Question about Toshiba 61A61 61" Rear Projection Television
Tshow me how replace ir sensor on toshiba tv 61a61
  • Toshiba Master
  • 12,061 Answers
Http://www.fixdevice.com/smanuals/file/31211.html
Please find above your service and repair manual, inside it shows you everything you need to know to accomplish this.
It is NOT a difficult task. BUT you will need a soldering iron on some sub chassis. Others use a plug and Wire, and one simply unscrews the old, unplugs from the sub board and replace. Other ones are soldered to a sub board, and need to be removed with a soldering iron. Either way it's a doddle. (Easy to do)
Posted on Aug 25, 2010
Toshiba 57H83 TV...My remote doesn't work...checked batteries & replaced remote...suspect IR sensor bad...can you tell me how to get access to the IR sensor to replace?
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
May 20, 2012 | Toshiba 57H83 TV
Lines across screen
I think its an electronic interference problem
Mar 25, 2008 | Toshiba 61A61 61" Rear Projection...
Toshiba no picture
then your optical section has fault.
Mar 17, 2008 | Toshiba 61A61 61" Rear Projection...
Toshiba tv 61a61 screen all red
jeffjo7,
Your unit is 10 years old and more than likely needs the drives adjusted on the blue and green guns. I have a tip at http://www.fixya.com/support/r6814105-adjust_screen_drive_crt_projection_tvs
which explains the process to adjust the screen drives for the best picture.
Thanks for using FixYa and for the great rating.
hardrocko
Mar 14, 2011 | Toshiba 61A61 61" Rear Projection...
I have the Toshiba 61A61 TV. I am not sure what exactly happened, but when the TV was on, suddenly the picuter went black. I still receive the normal sound, but can't get any picture (totally black). I...
Check all connections?Unplug,replug the cable box about an hour later let it upgrade it software.The projection lamp has not been replaced in this tv the last 1 1/2 or 2 years?The tv been on and watches at lest 4 or 5 hours a day?Yes,than the projection lamp life is over.Require a new projection lamp.
Sep 03, 2010 | Toshiba 61A61 61" Rear Projection...
My Logitech Harmony does not move my Toshiba TV between inputs
It all depends on the Logitech remote's Harmony features. Can it you place your original Toshiba remote IR sensor up to the IR sensor on your Logitech and learn from the Toshiba remote?
Nov 19, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I have a toshiba 61a61 that wont turn on but i unplug it and the red light turns on off and the same when i plug it in dont know what i can be
standby relay not latching in, may be a safety precaution due to a temp sensor or other power board protection, or the relay might just be failing !
Hope this help's as when you take it to the shop they might not charge you too much if they think you know what it might be !
Sep 22, 2009 | Toshiba 61A61 61" Rear Projection...
Stay on power light but no light or sound
No picture, no sound and all the fuses are ok, means there are no shorted components in the circuit, more than likely the tv is not generating horizontal drive to produce and feed hv to the crt and no b+ for the audio circuit. The tv is big enough to keep and repair if you are cosidering a repair estimated around 400dlls. I think the problem would be located in the deflection board.
Sep 09, 2009 | Toshiba 61A61 61" Rear Projection...
Toshiba CF32H50-no control from remote
Could be the remote does not operate on the correct frequency, but also may be the IR reciever sensor inside the TV, best bet is to bring your remote to a pawn shop and try it on a set there (they sell older model sets look till you find one like yours). once you determine the remote is OK, check the IR sensor for bad solder connection or replace it by soldering a new one in. Also some Toshibas develop micro CPU issue (the computer IC), another thing you can try is cleaning the main board control area with electrical cleaner residue can load down the control circuits but then the buttons would also malfunction.
Aug 01, 2009 | Toshiba CF32H50 TV
Toshiba 61A61 61" Rear Projection Television Logo
202 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
