Question about Samsung 7.3 Cu. Ft. Electric Dryer
Samsung dv 209 dryer gets power but when the start button is pressed the drum does not turn...is this something I can fix
  • Samsung Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Samsung dryer. It starts, but it doesn't get hot?
Samsung Dryer Diagnostic Repair & Diagnostic - Not ...
? 19:33
https://www.youtube.com/watch?v=a-8UFyRXBDg
Feb 7, 2014 - Uploaded by ApplianceVideo.com
Troubleshoot your own Samsung Electric Dryer that has some of the ... It powers on but when I get start nothing happens... drum spins but not ...
How To Fix A Clothes Dryer That Is Not Heating Or Drying ...
removeandreplace.com/2013/.../fix-clothes-dryer-heating-drying-clothin...
Sep 21, 2013 - At times your dryer can overheat and this can cause the motor that turns the ... Clothes Dryer Will Not Stay On After Pushing Start Button My dryer will run if I ... I have tried the trouble shooting tips for a dryer that doesn't dry but to no avail. ..... I have a 3 year old electric Samsung dryer and it stopped heating.
[FIXED] Samsung dryer runs, no lint clogs, good airflow, but no ...
forum.partsdr.com > Forum > Appliance Repair Help > Dryer Repair
Mar 12, 2013 - 16 posts - ‎4 authors
I want to check the third harness it but it doesn't look to slide out too easy once I remove the one phillips screw. ... Dryer gets nice and hot now!
Jan 19, 2016 | Samsung Dryers
Clothes dryer does not work when power turned on at wall. Sounder goes continuously, no lights on panel and panel buttons do nothing
If it didn't do that before removing the capacitor & wires then I would assume it is something you have done wrong. Maybe put a wire back in wrong place. There is a wiring diagram on back of dryer. Motor not starting could be the capacitor, you really need to test it with a capacitor tester. It may also be the motor bearings seizing up. If motor is tight to turn when belt is off then it will be time for a new dryer. Too expensive to replace the motor on such an old dryer.
Jan 03, 2016 | Fisher and Paykel Dryers
Why the drum on my samsung dryer not turning when the dryer is on and in drying mode?
Hi Is several resolutions:
1 broken belt
2 broken drum rollers
3 broken berings
Oct 15, 2014 | Samsung Dryers
Drum not turning
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced.
Now if you press the start button and the machine starts to hum and continues to hum its possible that something has gotten caught in the blower wheel and binding the motor up. Depending on the make and model the location and access to it vaaries.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 06, 2012 | Kenmore Dryers
My gas dryer is a whirlpool LGR4634eq0. Timer starts but when I press the power button i hear a load noise( like a stuck hinge) and the dryer wont start. Help
The power button is usually called a "start" button. For as long as you hold it down, it provides power to the motor. When the motor gets up to speed, centrifugal force holds the switch closed for you. This is why a quick (short) opening of the door will not stop the dryer and a quick press of the start button will not start the dryer.
This, however, does not explain the noise...
The motor turns a belt which wraps (sort of) around a pulley which is on a spring (and also around the drum). The spring should hold tension on the belt, but the belt should not be so resistive (drum refuse to turn) to cause the tensioner to strike anything.
Can you turn the drum by hand?
The drum rides on two wheels. They should roll smoothly.
:o).
Jun 04, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Drum will not turn and there is no heat.
This dryer has a circuit board that controls virtually everything. If it makes a buzzing noise when you press the power button to turn on the control panel, it's probably not going to be an easy fix. When you hire a professional, you avoid buying expensive parts that you might not need, such as a control board. If it makes a loud buzzing noise when you press the start button, it's possible that it could be a motor or belt problem. But again, I'd recommend a service call for this one.
May 25, 2010 | Whirlpool GEW9250 Electric Dryer
Maytag electric dryer. LDE9314ACE Drum won't turn, but sometimes will. Had friend turn drum manually while I pressed start/door buttons. Drum turned fine but when I let go of buttons to shut door, dryer...
The motor capacitor is burned. You can replace it yourself. It's on the motor. Take it down to a motor shop and they will have a new one. (electric motor repair shop)
Sep 25, 2009 | Dryers
Kenmore dryer electric doesnt start
It sounds like the dryer drum belt is broken
there is a drive belt that goes all the way around the dryer drum and when you press start the drum starts turning unless teh belt is off or broken
You can change the belt or call and have service technician change it
Jan 04, 2009 | Maytag HYE3657A Electric Dryer
The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
May 23, 2007 | LG DLE2512W Electric Dryer
Samsung 7.3 Cu. Ft. Electric Dryer Logo
613 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
