Question about Whirlpool Duet GHW9150P Front Load Washer
We had a power outage during a cycle & now the door is locked & I can't open it. All I get is add a garmet. Even if I clear that by holding in the end cycle button for 5 seconds, the door is still locked?
  • 5,081 Answers
Completely disconnect the washer from the power and then connect it again. Now start the washer and check if the door is still locked.
Posted on Aug 25, 2010
Kitchen aid gas range KGRS807, 901 or 907
The only time that the oven door should be locked is during the internal "Self Cleaning Cycle," due to the high temperatures used. Make sure that the display does not indicate that the oven is not in it's self-cleaning cycle, and try wiggling the door slightly to see if you can dislodge the sticking lock pin.
If this does not help, then I suggest that you Call the KitchenAid Customer eXperience Center toll free: 1-800-422-1230
Aug 30, 2015 | Kitchen Ranges
Kenmore 95024 Electric Range The self clean cycle Door stuck shu
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 27, 2010 | Kenmore 95022 / 95024 / 95029 Electric...
Oven door locked
put back in clean then cancle
May 25, 2010 | Zanussi ZBF360X Electric Single Oven
I just had a power outage. My garage door was open during the whole afternoon. I pulled the red trolley emergency cord and pushed the door down but I couldn't get it closed (locked). Why not?
IF THE OPENER IS IN THE OPEN POSITION THERE IS NOTHING TO LOCK IT IN THE CLOSED POSITION.
YOU CAN UNPLUG THE UNIT AND PLACE A VICE GRIP ABOVE A ROLLER ON THE TRACK. THIS WILL SECURE THE DOOR UNTIL POWER COMES BACK ON - DO NOT LEAVE THE UNIT PLUGGED IN - IT COULD BE DAMAGED BY A POWER SURGE WHEN THE POWER COMES BACK ON (ALL ELECTRONICS IN THE HOUSE SHOULD BE UNPLUGGED) ALSO IF YOU FORGET AND PUSH THE BUTTON THE VICE GRIP WOULD CAUSE THE DOOR TO COME OUT OF THE TRACK, MAKING YOUR CURRENT ISSUE SEEM SMALL.
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Washer loader door is locked and i cant open it
this kind of door lock is called PTC door lock.It is designed for protecing you from opening the dooe during the washing and spining cycles which may hurt you.So, if you want to open the dooe during cycles,pls press "stop",then ,wait 2 mins,you will be able to open it by then.the other situation is that,the power is cut off during working cycles,solution is:re-start the washer and directly open the door.Pls note that this kind of lock has to work under power.
Mar 14, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Will not restart after adding clothes
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. Wait for 2 minutes before trying the door. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
Apr 19, 2009 | Whirlpool GHW9300 Duet Washer
HE front loader washer door opened during cycle and will not shut
the latch broke within( the hook inwhich actually hold doorshut) , youll need a new latch assy.
Mar 14, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Frigidaire range
Unplug the unit, then manually depress and hold the light switch on the frame of the unit while plugging it back in. The lock should go back into the proper position.
Craig Mac
Nov 16, 2007 | Frigidaire FEF376 Electric Kitchen Range
Whirlpool Duet GHW9150P Front Load Washer Logo
212 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
