Question about Onkyo TX-DS555 Receiver
My onkyo receiver wont play music loud, I can turn it all the way up and faintly hear some music, how can I fix this? The speakers are hooked up, but there is no sound, the receiver model is txsv373...
  • 4,234 Answers
The most common cause of this is having the unit with the tape monitorswitch turned on. Check that first. If that is not the problem, the next likely problem is in the power supply. The output section is missing its main voltage. This will require professional assistance.
Please try the tape monitor first and update this with the results.
Dan
Posted on Aug 25, 2010
Onkyo tx sr502vreceiver wont send sound out when trying to play a cd. Hooking up to samsung smart tv that has no s video or optical output connections. HELP ! ! !
Hi Denni, the TV should not be a factor. Is the CD player connected to the receiver. It should be playing out the receiver speakers. Thank you, Onkyo USA
Nov 30, 2016 | Onkyo Audio Players & Recorders
Speakers and headphones do not work
Sadly this could indicate that the main power amp has failed. You should try turning it up really loud with some music playing. If you can hear it very faint, then the main amp has failed. If you can hear hum, then the pre-amp might be the cause. The only other cause is that the headphone socket has broken, cutting off both speakers and headphones.
Aug 06, 2013 | Onkyo Audio Players & Recorders
I recently moved and just got my outdoor speakers hooked up. When I turn on Zone 2, I get sound from my Ipod, but when I set Zone 2 to have music play from my satellite box, I get nothing. The music will...
If your satellite box is connected using a digital cable to the 601 receiver you won't get any sound through zone 2.Zone 2 can process only analogue sound ( inputs ).
Jul 06, 2011 | Onkyo TX-SR601 Receiver
How to hook up my subwoofer
It sounds like you're doing everything right. Did you define the sub to the Onkyo (Subwoofer = Yes, page 22)?
Let's prove the sub works. Set its volume about half-way, cutoff= 170Hz. Temporarily connect an RCA cable from its Line Input to one of the Tape Out connectors on the Onkyo and play some FM through it. If it's alive you'll hear the low end of the music.
Don't buy into the hype that there are different pedigrees of RCA (or speaker) cables that will make an audible difference. Save your money.
May 04, 2010 | Onkyo TX-DS696 Receiver
I have an Onkyo TX-605AV receiver that will goturn off andgo into standby mode with loud sounds, when the volume is turned up usually over 60. I hooked the speaker wiresinto the banana clips for the...
over heating your amp with a problem and its going into the protect mode... better stop before it dies for good...$$$ to fix....speakers mismatch or wrong ohm rating for starters bad speaker, bad xover...
Dec 05, 2009 | Onkyo TX-SR605 Receiver
How do I connect my outside speakers to play?
The onkyo should still have a speaker A/B selector in the menu.
Check on the back panel for speaker A/B.
If it has or you decide to use Zone 2 you will need to set the sound programme to "stereo" so the rears and centre do not work.
You can still use a digital source.
You should be able to display the amp's menu on the screen.
Hook up "monitor out" (Yellow) via RCA connector to one of the "A/V inputs" (yellow) on the tv, this will show you a display of the menu and will make it eaiser to navigate.
Jun 16, 2009 | Onkyo TX-SR705 Receiver
Onkyo TX-DS939
I have to ask the obvoius, did you get the manual, have you used the onscreen menu to set up the speakers, you can calibrate the speaker levels on the TV screen if you use the S video or RCA vidoe connection .have you turned off tape monitor?
Apr 27, 2008 | Onkyo TX-DS939 Receiver
My Onkyo Receiver TX 601 is turning itself off
Several things can cause this: Loud signal passages can momentarily draw high currents at the mains, especially if you have unit plugged into power stripe with other equipment. Or if unit is plugged into isolation transformer, current draw may exceed output of transformer. Too many speakers hooked to output or if one is bad (partially shorted due to overheating)
Apr 04, 2008 | Onkyo HTR500 Receiver
258 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
