Question about Sub-Zero 695/O Side by Side Refrigerator
Where would I find a screw for my Sub Zero door handle?
  • 86 Answers
Hello
Are you missing a screw? Any good hardware store should have a good replacement screw. I hope this helps.
Posted on Aug 25, 2010
Loose door handle
if this is a style with an aluminum handle that runs top to bottom of the fridge door, then you have to remove the metal strip in the center of the door handle. It is held by magnets. the best way to remove it without damaging it is to put a piece of electrical tape in the very center of the metal strip, and pull on it gently. it should lift it away from the handle then you can get your finger behind it to pull it the rest of the way off. DONT BEND IT or you will be buying a new one. Once they are even slightly tweaked, they will never stay on. Under this strip are the screws holding the handle on. Tighten them then tuck the strip you removed into the bottom then the top trim and just let it snap back into place.
Feb 19, 2014 | Sub-Zero Refrigerators
Sub zero 736
The screws come through the back side and into the handle.
Jan 06, 2014 | Refrigerators
How do I change the door panels on a model 642/F
If you have an overlay door, by removing the door handles, should be about 6-8 screws located when you open the door look at the handle, you should see these screws run top to bottom.
I hope this helps.
Oct 12, 2013 | Sub-Zero 642
Sub-Zero 601R door handle is loose
My Sub is a 650S. Not sure your handle assy. is the same or not. But each of the 2 attachment points have a small 3/32" set screw on the bottom of each short piece between the vertical handle and the door. These set screws grab onto posts that are screwed into the door. There can be 3 points where the handle can work loose.
1. The set screw(s) have backed out and not holding tightly onto the door studs. 2. The studs in the door are loose and need to be tightened with a screw driver. 3. After loosening the handle via the set screws, when you look back into the cavity vacated by the studs from the door, (pivot handle clockwise past edge of door) you will see a Philips-head screw that secures the spacer to the handle. If the spacer is loose, tighten it with screw driver. Then mount back into door stud and tighten set screw. Problem Solved. Have a beer!!!
Nov 26, 2010 | Sub-Zero 601R
I need to remove the wood door panels on my sub zero to repair a door handle
I have subzero 642 but it should be the same. Remove 2 screws on the top edge of the door. The screws attach a metal track to the top of the door and the track needs to be loosened to allow the front wood panel to slide out. Next on the side edge of the door are 3 metal strips. The middle one is held in place simply by magnets and slots at the top and bottom edges of the door. You can remove the middle strip by lifting it out in the middle with a small screwdriver and pulling it off. This will expose 3 or 4 screws that hold a metal track to the side edge of the door. Remove these screws and the metallic track on the side edge of the door. You can then slide the wood door panel out enough to expose the 2 screws that the door handle attaches to. Good luck!
May 16, 2010 | Sub-Zero 632 / S
The door handle on my sub zero 650 has come off.
On Few Models, To remove the existing handle have a look for clipped on covers hiding the screws.On others, With a small flat blade screw driver stick between the handle and the door trim on top and push it up and on the bottom push it down and you can access the screws in the handles and tighten.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 05, 2009 | Sub-Zero Bottom Freezer Refrigerator
How do you tighten a loose handle of the fridge door? Sub zero 642
I have the Sub Zero 650. I am not sure if yours iworks same but what you do is use a 3/32 Allen wrench; as you push the handle into the screw on the door so that it is flush, you insert the Allen wrench in the hole at the bottom of the short vertical connector at top and tighten; repeat for upper or lower part of handle.
Aug 15, 2009 | Sub-Zero 642
I nee to tighten up the freezer door handle on a sub zero 650?
There are different handles depending on serial number. The older of the two is at the top of the door. The screws are covered with a magnetic trim piece. You can remove this by putting tape on the chrome and pull up. You can then tighten the nuber two phillips head screws. The newer model is on the door itself. These are held on with small set screws accessed from the bottom of the handle. You may get by just tightening the set screws. If not you need to remove the handle by removing the set screws. You can then tighten the standoff and reatach the handle. For the 632 same procedure except it will be on the side.
Apr 12, 2009 | Sub-Zero 650 / O Bottom Freezer...
Main door handle top section pulls out from bolt on sub zero 642
There is a tiny set screw that holds that in place. It is on the bottom of the stand off and just needs to be tightened.
Nov 26, 2008 | Sub-Zero 642
Sub-Zero 695/O Side by Side Refrigerator Logo
79 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
John Tripp
John Tripp
Steve
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
