I bought a 2GB DDR3 board with a gold colored metal cover. Should this be removed when I install the memory? No mention is made in the instructions about this metal cover and the tag says "warranty void if removed." The gold cover appears to be glued onto the memory board!
  • 119 Answers
This is a heat dissipating shield and should be left on the memory.
Posted on Aug 26, 2010
HP pc 1 short beep 1 long beep?
https://support.hp.com/us-en/document/c02222922
is the coin cell , 3v? or 2v , 2.9v and up is good, lower not.
the memory rules on all PCs is complex , just because it fits means nothing.
2010 PC DT
windows 7 32bit?
do all PSU voltages read correct with a voltmeter?
they must be in spec,.
memory
240pin DDR3 DIMM 800MHz Memory
low density only maybe a limit here.
so you want 8GB up
2GB per slot.
there are 3 kinds on voltage alone, low, high and both
then speed,
sure forum factor DDR3 240s
but there are density limits and socket max limits and system max limits
if running windows 7, 32bit its limited to 3.5? GB.
so 8 is a waste there.
if running windows 7, 64bit then it can use full memory.
if the bios allows it
and the Processor MMC chip allows it.
see? there are complex limits on all PCs.
in this case AMD processor.
Athlon II X4
limits on this mobo are.
HP spec page
Supports 1 GB, 2 GB, and 4 GB DDR3 DIMMs per socket
  • Supports Dual channel memory architecture
  • Supported speeds
    • PC3-10600 @ 1333 MHz*
    • PC3-8500 @ 1066 MHz *DDR3-1333 modules run at 1066 MHz if three or more modules are installed.
  • Non-ECC memory only, unbuffered
  • Supports up to 16 GB on 64-bit PCs (DIMMs run at DDR3-1066)
  • Supports up to 4 GB* on 32-bit PCs
so what memory did you buy, and from whom.
name make model numbers exactly.
I think its coin Cell bad
or PSU bad , not memory.
if one stick fails its not that stick if
you now are buried in sticks, if all sticks fail in just slot
its not memory prob. its power.
for sure all original stick fail as one.
Mar 04, 2017 | HEWLETT-PACKARD Pavilion p6514f PC Desktop
I want to install 2GB 204-PIN DDR3 Ref: CT25664BC1339 in my Notebook
From looking at your specs you have 2GB of memory: 2GB DDR3 System Memory at 1,066MHz (2GB x 1) and you unly have 1 DIMM Slot?
Nov 09, 2012 | Samsung N102s 10.1 Inch Laptop - Black...
Having problems upgrading my GatewayDX4840-11e to 32GB of memory.
Memory Type: DDR3 PC3-10600, DDR3 PC3-12800, DDR3 PC3-8500, DDR3 PC3-14900, DDR3 (non-ECC)
Maximum Memory: 32GB
Slots: 4
Each memory slot can hold DDR3 PC3-10600, DDR3 PC3-12800, DDR3 PC3-8500, DDR3 PC3-14900 with a maximum of 16GB kit (8GBx2) per slot.*
*Not to exceed manufacturer supported memory.
Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
How much memory your Windows OS will recognize depends on which version of Windows you are running. To utilize more memory, install a 64-bit version of your OS.
Thank You
TomMiller
Eng
Aug 19, 2012 | Gateway Desktop / Intel Core i3 Processor...
Installed additional RAM on HP P6531p desktop, computer freezes on start-up. Using Kingston DDR3 SDRAM DIMM PC3 10600 @ 1333mHz 2GB. Computer starts and runs fine with 2 sticks installed, but freezes with...
You may have tried to put too much memory (RAM) onto it.
That models maximum spec is:
Memory upgrade information:
  • Four DDR3 DIMM (240-pin) sockets
  • Supports 1 GB, 2 GB, and 4 GB DDR3 DIMMs per socket
  • Supported speeds
  • Supports up to 4 GB on 32-bit PCs
You can find the specs and troubleshooting help files here
Jul 20, 2011 | HEWLETT-PACKARD Pavilion p6531p-b...
Add memory to lt2802u netbook.I am A+ certified.
Memory Type: DDR3 PC3-10600, DDR3 PC3-8500, DDR3 (non-ECC)
Maximum Memory: 2GB
Slots: 1
Each memory slot can hold DDR3 PC3-10600, DDR3 PC3-8500 with a maximum of 2GB per slot.*
Here is a youtube video for how to .. http://www.youtube.com/embed/J-WB0SdfEnk
Jul 08, 2011 | Computers & Internet
MSI H55M-P31 board & having 2 2GB DDR3 modules and I7 Processors, installed memory on dual channel and sytem beeps 3 time and no display
Depending upon which BIOS make is installed in your computer, 3 beep means RAM fault.
Check the specification of your motherboard for the recommended RAM.
Reseat the RAM nodules in the motherboard.
Remove the RAM and get them tested at your friendly computer repair shop.
Sep 24, 2010 | MSI H55MP31 LGA 1156 Intel H55 Micro ATX...
2G memory card not working
If the original memory card (RAM Stick) is working, then it just means two things; either the 2GB memory card is defective or incompatible with your system. Incompatible means the type is not for your motherboard or the 2GB is more than what your computer can handle. You dont need any drivers for your memory card (RAM).
Try to install a 1GB first and check if it is working. make sure the type (ddr,ddr2,ddr3) is the same as the original and the Bus speed (3200,667,800,etc.) is the same as well to eliminate incompatibility errors.
Hope this helps.
Jul 15, 2010 | Toshiba Satellite L305D-S5874 Laptop
Are OCZ PC3 1333 ddr3 1.65v memory compatible with
Intel's web site for the board has the following:
The Desktop Board supports the following memory:
  • Four 240-pin Double Data Rate 3 (DDR3) SDRAM Dual Inline Memory Module (DIMM) connectors with gold-plated contacts arranged in two channels
  • 1333/1066 MHz DDR3 SDRAM interface
  • Support for single- and dual-channel memory interleaving
  • Unbuffered, non-registered single- or double-sided DIMMs with a voltage rating of less than 1.6 V. Using a DIMM with a voltage rating higher than 1.6 V may damage the processor.
  • Non-ECC DDR3 memory
  • Serial Presence Detect (SPD) memory only
  • Up to 16 GB maximum total system memory
You need to contact TigerDirect and have them change out the memory for sticks that meet the above specs.
Jan 25, 2010 | Intel Computers & Internet
Need instructions on how to upgrade to 2GB...
Hello
No , you dont have to backup anything or reinstall anything when you perform a memory upgrade.
Look at the bottom of your laptop , there should be several covers. Consult the laptop manual which ones the memory cover (or just guess they are generally credit card sized/shape). When you have removed the memory cover , there should be a release lever either side of the existing memory module , which you can release and the stick just pops up gently for you to slide out. Then its just a matter of sliding the other one in and clicking the levers into place!
If you found this solution helpful , please rate my solution below
Kind Regards
1234s282
Jul 01, 2009 | Toshiba Satellite A135-S2276 Notebook
Why won't my computer boot?
phill-29
To solve this problem at first clear CMOS by removeing CMOS battery then replace ur CPU.
if it not solve ur problem then check ur bios verson 1002 or not if it 0940 then update ur bios. u can download this update file from this link: http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5E3
Jul 03, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
