Question about Panasonic KV-S3065CL Path-Through Scanner
Hopper on Panasonic KV-S3065CW scanner will not drop to load position when it is idle. the only time the hopper drops is when there is a double feed or paper jam. I've cleaned all sensors and everything else seems to function properly
  • KJ Saks Feb 15, 2011
    it was the Hopper Home Board
    Part #
    PJLPCOOO4YA-h
    PPB747ADF05H
Try replacing the ribbon cable in the paper hopper.
Posted on Sep 24, 2010
  • KJ Saks Sep 24, 2010
    DUH! I posted the problem over a month ago.
    Your solution WASN'T the fix any ways!...
    NOT EVEN CLOSE!
  • cwhuling Feb 15, 2011
    I am having the same problem, what was your solution? We have cleaned the sensors and blown out all the dust and dirt we could find.
KV-S3065C has a error F40
You have to replace under the hopper cable part number PJJEC3437Z and board part number PPB747ADF25H from www.part store.com this will take about 2 hours to do because of the covers you have to take off.
Oct 24, 2016 | Panasonic Kv-s3065c Scanner
Why Oki b4600 after changing drum devolves toner empty
The toner cartridge is only a supply chamber. The cartridge simply dumps toner into the feed hopper in the drum. When you change the drum the feed hopper is empty and it is likely that the cartridge dropped the last of it supply into the hopper - ergo it is now empty. I recommend shaking the toner back into the cartridge before separating the cartridge from the drum unit when changing them
Sep 08, 2014 | OKI B4600 Printer
Feed hopper wont rise up no error
Please contact Kodak Service & Support - 1-800-822-1414. This problem requires field support.
Mar 20, 2014 | Kodak Ngenuity 9090 Db - Document Scanner...
My fi-5220C says No paper on ADF paper chute or Hopper. (Code: Ds32003)
"No papers on the Chute unit" error occurs when the Hopper empty sensor detects no paper loaded on the Chute unit at the receipt of a Feed command.To recover this, Load documents on the Chute unit.
1. Does the same symptom occur after turning OFF and ON the scanner? Press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2. Is there a slip of paper left near Hopper empty sensor? Open the ADF and check inside visually.
3. Check the performance of Hopper empty sensor. Conduct Maintenance mode to see if the sensor works properly.
If the error still occurs, confirm that the cable is correctly connected then replace the sensor EM.
Thanks & regards,
ScanCare
Oct 02, 2013 | Fujitsu Office Equipment & Supplies
U8 detail 61
U8 is the ADF Set-up Error. This error is displayed when Pick roller unit is locked in the upper position, release(lower) the Pick roller unit to resolve the error. Secondly, if the hopper is over loaded, reduce the document load on the hopper.
Hope the above information is helpful.
Thanks,
Scancare
Dec 21, 2011 | Fujitsu fi-5900C Pass-Through Scanner
Beans grind, but nothing comes out. says it's out of coffee. works fine with the "pre-ground" setting. Fairly new machine.
Hi
First try turning the big knob in the bean hopper to 18, then the small knob to the minus -. If that doesn't work you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the backside of the drop chute.
Once that is cleared go to the bean hopper. There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on before, but only when the grinder is running. Turn the small knob up to the + then back 1 mark for a strong coffee.
This is what it looks like when it says out of beans and there are beans in the hopper bansheracer_12.jpg
Jan 26, 2011 | Saeco V-spresso Espresso Machine
Panasonic scanner kv-s3065c error code f40-30000000 hopper error ocurred in scanner
F40-30000000 Solution You have to replace under the hopper cable part number PJJEC3437Z and board part number PPB747ADF25H from www.partstore.com this will take about 2 hours to do because of the covers you have to take off.
Apr 06, 2010 | Panasonic Office Equipment & Supplies
Solis master 5000 beans get hung up in hopper. machine says no beans, lift lid to find hopper is still full, poke finger into pile to release hang-up, is this normal, should I try to remove small cover...
The coffee that you are using might be very oily and not able to slide over the cover. DO NOT REMOVE THE COVER. Try finding another blend that is not as oily or clean the bean hopper more often.
Oct 06, 2009 | Coffee Makers & Espresso Machines
Cant slide the card hopper in the back of my magicard rio 2
Hi There,
Just go to the following web site;
http://www.magicardonline.net
Enter your printer's serial number in the QuickSearch box.
At the bottom of the search results you fill find a useful video tutorial called 'Loading cards'.
The trick is the hopper has to be offered up to the rear of the printer at a 45 degree angle, then as bottom of the hopper engages, tilt if forward and it will drop down into position.
Like you say, I am assuming that you have the correct hopper, but you will see the correct hopper on the video!
I hope this helps.
Regards,
MC
Feb 26, 2009 | Magicard Rio ID 2 Card Printer
Panasonic KV-S3065CL Path-Through Scanner Logo
586 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
