Question about Kenmore Refrigerators
Fan Blade in freezer not moving - Kenmore Refrigerators
  • 86 Answers
Hello
Two things to look for. The fan motor is bad. This happens all the time. Or some thing is keeping the fan from spinning like ice on a frozen coil. If it not iced up yet it will be soon if the unit is running and the fan is not working. I hope this helps. Please leave feedback.
Thanks.
Posted on Aug 25, 2010
Can I simply defrost freezer to solve a grinding noise that stops when I open fridge doors and gets louder when I open freezer doors?
Not knowing the type of Refrigerator, frost-free or cyclic-defrost-
My opinion is, the noise may be generated from the Fan in the Freezer -compartment,
It is mostly situated in the freezer, behind a removable panel at the rear wall, The panel has a grill, or is slotted to allow the cold air to flow.
The fan may be worn out.
You may hear a grinding or squealing sound.
The fan-blade may be touching (striking) something,
The blade may have moved along its shaft and strikes the housing.
It may strike solid ice ,
the ice can form, if there is a fault with the Automatic-Defrost.
You need to confirm if the fan blade rotates freely.
Do you know how to do that?
K. AUS
Mar 11, 2015 | Refrigerators
How do I fix feezer fan noise
ok you must have a freezer full of stuff and its hitting the fan blade move the stuff away from the fan blade
Sep 08, 2014 | Refrigerators
My magic refigerator/freezer condenser fan stops but when I move the fan blade it starts working and the refrigerator get cold again. Is it a bad fan unit or something else?
yes if you can barely touch blade and it stops the fan motor is bad. While replacing conderser fan motor be sure to clean dust from condenser coil.Then as regular maintiance clean coils twice per year.
Aug 12, 2011 | Refrigerators
The feezer side is making a loud noise and will not stop. it seems to still be cooling just fine on both sides. thier is no burning smell or anything. i tried dissconnecting the ice maker and that did...
From what you're describing it sounds like the freezer fan motor is causing the noise you hear. The freezer fan is the only moving part in the freezer section. I recommend replacing the freezer fan motor & fan blade together. If there is ice buildup on the back wall of the freezer then the sound is likely from the fan blade hitting the ice and you will need to defrost the unit.
Jul 31, 2011 | Frigidaire Refrigerators
Hello, we have an RSW2400E. We recently moved and took our refrigerator with us. We left the refrigerator off for 24 hours and then turned it on. The refrigerator does not get very cold and the food in...
This sounds like someone may have knocked the condensor fan motor connector loose or bent a fan blade on the condensor fan in the process of moving it. Open the back of the unit and check the fan blade to see if it turns freely. Clear any obstructions. If there are no obstructions check the connector on the condensor fan motor. The key here you said it was working pre move and post move this statement is a dead give-away for a condensor fan problem: The panel that splits the refrigerator from the freezer is extremely hot. You can most likely fix this yourself.
Thanks for choosing FixYa,
Kelly
Nov 06, 2010 | Maytag Refrigerators
Makes noise stops when freezer door is open
s this sound like a noisey fan . if older model i would replace the fan motor . / other problem could be the fan blade has moved on the motor shaft . so just replace the fan balde .. mm
Aug 10, 2010 | Maytag MBB1956GES Bottom Freezer...
My kenmore bottom freezer has a rattling noise which stops when youopen the freezer. compressor was replaced in october of 09. coils are clean and no loose parts can be seen when back panel is removed.
Check the Fan, and the fan shroud(to make sure they're tight).
There isn,t any other moving part in those freezers.
Could be the fan motor itself making noise, or a broken fan blade, or loose mounting screws...
Mar 04, 2010 | Refrigerators
Light clicking sound from outside whirlpool french
Check the fan blade on the fan in the freezer. It could be an object or ice, frost, anything. If this is an Amana Whirlpool, definitely check to see if the fan blade is no longer tight on the motor shaft and has moved forward and hitting the guard in front of it. ( yes, amana whirlpool )
May 12, 2009 | Whirlpool Refrigerators
Maytag upright freezer model MQU1556AEW
I experienced the same problem last week with my freezer. Apparently the change in temperature during defrosting allows the blade locking mechanism to slide on the motor shaft during the spinning operation. The blade pulls itself along the shaft until it comes in contact with the motor mounting bolt. If your freezer just stops getting super cold, but remains cool and you don't hear the fan spinning, remove the inside back panel and check the fan blades for freedom of movement. I almost disposed of the freezer this past week but decided to make one last check of the mechanisms.
Sep 22, 2008 | Freezers
Freezer fan stopped working
Sounds like you need a new fan motor. First make sure the fan blade turns freely and see if you can move the shaft side to side, or up and down. If you can feel any movement in the fan shaft the bearings of the motor are bad. It is possible for some ice to have the fan blade frozen causing the motor to stall. Some models also have a fan light switch install at a point near the hinge side of the door.
May 02, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
Refrigerators Logo
18 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
