now, coffee pot will not work
Automatic clean function
The coffee maker is equipped with an automatic clean function. After 60 brewing cycles, the clean indicator/button (22) lights up. This indicates coffee maker should be cleaned by using the automatic clean function and the charcoal filter (17) should be replaced.
NOTE: The coffee maker can continue to be used, when clean indicator/button (22) is on.
• To begin the cleaning cycle, remove the charcoal filter (17) from the water tank (10). Fill the tank with a vinegar and water mixture (1/2 vinegar and 1/2 water) or a descaling product. Press clean (22) button for three seconds. The clean indicator/button (22) flashes and the cleaning process begins.
Cleaning process:
• 24 cycles of 7 seconds brewing and 21 seconds off
• 30 minutes rest
• Brewing the remaining descaling solution
• After cleaning process is complete the clean indicator/button (22) goes off. Fill water tank (10) with clean water and run one brewing cycle to rinse the coffee maker.
• Change the charcoal filter (17) (ill. k). Reinsert the charcoal filter to the coffee maker (ill. l).
NOTE: You can use the cleaning function before reaching 60 cycles (especially if the water hardness is above normal). Press and hold clean indicator/button (22) for 3 seconds.
NOTE: The Cleaning Process takes 60 minutes to complete. You cannot cancel the cleaning process before it is complete. Unplugging the machine only delays the cleaning process.
Jan 26, 2009 | GE 106591 Coffee Maker
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Nov 23, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
Hotpoint Aquarius WF000 Front Load Washer Logo
27 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
