Question about John Deere Garden
How to change ignition coil on an lx255 john deere
wadembly
  • 489 Answers
SOURCE: No spark
did you make sure the gap was set right on coil & flywheel it should be .020 between magnet on flywheel & the coil & the same thing with the points in the open possition between points & condensor
Posted on Jun 08, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
chad7houston
  • 62 Answers
SOURCE: john deere lt120 , 2004
My bet would be a saftey switch. On most riding mowers there are several switches that must be actuated before it will start. First, make sure that blades are disengaged. If there is a handle that engages and disengages them, you might try holding it in the dis-engage position in case the switch is out of adjustment. There is probably one under the seat also. This switch kills everything if you are not sitting in the seat for safety reasons. Also, make sure the parking brake is set, and the gear is in neutral, and not forward or reverse.
Hope some of this helps.
C
Posted on Oct 08, 2008
  • 69 Answers
SOURCE: HAVE A JOHN DEERE 318 LAWN TRACTOR, CHANGED POINTS
Check the coil impedance on the primary and secondary side. You'll have to disconnect the battery negative cable so you don't short something out. Unplug the spark plug wires and the two sets of smaller wires connected to the primary side of the coil. The primary coil reading should be between 3.7 ohms and 4.6 ohms while the secondary (spark plug side) should be between 34.2 k-ohms and 41.6 k-ohms. If the resistance values you measure are outside of these ranges, you need to replace the coil.
Posted on May 19, 2009
SOURCE: John Deere LX255 PTO stopped
My John Deer LX255 will not engage the blades unplugged yellow switch and cleaned spades. What should I do next?
Posted on Sep 03, 2010
Does a John Deere model LX279 only have one belt
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
JOHN DEERE LX255 LX266 LX277 LX277AWS LX279 LX288 LAWN GARDEN TRACTOR...
Apr 27, 2017 | John Deere Garden
Where is the spark plug located on a john Deere lx255?
I could be wrong but if your mower has an engine it would located screwed into the cylinder head.
Apr 26, 2015 | John Deere Garden
LX255 JOHN DEERE MOWER BLADES WILL NOT ENGAGE WHEN I PULL ON THE KNOB NEXT TO THE STEERING WHEEL.
Probably out of adjustment or the cable control, on some models, has stretched.
Sep 21, 2014 | Acer Aspire 5610-4648 Notebook
No spark one plug f725 john deere
Did you replace the IGNITION coil or the "PULSING coil"? There are two different types on that engine. The ignition coil makes the high-voltage spark, the pulsing coil is a sensor that tells the ignition control module when to tell the ignition coil to make that spark. The pulsing coil is pretty inexpensive on eBay.
If you change both the ignition coil and the pulsing coil and the problem still persists, you may need to replace the ignition control module.
Unfortunately, they don't make these things simple any more, or easy to troubleshoot.
Jul 30, 2014 | John Deere Seat For F710 F725 F735 Riding...
Where can i find a free john deere lx255 owners manual?
Don't know for free, but I found it on amazon, so take a look if you want.. here: Amazon com john deere lx255 manual. I hope this was helpful. Have a nice day
Apr 22, 2012 | John Deere Garden
Apr 21, 2010 | Garden
Garden Logo
854 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
