When i plug in my condenser, and the phantom power is on, none of the pan knobs are turned left or right, but for some reason when i talk into the mic, it is panned to the left. and when i record it does the same thing. i cannot find any solution. i have tried a lot of things. please help me. thanks
  • 4,234 Answers
There is not enough information to go on here. A condenser mic is usually connected via XLR connections and receivers done have thaty type of input. Where is the phantom power coming from. Perhaps the wiring of hte XLR is incorrect for the equipment being used. (There are 2 standard connection styles). Can you update this with the equipment being used and how it is connected?
Thanks,
Dan
Posted on Aug 25, 2010
My at4033a/sm is about 6 years old and only used 2 or three times .plugged it in...there is no sound
I have two words for you...Phantom Power.
Electrete condenser mic's MUST have phantom power to operate. Look for "Phantom Power" button on your Jackie (surely means Mackie) and try it again BUT turn volume down before engaging phantom power or testing mic.
Feb 06, 2013 | Audio Technica Audio-Technica AT4033A...
I plug the microphone into my mac using a usb adapter, and it recognizes me turning on/off the mic, but not my voice when I talk into it.
You need Phantom power for condenser mikes.
No mac gives that.
Use a dynamic mike and try, now you know.
Peace-
Jul 15, 2011 | Marshall MXL 604 Microphone
On my Behringer UB1202 mixing board none of the inputs work. I plug headphones into the headphone jack to monitor. Neither dynamic nor condenser microphones work (with phantom power enabled when...
Does your computer Recognize the mixer. and to answer your question honestly Behringer is Junk they make cheap knock offs of really expensive products. but see if your computer recognizes it and if not i sugguest taking it back
May 13, 2011 | Behringer XENYX 1202 Premium 12-Input...
Have only had it for just little under a year and I can't get the mic to sound I have a CD player hook to it its player but mic will not
Without knoowing what type mic you have and where it is connected we can't help you. Normally a mic is connected via an XLR to XLR cable to one of the input XLR jacks. Then you turn up the top white knob... start at about 3 o'clock. This is the input trim control. Set the grey pan control in that same line of knobs to 12 o'clock. Move the slider up for that column AND move the MAIN slider up.
The speaker should be in the A/B mode for stereo. With these settings you should get mic output.
Please view videos on YouTube about "mixer setup". MOST mixers are about the smae and what you learn about any of them will apply to your unit. One other thing is IF you are using a CONDENSER type mic, you will need to turn on the PHANTOM power switch. Note condenser mics are so sensitive that they must be used in a studio as if they can hear the speakers at all, feedback will occur. Also be careful if your speaker plugs are 1/4 inch, do NOT lett the sleeve of channel A touch ground as the sleeve, not the tip is hot.
Apr 16, 2011 | Behringer Europower Pmp5000 Powered Mixer...
I have a Yamaha IM8. I had a condenser mic hooked into channel one with phantom power on. I had to leave the room for a while and when I came back, I noticed some rather severe popping in the audio. I turn...
There is really no way for a condenser mic to damage the board UNLESS you break the ground and get a static discharge into the input. That can happen with any microphone and has NOTHING to do with the phantom being on or off. As phantom power goes on and off slight bias at the input preamps can make amps non-linear causing the raspy sound you heard. The Phantom LED means NOTHING as it shows the state of the phantom switch by connecting a 12 volt source through a resistor to the LED... It shows NOTHING regarding the state of the 48 volt supply. Each input circuit has two 6.8Kohm resistors to the swinger of the phantom switch 2nd pole that either grounds those or connects them to a filtered 48 volt source. As long as you don't have a static buildup there is NO need to turn phantom power on or off while connecting a condenser microphone. At each input when using the XLR jacks are two per side 470pf capacitors for RF bypass. For the XLR's there is a 10Kohm between the signal lines and two series 10mfd/50 volt caps in series of each input to block the DC, when using phantom power, from reaching the preamp stage. These caps have to charge and discharge when changing the state of phantom power so you should AVOID having the main amps being driven while changing the state of any phantom power. Always have the fader(s) down and any monitors down to avoid a thump and also the non-linear raspy transition as the input caps charge/discharge. So fix the microphone... don't know what type you have, but DO check the cable (first) as ALL three conductors MUST be good for a condenser mic to work on phantom power. A ground leakage or noisy connection will cause your symptoms. Use a SHORT known good cable right at the board to test the mic. The 48 volts is applied through the two 6.8K resistors between both the signal lines to the shield of your XLR cable. The microphone picks off the 48 volts with a similar circuit.
Now let's cover a very important thing regarding system safety: ALL, and I do mean ALL interconnected equipment MUST be powered from the same source. Professionals run a power cord back to their mixer right alongside the snake. This is to avoid ground bounce damage due to bad building grounds or ground faults.
Mar 22, 2011 | Yamaha IM824 24 Channel Mixing Console IM8...
My U87 microphone won't power up...no signal. does anyone know why this may be happening?
Was it working fine before it stopped powering up? The U87 is a condenser microphone so maybe the reason it is not powering up is because the phantom power on your interface was not turned on. Plug the U87 into your preamp and then switch on the phantom power (48V) to get it powered up. If that doesn't help, there must be an internal fault within the microphone or in your preamp.
Mar 02, 2011 | Neumann U87 Professional Microphone
I have Lexicon alpha, Condenser Mic, phantom power .If i record, the voice goes only to right speaker. I am using cubase le 4, stereo in/out are correctly.
Sorry, but the Lexicon Alpha does NOT have Phantom power and you can't use a condenser mic with it without a Phantom power injector or preamp.
If you mean you have a Phantom power injector then it should be working. Do you have seperate mics for the two channels of the stereo? If you have only one mic, then only one side will record unless you set for mono recording and then dump the recording into stereo voa Cubase. I would recommend you get a small mixer... even a 4 channel one to use ahead of the Lexicon so you can mix and PAN your mics the way you want them. The recording and trying to control the panning in Cubase can be frustrating... The Lexicon really doesn't have anything built in to PAN the mic to the center when stereo recording. Small mixers are inexpensive and often you can find them used or in pawn shops for cheap.
Feb 12, 2011 | Lexicon Alpha Personal Recording Studio
Signal peaks automatically once track is armed for recording.
Is there something plugged into your inputs, and are the pre amp channels turned all the way down? Also is your 48V phantom power turned off? To prevent damage to diaphragm or electronics of condenser microphones, the phantom power should be left turned off and only turned on after a mic is plugged in and the pre amp turned off and track unnarmed to prevent damage to speakers.
Aug 17, 2009 | Digidesign MBox 2 Mini (USB, includes...
Not working
If it is brand new, it is likely "pilot error" as setting these up if you are unfamiliar with mixers can be frustrating.
There are several things that must be done to have a working system. Correct speaker cables are one and the setting of all the knobs are important...
DO NOT REPLACE FUSE. If any LED's are on, fuse is OK. If fuse blows, service the unit before replacing fuse to avoid further internal damage.
Make sure speaker cables are good.
Set the level control for the channel you are testing up AND you may need to press the "PAD" button to change the input gain. Turn up the master gain.
Depending on the source you are using, line or mic you may need to change the PAD button.
NOTE: This mixer does NOT have Phantom power and cannot be used with CONDENSER microphones requiring phantom power. You will get no audio from a condenser mic without phantom power. You must use dynamic mics with this mixer.
Jun 12, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
 Grubhead
Grubhead
