Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Both sides are not geting cold the compressor is working and the fan,what cloud be the problem
  • 86 Answers
Hello
The problem may be just a dirty condesor. It is located under the frig. clean all the dirt and dust out and you should be fine. I hope this helps. Please leave feedback.
Thanks
Posted on Aug 25, 2010
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
My ac is not geting cold
No problem. just put it in bed with my wife!
With all joking aside, there are MANY things that can cause your A/C to not get cold. The most common is that your system could be low or out of freon. If this is the case, the system needs to be checked for leaks and repaired so it will not just do it again.
Other possible causes are broken blend-air door in the A/C housing under the dash, a defective blend door actuator, malfunctioning condensor fan or fan circuits, a bad compressor or compressor clutch, a stuck-open expansion valve, etc.
The place to start would be to hook up a set of gauges and check the high and low side pressures in your system. If there is plenty of freon, then you must look elsewhere for the cause. You must systematically eliminate one possibility at a time until the problem is located.
Aug 20, 2011 | 1997 Nissan Sentra
My 25.2 refrigerator and freezer not geting cold i clean the coil and still not getting cold its been this way about a week or so.
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Hope that help in solving the problem...
Jan 11, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Just brougt had it staningup slinted a litte bit geting off truck wife cleaned it up plug it in comppessor kicking in not geting cold in side
After transportation or tilting one should not plug till after aprox 2 days to allow compressor oil to setle down. Switch off now and let setle for 3 days if does dot work you may have to change the copressor and vacuate the system.
Jun 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
NOT GETTING COLD
the first thing to check is the thermostat if its stoped working them it wont be telling the compressor to start up and the unit wont get cold,,
have this looked at first as its the cheapest part to renew
May 22, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Quit geting cold, started Sunday, things are completely defrosting now. I tried to unplug and restart. The fan seems to come on but the compressor does not. Can't find the defroster timer to see if maybe...
Sounde like the overload is bad on the compressor . Pull the refrig out and remove the lower panel . Attached to the side of the compressor , is the overload/relay . If the compressor is not running , replace this part . Only 2 or 3 wires connected to it . Take your model number with you when getting the part , as you didn't list it here , or a part number could have been given .
Oct 21, 2009 | Kenmore Refrigerators
My compressor stoped working and it got hot and
If the fan was the problem and the compressor is now running , it should start getting cold.
Oct 16, 2009 | Amana ARB2217C Bottom Freezer Refrigerator
The food side not geting cold I set up the control nothing
the small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
Mar 06, 2009 | Amana AFD2535DES French Door Refrigerator
The fan on my fridge is working, but its not cold. Everything thawed out. Do you know wht this could be?
There are a couple things to check and do.. 1st check if your compressor is hot.. (pull fridge out, back bottom area remove to get to comp) if comp is hot possible refrigerate leak.. the other is capacitor (or hard start kit is needed)... unplug fridge and let sit for a few hours (like 5hrs).. plug back in.. you should feel cloud in the freezer area in 15min.. if not then, your possible problems I mention 1st.. hope that well do.. good luck.. mike
Jan 23, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My ge side by side is not geting cold on either side
Hi ladyjazzy,
If the refrigerator just stopped cooling all at once then you may have either a condenser fan motor or a compressor problem. If it gradually stopped cooling then you may have a defrost problem and need either a defrost heater, defrost thermostat, or a defrost timer. give us a little more infor and Im sure I can figure it out for you. Lots of luck to ya, and I hope I helped. mca0824@aol.com
May 02, 2008 | GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
24 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
