Question about Canon PowerShot SD1000 Digital Camera
My camera won't turn on. Battery is charged but nothing happening at all when I press power button.
  • natalies11 Aug 25, 2010
    The camera won't turn on at all. Battery is fully charged. It was not dropped on ground or in water.
  • Canon Master
  • 3,866 Answers
This happens when the flash capacitor dies Looks like this
My camera won't turn on. - 390e722.jpg It is connected to the battery fills up and powers the flash, the rest of the unit, vice versa:
You would not want to open this and expose yourself to it as it packs a huge Punch of electricity weather its good or bad allow a camera expert do it for you locally the cap cost $2-5 bucks.
Now that you know what your issue is with your camera you have the option to Fix it yourself or take it in even if i recommend take it in, but you know how to fix i you at your own risk can do so,
Thanks for using fixya.com, for the appreciation of my efforts please do click the accept button.
Posted on Aug 25, 2010
  • 10,594 Answers
HI,
Try this battery in another camera to make sure that battery is not cause of problem. Similarly put another same battery in camera to be sure that camera if fine.
Above said procedure will narrow down problem and if battery found bad, buy new one and if camera has some internal power supply problem that take it in local camera repair shop to fix it because it will take apart and visual check is needed by qualified tech.
Thanks.
  • Shahid Electronics
    Shahid Electronics Aug 25, 2010
    OK, that means camera main board got problem for some reason and it needs to be inspected by qualified tech because it is hardware issue that can not be fix with few button push.
    Take it in local camera repair shop for proper handling.
My LG 4G LTE won't turn on even though it has been charging for hours.
do you have a universal travel charger? and use it to charge your battery for about 4 hours. or buy a new battery.If it is not ok, your phone is in short-circuit. go to service center
Apr 15, 2013 | LG Cell Phones
Pentax optio w80 waterproof digital camera won't turn on
I had the same problem. I checked the voltage first to ensure it was greater than 3.7V (some batteries were not). I left the door open and pushed the battery down and pressed the button and it powered up. Seems to be a problem with the contacts. I put about 6 layers of duct tape on top of the battery to cause the door to push it down and now it works.
Feb 21, 2013 | Avianne & Co Pentax Optio W80 Waterproof...
Vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Aug 06, 2012 | Dell Vostro 1400 Laptop Computer (Intel...
Won't turn on
I had this same problem! Scoured the web and found no solution. This is what I did to fix it...
Remove battery. Unplug charger. Press and hold the power button for 20 - 30 seconds. While still holding the power button, re-insert the battery and/or plug in the charger. Voila! Came back to life and worked like nothing ever happened.
I also did the same thing with the record button, but it was the power button that got the result.
Hope this helps!
Feb 29, 2012 | Toshiba Camileo S30 HD Camcorder -...
Press power button nothing happens
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 27, 2011 | Olympus Cameras
Polaroid A500 digital camera pressed ON button, nothing happened with new AA batteries and SD card
Nov 25, 2011 | Polaroid Cameras
I have a Canon PowerShot SD600 Digital Camera. The battery has a full charge but the camera will not power up. I press on and nothing happens. What do you recomend?Best RegardsNeil
Oct 02, 2011 | Canon PowerShot SD600 Digital Camera
Reset button ?
Sometimes there is a reset button and sometimes you have to reset it through a menu. Of course, if it won't turn on, then you can't get to the menus.
May I ask, what is you Toshiba camcorder's model #?
Jul 31, 2010 | Toshiba Video Cameras
Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
Mar 26, 2010 | Panasonic Lumix DMC-FZ3 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
27 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
