Question about Dell E173FP 17" LCD Monitor
My dell laptop thw screen flickers and even goes black some times untill u put pressure on the back of it and then thats only a temeprary fix till it goes bacck to being dull , flickering or black can i fix this
  • 11,361 Answers
You may have loose connection between the LCD panel and the chassis, loose connection on the backlight board, you need to open it up and see, try reading about laptop repair here: <a rel='nofollow' href="http://www.insidemylaptop.com">www.insidemylaptop.com</a><br /> <br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a rel='nofollow' href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a rel='nofollow' href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span>
Posted on Aug 25, 2010
When i plug my ac adapter the screen flickers a couples of time then i goes black
Hi grice2000,
The easiest way to fix this problem is to perform a power drain. Please follow the instructions below.
1. Turn off the system completely.
2. Unplug the AC adapter from the power outlet.
3. Remove the battery from the unit.
4. Now, press and hold down the power button for about 15-20 seconds.
5. Put back the battery in and plug the AC adapter.
6. Reboot and observe the system.
Hope it helps.
Thank you for using FixYa.
Jan 09, 2011 | Dell Inspiron E1505 Notebook
Dell D610 Screen Black, But Power Still On
Hi my name is Eric,
I hope I can help you with your isue,
 Thats the way these dells are, the standby mode sometimes puts it in hibernation.
Check the settings in the screen saver/ power area
If I have helped you pleae click accept
we can till post until the post expires
Thanks
Eric
Sep 27, 2009 | Dell Latitude C610 Notebook
Dell Inspirion Laptop Screen Randomly Flickers, Then Blacks Out
not to get to concerned just yet, a few tips, when you press on the top of the laptop case by the screen area in the back of the laptop do you notice the screen flickering off? and when you let go dose it come back on? if so this can be a faulty wire or bad inverter, they are actually both very simple to fix and relatively cheap fixes.
Aug 20, 2009 | Dell Inspiron 1100 Notebook
Dell inspiron 6400 display goes off < 1 min after switch on time
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
The buzzing sound is most likely the inverter problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 26, 2009 | Dell Inspiron 6400 Notebook
Acer Laptop Screen Flickering
The flickering screen indicates that it is a backlight problem with either a faulty inverter or inverter connection problem. The inverter is usually located at the bottom edge of the LCD screen, and may have one or two connectors (one for the video info. and one for the inverter power or a combined connector) attached to the motherboard under the case near the top edge of the keyboard near the hinges. Reseating these connectors may solve your problem.
Jan 29, 2009 | Computers & Internet
Dell SP2208WFP Flat Panel Monitor flickers out and goes black.
Hi again,
Any luck with the Dell people?
A favor if I may, at your convenience, would appreciate if you can rate our Live Session as you see it fit.
Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 05, 2008 | Dell 21" M1110 .22DPI 1600x1200 *SUPER...
Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
May 28, 2008 | Dell Latitude CPX Notebook
Screen goes black
. if The screen flickers then turns dark,when you move it or tap it lightly on the sides, it may be due to Failed cable at the back of the screen or LCD
In some cases you might hear a buzzing noise coming from the area where the inverter board is located, it’s on the bottom part of the screen Troubleshooting: If the screen is black, look for the “lid closed” switch and try pushing it a few times. It’s usually a small switch near the hinges that is pressed when the lid(the screen) is closed. Sometimes these switches get stuck in the “lid closed” position that results in black screen(no backlight) or non-starting laptop. Also some laptops have a magnetic switch (newer Dells, most Macs, etc.) that doesn’t get stuck.
The most common failures are (in this order): inverter, “lid closed” switch, cable, LCD, backlight.
the display assembly.so open the display assembly check the cable fix it tightly and again if no improvement change the inverter PCB
May 20, 2008 | HP Compaq nx5000 Notebook
Dell E173FP 17" LCD Monitor Logo
119 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
