Question about DISH Network 135899 Remote Control
I have my remote but it will not let me turn on my Sat. so all i have is a screan with the dish network thing going around it. How can i make my remote work again?
    Novelist:
    Champion:
  • DISH Network Expert
  • 286 Answers
Becki Barned with Dish Network customer service here. This may have been resolved already, but if not, and if you want info for later, here's some steps! Your remote needs to be readdressed. Try these simple steps. And make sure your batteries are less than 60 days old! http://www.dishnetwork.com/SupportSection/remote-control
Posted on Dec 25, 2010
Dish Network controller doesn't work if you happen to pause or stop when the screen is black or on a dark picture. You have to turn TV and control box off then back on to regain controller.
falcondan
The remote works fine other than this stated problem? What type receiver and TV do you have? Do this just began occurring? Have you checked the batteries to make sure they are fresh? Is this on TV 1 or TV 2? One thing you may try is readdressing the remote to the receiver.
Remote: All Other Remotes
  1. Go to System Info screen (press Menu button 2 times on remote).
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button.
  5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Jun 25, 2011 | DISH Network IR Remote Control
MY dish remote is installed with the dish receiver. My dish remote though is not changing the channels. I already changed the batteries and it turned out to not be that. So what do I do?
Tierra_bush,
It's possible the remote may just need to be readdressed to the receiver. I've listed the steps below:
Addressing remote
1.) Go to System Info screen.
2.) Hold down the SAT button until all mode lights light up.
3.) Enter a number between 1 and 15 using the numeric keypad on the remote.
4.) Press the pound (#) button.
5.) Once the SAT button blinks three times, press record.
6.) Try the remote and see if it is working.
Let me know if you have any other questions!
Tommy Faust
DISH Network
Apr 12, 2011 | DISH Network ViP722 DTV Receiver /...
My dish network duel feed remote will quit working the dish reciever after about 15 miniutes or so,however it will still turn tv on and and off. if I shut the reciever down for a while it may or may not...
Hi pappy63my name is Mike Houston of DISH Network and there are some steps that will getyour DISH Network remote to change the satellite channels. The first thing youwill need to do is press the System Info button on the receiver or pull out thesmart card from the receiver, with the remote press and release the SAT buttonand press the Record button and you will see the number in the white boxchange. I will leave a link to help with these steps. http://www.dishnetwork.com/SupportSection/remote-setup
Feb 11, 2011 | DISH Network IR Remote Control
Dish Network IR Remote's SAT Mode Not Working ________________________________________ I programmed my Dish Network Remote (IR 1.5 Blue Button Remote Control ) for my Sharp 27F543 and now the remote would...
Hello, this is Nick Franta with DISH.
If you are trying to get the remote programmed to the receiver you can remove the smartcard from the receiver and that will prompt the system info screen. This will allow you to program the remote to the receiver.
If you need the process for programming the remote, here it is:
  1. Go to System Info screen (in this case -- obtain by removing smartcard from receiver)
Hope this helps!
Jan 01, 2011 | DISH Network IR Remote Control
The tv is jammed. Remote is fine but have pressed the wrong button
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux modes. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is in fact the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with!
-Kirstie DISH Network
Oct 01, 2010 | DISH Network IR Remote Control
2nd television remote control is programed and it work for turning on and off but the other butttons don't work, like the sat button or arrows to pick different channels doesn't work. I appricate it thank...
Have you tried pressing SAT and trying the remote again? If not then you may need to readdress the remote.
To do so:
1. Access System Information from primary TV.
2. Note the number on bottom by Second Remote Adress
3. Hold SAT until all lights on top of the remote light up.
4. Let go and it will be blinking, enter a number between 1-15 and press #
5. Press record 3 times and the number found in step 2 should change to the one you selected.
Tommy Faust
DISH Network
Sep 21, 2010 | DISH Network IR Remote Control
My dish network remote stop working
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux mode. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with! -Kirstie DISH Network
Mar 11, 2010 | DISH Network IR Remote Control
Sat button won't illuminate nor operate
Hi jscot myname is Mike Houston of DISH Network and I was going over your post and thereare a couple of things we can check. The first is to replace the batteries andafter the batteries are replaced push and release the SAT button and press select.If the SAT button did not light up the remote would need to be replaced.
Dec 30, 2009 | DISH Network IR Remote Control
When i turn on the tv it goes to a Dish Screen when i push select it doesnt do anything
I most likely need additional information to ensure this is in fact the correct resolution to your remote issue- but it sounds as though the remote may be in tv mode. If this is in fact the problem, then the remote simply needs to be put into "SAT" mode, which will enable you to be able to press select to proceed past the DISH Network screen. The "SAT" button is labeled & in the upper left hand corner of the remote just press SAT once and then release, the button should briefly light up red & then will go off, you can then press select and as long as the SAT button lights up when you press select or any other button on the remote then your all set to go! I hope this helps -please let me know if there is anything else I can help you with! -Kirstie DISH Network
Sep 29, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Programing dish network remote control for aiwa av-x220
You will have to call Dish Network.
800-825-2557
Feb 22, 2008 | Aiwa AV-X220
DISH Network 135899 Remote Control Logo
87 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
