Question about Leupold 1 3 x 14 CQT Riflescope
Taking off the top screw for elevation the unit below the cap came off also. how do you seperate the two? thanks jack
    President:
  • 2,702 Answers
That what you get for doing them up so tight,,,if your lucky you should still have a little thred showing ,,get a hold of this thred in a very very soft vice and undo the cap,,,,if you bamage this thred the scope is going to be a scraper,,,when you get the top off put a spot of supper glue on the first thred and screw it back into the scope,,,you should now have the scope re-gased,,,
Posted on Aug 25, 2010
Testimonial: "thanks this did help. where do i get it regased?"
  • Michael Thorpe
    Michael Thorpe Aug 26, 2010
    so you fixed it then a? now go and find a camera shop and get a bottle of "nitrogen" they may call it "dust away or dust off" its compressed gas "make shore its "nitrogen" and not "co2" all you need to do it look at the scope for a small grub screw in the body of the scope this is the purge plug undo the screw and puff nitrogen into the scope to push out all the air from it,,, this should stop it from foging up,,if it dont you need to dry out the scope first so warm it up,,,
    just warm it only dont go cooking it!! as nitrogen is a heavy gas it will lay in the lowest part of the scope and it will fill up and push out all the air as it fills it up,,,it also stops the groth of mould on the glass inside the scope,,,go very gentely with the gas filling,,,
    now,,,mine's a piy and pint?
Header tank cap seperation
you have one of the faulty caps that were made you are going to need to replace it with a new one. you will need to prise out the bit stuck with a screw driver and lift it out if any parts brake off you need to take the coolant tank off and empty the broken bits/s out. caps are cheap to replace.. off ebay
Mar 09, 2014 | Vauxhall Cars & Trucks
Imaginext batcave elevator string came out
I had the same issue, my son used his all of half a day and the elevator stopped working. If you take the top of the cave off, and unscrew it from the elevator shaft you will see a black wheel. The string needs to be wrapped around this twice, there should be very little play in the string. What I had to do was take out the 3 screws that held it to the knob on top, then wrap the string back around the wheel making sure not to tangle the string more. once the string is wrapped 2 times you can reassemble.
Dec 18, 2011 | Toys
How to replace headlight bulbs
It's a nightmare! But you can do it!You have to basically remove the bumper and grill which are attached. Once you do that you will expose the headlight unit. I believe there are a total of 4 screws that need to removed to access the light source. Once you remove the screws you have to unplug the wiring which is just a snap connection. That will free the unit. Once you remove the unit on the back you will notice a round screw cap, take the cap off and you will see a silver triangle shape connection... twist that off and you will see the back of the bulb which is held down by two spring connections. You need to press them together and bulb will come free. Then you just take the bulb out and put in the new one. (Which cost around 260.00 from Infiniti ugh... I know ridiculous) and reverse the process! Its takes a while but it's pretty easy let me know if you have anymore questions. Oh and to remove the bumper I think there are 2 Screws on the top part and remove the plastic push fasteners on the top of the grill under the hood. video below shows how to take the bulb out and replace it. Not that you should never touch the bulb part with your bare hands oils can cause less life expectancy making you have to change it sooner then expected. If this helped please feel free to rate the solution accordingly. Thanks, Midwest-tek
Aug 31, 2010 | 2005 Infiniti G35
Elevation cap srew broke, Bushnell Banner, 20 yrs old 3x9x38
Take it to a well stocked hardware store and see if they have a screw that will work.
Aug 25, 2009 | Bushnell Banner Dusk & Dawn 3.5-10x36 AO...
Where is the oil sending unit on a 93 chevy silverado 350 engine
the oil sending unit is located at the back of the motor right below the rotor cap it is about 3 inches long and has a 3 wire plug hooked t it
Feb 21, 2009 | 1999 Chevrolet Silverado 1500
Tasco scope issues with elevation adjustments
Take the lens caps ff.Then run a new Leupold under it..
Jan 16, 2009 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
JVC ¾? Umatic Model CR-6060U parts or alturnative
I used to repair these units and still own one. Each
one of the black side panels (control panel covers) is
held in place by four screws. After removing the
screws and control knobs, the right panel should come
right up. You may need to move the left hand panel
forward to clear the headphone jack before it can be
removed. From your description, it sounds like the
FF/play rubber tire is worn. After removing both side
panels, remove the cassette elevator. The elevator is
held in place by four screws. Two on each side of the
elevator. Pull the unit up, the FF/play and RR rubber
tires should now be clearly visable. Have you found a
video head yet?
Jul 29, 2008 | Televison & Video
Rt. elevator arm replacement
Take off the top cover, then you can replace the elevators, they come both sides in a package, part #2000010. When you replace the top cover, check all tubes to make sure they are routed right so as to not pinch one when the cover is locked down. Also there is a piston that attaches to the bottom of the smart mix valve and that the smart mix knob is on the water setting, then put cover back in place and don't over tighten the screw.
Jun 13, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Leupold 1  3 x 14 CQT Riflescope Logo
35 people viewed this question
Top Leupold Optics Experts
ray gallant
Bill Boyd
Are you a Leupold Optic Expert? Answer questions, earn points and help others
