Question about SmartParts (1DPFSP01) Digital Picture Frame
SPX8E frame turns on but only for about 12 seconds. Not long enough to get into menus and reset factory settings. Is there any way to do that via PC connection?
  • landisa972 Aug 26, 2010
    the desktop software only does picture management, and leaving it unplugged for 24 hrs hasn't fixed the problem.
  • John Everlasting
    John Everlasting Dec 25, 2013
    you have to go in the menu to turn the light sensor off. to do that put a flashlight or bright desk light on the sensor element at 1.5 inches to the right of the menu exit button. that will keep it from shutting off when going into the sensor setup menu to turn that feature off. otherwise use the unit in a bright room all the time. It was meant to shut off when u turn the light off to go to bed.
  • 10,594 Answers
It seems your photo frame got problem in internal sub power supply section that is why it turns off after a while for some reason.
Visual check is required to find out any voltage regulator might stop functioning after heating up, local tv repair shop will help you to rectify problem.
I'm afraid it is not user level fix nor issue can be resolved by resetting it on default factory settings. It sounds hardware problem that turns off photo frame and technician can look in to it.
Thanks.
Posted on Aug 26, 2010
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Aug 26, 2010
    Correct, that is why diagnosis says photo frame got hardware problem and most probably in sub power supply section on its main board.
    A technician can inspect its circuit board to check regulator chips that might got failed and causing problem.
  • macshoppe Sep 29, 2010
    Try turning the unit on in a very brightly lit room. Mine did the same thing and I realized that the light sensor setting (that turns it off in low light) is set to ON by default. I am not sure where the sensor is, but it seemed to work better when I had the back towards the light. Then I was able to get in to the settings menu and turn off the light sensor.
  • John Everlasting
    the light sensor is 1.5 inches to the right of the menu/exit button when viewed from the back
  • 4,924 Answers
I di not think that you can have access from the computer to the settings ..but if it has a manager for it .....the thing to try is to remove any power source from it ..ac adapter ..batteries all...and leave it like that a few minutes..than power it up again and see if the settings that caused that are gone..
Posted on Aug 25, 2010
How can i reset factory setting on my sony dsc55 camera
Reset button on the camera
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Initialize or Reset option(s) in the camera menus
  • The menu layout is different between cameras so check the operating instructions.
  • In general, there will be a Reset or Initialize section within the menus of the camera.
  • Some cameras allow for resetting or initializing different options such as wireless settings, the settings used in taking the last picture, or all settings. Be sure to look at all available options in the product manual.
Manual reset process
Cameras manufactured prior to the year 2000 do not have reset buttons or options in the menus. Follow the steps below to reset:
    1. Turn off the camera.
    2. Remove the battery pack.
    3. Remove the button-sized lithium battery.
    4. Allow the camera to remain without power for 30 seconds.
    5. Reinsert the button-sized lithium battery.
    6. Reinsert the battery pack.
    7. Turn on the camera.
NOTE: If your camera is experiencing an issue and it is not resolved by performing the appropriate reset or initialize procedure above, service may be required.
Jan 06, 2015 | Sony Cyber-shot DSC-W55 Digital Camera
Factory reset for HP 2000 running Windows 8
a clean wipe of the partition and reset can be accomplished in the Bios functions, simply go into set up at boot and move through the menus until you achieve your goal. HP is well known for installing ghost partitions on their hard drives .
Jun 06, 2014 | HEWLETT-PACKARD Hewlett Packard Techno...
Factory reset
In camera settings menu, on the bottom of the screen you find Settings. In Settings is the only reset the camera knows. You only will reset the menus and shooting options. Date, time, language and video output settings are not reset.
