Question about Dell Latitude D600 Notebook
My wife drop the laptop on the floor and since then when i start the laptop it says no boot device found.
  • 2,567 Answers
Two possibilities here:
1. When your laptop was dropped, the connecting between the hard drive & the laptop's motherboard became loose, & as a result the motherboard could not properly detect the hard drive. Solution here is simple: Try removing the hard drive & replacing it back in the laptop & see if this resolves the problem.
2. If the case did not turn out to be as described in point (1), then most probably your hard drive is damaged as a result of the fall. In this case you will also need to remove it off the laptop, but you will have to buy & install a replacement hard drive, & re-install the operating system & all other software.
The document at the following link describes how to uninstall/install a hard drive in your laptop's model:
http://support.dell.com/support/edocs/systems/latd600/en/sm/hdd.htm#1123687
Posted on Aug 25, 2010
My boot devices are disabled
Hi
Normally for Pcs and laptops the booting devices can be found in the CMOS/BIOS settings, when you start up the pc/laptop you normally press esc f1 f2 etc, this allows the user to enter into the CMOS/BIOS setting.
Under the Boot tab you will see all the devices you boot from they will be enable/on or disabled/off check them to see which devices are on and off.
The last tab has a load default option if you select it and exit and save these changes it will automatically enable all the default devices in order.
Your pc/laptop should boot up normally now
Cheers
Apr 16, 2014 | E-Machines eMachines Desktop PC
Clicks when switched on, stops after a while, screen says reboot and select proper boot device or insert boot media in selected boot device and press a key
Your machine can't find the boot sector of the hard drive. This could be because there is a cd/dvd in the drive or the BIOS has the wrong boot sequence assigned.
Nov 04, 2013 | Toshiba satellite c660
Broadcom base code PXE-2.1 v1.1.0 Operating system not found
Go to your laptop's bios and select first boot device as your hard drive. and also disable the other boot devices and boot from network must be disabled. that's all.
Sep 22, 2012 | Acer Aspire 5536-5224 Notebook
Acer aspire 5253 error message no botable device after laptop was dropped on carpet
No bootable device suggests that your Acer Aspire hard disk may have been damaged when the computer was dropped.
You should try opening the cover on the base of the laptop where the hard drive is fitted and check to make sure that the drive is seated firmly and has not come loose with the drop. See the Acer Aspire 5253 Quick Start Guide for the location of the drive cover.
If reseating the drive does not help, then you would need to find any recovery discs that you may have made or received with the laptop plus need to buy and install a replacement hard drive.
Jan 10, 2012 | Acer Computers & Internet
Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Sep 11, 2011 | Dell Inspiron 600M Notebook
My Toshiba Satellite A105 was accidentally dropped on the floor. When I turned it on and after choosing "HDD" from the Boot Menu, the screen would display this: PXE-E61: Media Test Failure,...
Sorry but Unfortunately Hard drives (HDD) are very susceptible to physical shocks and can be damaged that way. It may be possible to take it to a repair center to see if they can salvage some of you data but their are no guarantees.
If you found the information helpful please rate my response.
Aug 07, 2011 | Toshiba Satellite A105 Notebook
My wife found a floor safe in her father's home we are selling, He died last January. The safe has a key broken off in it and I couldn't get it to come out. How or who should I get to open or remove the...
Call your local locksmith and describe your problem, brand name of safe and any other criteria you have like how the safe looks mounted in the floor. He can give it a look or an estimate. Sorry about your loss, really...
Dec 05, 2010 | Safe International Double Door Digital...
Black screen on mu compaq R3000
You can try:
reseating / swapping the memory
booting the computer with the battery out.
You probably damaged the motherboard with the drop.
There are a few other things you can try too, but let's try the easy stuff first.
Jun 17, 2009 | Compaq Presario R3000 Notebook
Toshiba satellite A105,My wife dropped laptop now when you try to start I get error message operating system not found, try to boot to bios and get several quick beeps
Harddrive has probably crashed or the connection have become loose. Flip the laptop over and look for the Harddrive assembly. Usually has 1 screw holding it in place. If you feel comfortable enough - remove the screw and pull the HD out and slide it back into place. See if the connections are simply loose.. If that does not work you probably need to replace the HD.
Jun 17, 2009 | Toshiba Satellite A105 Notebook
Dell Latitude D600 Notebook Logo
48 people viewed this question
Alun Cox
