Question about Ricoh Aficio GX3000S multifunction Ink Feed System
After replacing the ink waste tank, I am still getting an error stating replace waste ink tank full on an Ricoh GX3000 all in one.
    Problem Solver:
  • 10 Answers
This may have to do with the method of replacement. Leave the printer on, remove the waste tank, clean the area (sensors may detect residual ink) replace the empty waste tank. If this doesn't work, there may be a chipset on the waste tank to indicate end of life. This is a way for the manufacturer to continue making a truckload of money from the end user. Generally the only way around this is to modify your printer to by-pass this part of the circuit (an electronic solution to replace the chipset). This method will most likely void your warrantee.
Posted on Sep 03, 2010
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
Ricoh Aficio GX3050 Gel sprinter - error999
BULLETIN NUMBER: J001/J003/J006/J007/J010/J011 – 021 07/02/2008
APPLICABLE MODEL:
GESTETNER – GX3000/GX3050n/GX5050n
LANIER – GX3000/GX3050n/GX5050n
RICOH – GX3000/GX3050n/GX5050n
SAVIN – GX3000/GX3050n/GX5050n
SUBJECT: SC999 OCCURS
SYMPTOM:
An SC999 (Maintenance Stepper Motor Home Position Error) occurs.
CAUSE:
Some of the ink in the machine has dried, and as a result the maintenance stopper motor cannot rotate or
the levers come loose.
NOTE: The following conditions make it easy for the ink to dry up (See Appendix 3 for more details):
- Low humidity
- Long intervals between machine usage
- Total period of usage is long
- Low Print Volume
 COPY QUALITY
Fixed ink Stepper Motor
Right Flushing Gate
Levers
Tech Service Bulletin No. J001/J003/J006/J007/J010/J011 – 021
Page 2 of 5
SOLUTION:
Production Countermeasure:
The shapes of some parts in the Maintenance Unit have been changed in two steps ("Step 1" and "Step 2"
below).
NOTE:
See Appendix 1 for the details of the Step 1 and Step 2 modifications.
See Appendix 2 for the visual differences among the unmodified unit, the Step 1-modified unit, and
Step 2-modified unit.
See UNITS AFFECTED for the Serial Number cut-in of Steps 1 and 2.
Field Countermeasure:
1. Cycle power OFF/ON.
2. Install one of the modified Maintenance Units ("Step 1" or "Step 2").
NOTE: For customers experiencing a SC999, have them contact 1-800 Ricoh38 for replacement.
Feb 02, 2010 | Ricoh Aficio GX3050 GelSprinter
I replaced the ink waste tank on my Ricoh GX3000 - then it asked for new yellow ink cartridge and I replaced that. Now I have an error code 990 and I can't get rid of it.
bonjour,
allume ton imprimante,puis retire toutes tes cartouches.
eteint l'imprimante.
rallume l'imprimante et remet les cartouches.
le code d'erreur 990 indique de l'air dans les tuyaux.
ça devrait marcher!
Oct 05, 2009 | Ricoh Aficio GX3000 InkJet Printer
Have error code 990 on ricoh gx 3000 printer how do i clear this?
you can try pulling out and reseating the Waste Ink tank which is located behind the machine behind a plastic door cover (left side of machine as you are looking at it from behind). Turn the machine off and on using the main power switch. If the code comes back then you will more than likely need a new Waste Ink Tank.
Mar 23, 2009 | Office Equipment & Supplies
Waste ink tank full on a Ricoh Africio MP C1500 sp
The book doesn't really tell you where it is in the machine but if you open the door in front of the copier, look for a white plastic bottle with toner in. Remove the toner bottle from the machine and dispose of the toner bottle and replace it with a new one or dispose of the waste toner. Clean the bottle and replace it back into the machine.
Dec 02, 2008 | Ricoh Aficio MP1600SPF Copier
Probems with a waste ink tank on a Ricoh Africio MO C1500 sp
on the right hand side of the machine , open the door you will see a transfer belt unit pull it out,there have a plastic pan remove it dump the waste toner.
I have a Ricoh G7500 printer that is giving me an ERR-990 when I turn it on. I don't see any documentation on Ricoh error codes.
990 A Waste Tank Full Sensor Defective
The waste ink tank full sensor (a
photosensor) on the corner of
the waste tank is not operating.
• Waste ink tank sensor on the corner of
the ink waste tank is defective.
• Replace the waste ink tank.
Aug 23, 2008 | Ricoh Office Equipment & Supplies
Ricoh GX3000
ERR (990) or ERR (999) are both error messages which are displayed when a sensor does not work normally due to dirtiness. For example, either may be caused by a dirty maintenance unit or clogged ink nozzles. It may be possible to resolve the issue by cleaning the device
look here for instructions:
http://www.ricoh-usa.com/support/knowledgebase.asp?tsn=Ricoh-USA
Jan 25, 2008 | Ricoh Aficio GX3000 All-In-One Printer
Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Aug 19, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
Ricoh Aficio GX3000S multifunction Ink Feed System Logo
216 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
