Question about Hotpoint WMA13 Front Load Washer
Washer stopped dead in the middle of cycle
Hi. We have a hotpoint wm62. it is 9yrs old but has been in storage for the past eight years. We installed it a mont ago and it has been working beautifully up until today. We turned it on to wash (1 light blanket and two shirts). Didn't think I overloaded it. It has stopped in the middle of cycle with everything sitting in water. I took everything out, gave it time, checked the plug and replaced the fuse. What else could it be? Thanks
  • 975 Answers
CHECK ALSO the sensor switch underneath where the door close , you gonna need a tester for this task ,hope this helps AJ
Posted on May 05, 2008
Hi there, My washing machine is hotpoint WTL500
My washing machine runs for 10 minutes then all the lights start flashing also there's water in the drum, I've drain the water twice but it does the same thing.
Any idea what's going on there pls.
Aug 11, 2013 | Hotpoint Aquarius WMA42 Front Load Washer
We can do an entire load of wash and when finished often the items in the middle are dry not even wet , we do not over load weve been using this for eight years and this started in the last 6...
This sounds as if not enough water is fed in for any cycle, wash or rinse. I suspect the water level sensing is not doing its job properly and that there has been only a little water in the drum each time for the past 6 months!
Sorry but you will need to call a service engineer as there is nothing that we could do remotely to help ;-0(
Good luck,
John C
Mar 15, 2011 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint WMF940 Washing machine - 11 months old. The cycle times displayed do not represent the actual times. No 5 cycle takes over 3 hours. The other displayed cycle times are similarly not...
If it is indeed less than a year old, then I recommomend you contact Hotpoint direct as the washer will still be under the years guarantee,and you should get a call free of charge
Check with Hotpoint at the web address below.
They should be able to help you.
Jan 03, 2011 | Washing Machines
I have a bosch washing machine make is a exxcel 1200 express and it stops working in the middle of a cycle and the words f04 come up wot does that mean please
there may be a stuck in cycle of rotating knob kindly rotate the knob more than three times your problem will be sloved otherwise replce the mechanism
Dec 23, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Whirlpool washer-dryer has stopped washing
Remove the pump system like this off the Hotpoint wd640 . Remove any blockage inside and retry.
Nov 10, 2008 | Washing Machines
No power??
It's more than likely its the door lock, if not check the timer contacts on the top front connection block, if they have blown it will need a timer & door lock
Nov 02, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint F-01 Error code
my washing machine is 2 years old, hotpoint wt761p showinf f-01. it hasnt finished it cycle. turned off by mains to open the door and get washing out.
please help!!
Oct 12, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Washer
cutting out in cycle could well be just the door interlock
however on delicates and wool programs, the machine stops still full of water and you then have the choice of drain or spin. many people confuse this and think it is a fault. price of £50 is about right
Sep 09, 2008 | Hotpoint Washing Machines
No longer rinses or fast spins...although drum does go round slowly... My WMA 13 First Edition Hotpoint has stopped fast spin, so although the drum does go round, it does not speed up to a fast spin at...
LETS check the DRAIN MOTOR PUMP it could be clogged , open panel of washer to access inside , look for a small motor with 2 hoses connected to it , take it out , clean it , re install and try it again , hope this helps AJ
Apr 14, 2008 | Hotpoint WMA13 Front Load Washer
Hotpoint WMA13 Front Load Washer Logo
140 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