If your camera has serious trouble, accessing menus or something like that, there is nothing like pressing a button for several seconds and everything will be ok. (not in the manual)
Dec 08, 2013 | Samsung ES30 Digital Camera
Reset printer
Please print printer settings configuration page. The page will explain the printer menus and change values. Menus are represented by Continue, Ready/Data, Toner Low and Load/Remove Paper light sequences. Menu Items and their values are indicated by Paper Jam and Error Light sequences
Here are the instructions to do that:
1. Turn off the printer.
2. Open the front access cover
3. Press and hold the red Stop button while powering up the printer.
4. The lights should cycle, release it when the light stops cycling.
5. Close the cover once the ! light displays
6. The lights should cycle again.
7. Then press the Continue button.
8. This should print a Printer Diagnostics page.
9. On the Printer diagnostic page, Use the Utilities menu to troubleshoot printer problems
- Return the printer settings to factory default values.
- Sometimes resetting the printer to the original settings solves formatting problems.
- All menu items are reset to the factory default values except:
- All settings in the Parallel menu, Network menu, and USB menu.
- All downloaded resources (fonts, macros, and symbol sets) in printer memory (RAM) are deleted.
- Resources in flash memory are unaffected.
10. Please locate the value that would say "Factory Defaults".
11. We would need to follow the exact light sequence that you see for the "Factory Defaults".
12. Press and release the Cancel button to advance through the menus and the menu items to the one we would need.
13. Press and hold the Continue button until all the lights cycle to save the function/value.
14. Restart the printer.
Jun 16, 2011 | Lexmark E260dn Laser Printer
The application is locked
Are you locked out of your router? If so put a pin in the reset switch and unplug the router for 12 seconds while keeping the reset button pushed in. After 12 seconds plug it back in and when lights start to turn on release the reset button. It should be back to factory settings.
Apr 15, 2011 | Computers & Internet
How do i perform a cold reset on a laserjet 2600n printer
Via the Control Panel: The Resets menu makes it possible to reset factory settings, disable and enable Powersave, and update the printer after new supplies are installed. Configure device menu The Configure device menu makes it possible to change the printer's default print settings, adjust the print quality, change the system's configuration and I/O options, and reset the printer's default settings RESTORE FACTORY SETTINGS :Makes it possible to clear the page buffer, remove all perishable personality data, reset the printing environment, and return all default settings to factory defaults. Press Menu or (Select) to enter the MENUS.
  1. Press (Down Arrow) to highlight Configure device menu .
  2. Press (Select) to select Configure device menu
  3. Press (down arrow) to System setup menu
  4. Press (select) System setup menu
  5. Press (select) Resets menu
  6. Select RESTORE FACTORY SETTINGS.
Dec 03, 2010 | HP LaserJet 4600dn Color Printer
Can't transfer music (audio) to the Frame
Make sure the music is in the correct file format for the frame. Some frames take MP3, others take WMA. If the format that you have is not compatible, you must convert it or the frame will not read it.
Jan 29, 2009 | SmartParts SPX8 Digital Picture Frame
I would like to know how to reset the settings on the SPX08 smartparts digital frame. It currently only turns on for approximately 5 seconds and then automatically turns off. Thanks.
I had the same problem with an SPX08E. It turned out that enabling the auto light sensor was the cause!
The way I fixed it was to remove all memory cards and attach the frame via USB to a PC. Then use windows explorer to delete all folders and files on the frame other than the smartpix installer MSI. Then remove the USB and power cycle the frame. It will come up at the main menu and you then have about 15 secs to navigate to the settings page, scroll down to the reset settings tab and reset all settings to defaults. You can then transfer any pictures you want back to internal memory.
Do not turn on the light sensor or you will have to do it all over again!
Dec 07, 2008 | SmartParts SPX8 Digital Picture Frame
Reset Default Settings
Hi
with the unit ON press and hold for at least 5 seconds the power button, you will see the clock goes to 12:00
This procedure will reset the unit to factory settings
Jul 06, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
SmartParts (1DPFSP01) Digital Picture Frame Logo
399 people viewed this question
Top SmartParts Photography Experts
Tony
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a SmartParts Photography Expert? Answer questions, earn points and help others
