Question about Sharp R-530BS Microwave Oven
Maytag MMV1153BAW interior access panel
There is an interior access panel inside the microwave. It is a round plastic panel with type (OPEN, CLOSE) arrows that tells you which direction to turn the panel to open it. There is a small plastic tab (about the size of a thumbtack) that holds or locks the panel in place. That small tab broke and I've fixed it temporarily (until I get a new plastic tab). What is the purpose of the device (a round metallic disk looking thing that apparently rotates) inside the panel? When I put it back together a spark arched out of that panel, but then everything seemed fine. I'd like to know what it does and if I should stop using the microwave for now. The MW seems to be working just fine. Thank you. DPN
  • DPN5245 May 05, 2008
    Moved to Maytag product board
  • Sharp Master
  • 9,098 Answers
This is the stirrer cover. It is important. It is to keep food particles and grease out of the stirrer and waveguide area.
If grease or food particles build up, they can arc, which will cause burn damage to the cover, stirrer, chassis, and/or magnetron.
If you have any arcing, you should remove it for cleaning. Be careful of sharp edges.
The stirrer's job is to stir the microwaves to ensure even heating, even when a turntable is not present or not used.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 09, 2008
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Maytag MMV1153BAW
Nothing on keypad for my microwave works
Be very careful around microwaves they have very high voltage inside them that can be deadly. As for the control panel its very common for grease and oil to get behind the plastic film of the control panel, once it does the buttons will stop working since the grease insulates the contacts. Unplug it from the power, let it sit for 60 minutes to make sure all power from the high voltage caps has dissipated. Get access to the back of the control panel. You will probably have to peel back the control plastic on the front to get behind it. One behind clean all the buttons and contact areas. Reassemble, and it should work.
Aug 10, 2014 | LG LMV1630ST Microwave Oven
Maytag microwave model mmv1153baw light won't shut off and won't start
Either the latch in door (spring related) is not in the correct location or you have a door switch issue and its not expensive to fix if you husband is handy. Part number you can use is 28QBP0495 or the factory one 3405-001034 (more expensive). This issue is common and these switches are located inside the control panel on the left side, the switch you seek is the lowest one in the bracket of three. Good Luck and I hope this helps.
Apr 20, 2014 | Maytag Microwave Ovens
No power on microwave. model mmv1153BAW. is it broke
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 07, 2011 | Maytag Appliances Over-the-Range Microwave...
My maytag microwave lost power
There is always a fuse inside a microwave.Sometime this has only blown due to a surge,and upon replacing, the microwave will continue working.If it is something worse the fuse will continue to blow.In this case it could very well be the transformer,but there are other possible causes as well.(for example the control board or a short.)
Jun 24, 2009 | Maytag MMV1153A Microwave Oven
Timer runs fast, plus no heat Maytag MMV1153BAW
No... you are not in a microwave induced time warp...
Your microwave oven needs a "reboot". The same thing happened to me.
Unplug your microwave oven, wait about a minute (more or less), plug it back in. Try setting/running your kitchen timer, boil water, etc. Your timer software on the microwave should be reset.
Jun 14, 2009 | Whirlpool MH7135XE Microwave Oven
Need to know how to remove the control panel to check the fuse. Will not run, push start, beeps three times and light is not working. Please help us!
the fuses for microwaves are not normally placed on the control panel...they are in the back near the power cord...but the fact that it beeps 3 times means the fuse is ok...power is going in....most likely, the fault is one or more of the door interlock switches which arc every time you open and close the door and they corrode or wear down very badly sometimes even burn away so that there is no more contacts to come together....interlocks are cheap to buy and they just snap in place....access to them is easy...just remove the cover and look right behind where the door closes on the inside, you'll see a plastic bar on the door that when you close the door...it pushes on the interlock switches on the inside to activate the oven.......if the interlocks are ok...then you probably have a shorted magnetron....very common on any type of microwaves are these 2 parts...( the interlock switches and /or magnetrons.....it's not likely that your control panel is bad unless you physically see that something has burned on it.....good luck
silvio
Jun 03, 2009 | Whirlpool RMC275PD Microwave Oven
Sorry my English, but can u help me?
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally by a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Jul 06, 2008 | Maytag MMV1153A Microwave Oven
Maytag MMV1153BAW
May 05, 2008 | Maytag MMV1153A Microwave Oven
G.E. Spacemaker XL1800- Loud constant buzzing noise. Help
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
Mar 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-530BS Microwave Oven Logo
210 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
