Toshiba 250GB 5400RPM 2.5" SATA Drive Model MK2565GSX 8MB Buffer SATA 3.0Gb/s Interface 1.5W Read/Write Power; 0.18W Standby 9.5mm x 70mm x 100mm will this harddrive work in a toshiba tecra A3
SOURCE: I HAVE ALSO LOST RECOVERY DISKS OF TOSHIBA TECRA A3 .
Toshiba carried the A# recovery CDs for 2 years.
After that the licence was given to another company.
At the begining of 2009, Microsoft told the company to stop.
A3 recovery is no longer available.
SOURCE: Where to find driver for touchpad scroll toshiba
To Enable the Pointer Device, go to, Control Panel, click (Mouse) in the Hardware and Sound category. Go to, Device Settings, in the (Devices) block, click on, and Highlight; the item you want to (enable) this being the Pointer Device. Click the Enable button, just below. Be sure to (Click) on the Apply button, click OK. You may need to Update Drivers. Click on Hardware, click Properties, click, on Driver. If the, Update Driver (block) is not Grayed-out click Update Driver, click (OK), this will ensure that the application take effect. Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware. I hope this Fix it. paul7of9
SOURCE: Toshiba Tecra S1. My laptop has power but will
It has a memory problem, take the laptop to your local store and ask if they will test the memory for you, if it is the problem then you will have to purchase a new memoy module.
