Question about Dell Dimension 5100 (D51L1) PC Desktop
Not the power supply!
I tried my power supply in another computer and it worked fine.I have a green light on my mother board and I poped the watch battery out and it reads 3.2v dc and seems to be fine.What is your guess to why my computer wont power up and yes I double checked all the connections "Everywhere".lol
    An expert whose answer gotĀ voted for 100 times.
  • 156 Answers
To help troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights lites solid green. The power button also lites solid green. If the computer malfunctions, the color and sequence of the diagnostic lights as well as the power button helps identifies the problem.
First, disconnect the power cord and remove all connections (Keyboard, Network, Mouse etc) as well as optional PCI Cards. Connect up the power cord (Monitor as well) and try powering the PC.
Check the diagnostic lights/system lights color and sequence and check the link below for more info (Assuming you have another system that can access internet)
Diagnostic Lights -
System Lights -
Reply with lights color and sequence as well as any beep codes and I will respond at best effort.
Posted on May 07, 2008
I recently purchased a new atx 1956f power supply. When it was installed in my computer the green light in the back came on like it was supposed to, but when I pushed the computer power on button the power...
Hi, check your power supplier fan is work or not. if it is then watch mother board light is on or not. If it is then try to connect correctly power cable into the port.
May 13, 2011 | Computers & Internet
Power supply pulled from working system about 1.5 years ago. Connected to the previous mother board. On board power LED solid green. Tried to power up, but the light just flickered very fast. Tried...
try 800W power supply? also make sure you connect the big flat multi cable plug and small 4 cable plug into the mother board usually on opposite side of the big plug
Mar 02, 2011 | ASUS A-55GA (A55GAATX550WAPFC) 550-Watt...
Power supply light flashing green ,,, tried unplugging mother board still flashes green is it the power supply or the mother board?
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacemnent from, Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
Aug 14, 2010 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Flashing green light on psu
you need a new power supply and try it see if any change it try to take off your modem and one of the 2 will be a problem thanks
Nov 08, 2009 | Computers & Internet
Dell 8200 won't turn on - power supply is good
Have you put in a CMOS Battery? Hard drive works?Any more information that was not in your first post?
Sep 06, 2008 | Computers & Internet
No Power of a Compaq Presario Computer
Make sure that the power button is conected to the right prongs on the mother board. On the writing next to the prongs it should say power.
Feb 23, 2008 | Computers & Internet
Power Green Light Flashing HP Desk Top PC m7250n
During a power outage their is a surge when power come back on the grid (surge can be caused by lighting strikes akso). This surge trips the internal procters inside the power supply to protect the Mother Board, hard drive, processor and fans and any device that pulls wattage from the power supply. Since all these power using devices are trying to pull power at the same time to boot the computer back up one ends up with a loop of surge thrugh the power supply with a protective trip, reset, surge again and trip again. This will continue in this loop as the computer is trying to boot all the devices at one time (Mobo, Hd, processor, cooling fans and other devices). Simoly, more power wattage is being demanded than the protectors will allow at one time causing a protective shutdown followed by a restart followe by a protective shutdown in a continious loop.
The normall sequence for a boot is to boot the board, processor and fans followed by a boot of the hard drive, and other boot devices once the board is energised, NOT all devices at the same time, as this results in an overload and trips the protectors. This protective loop is indicated by the blinking light as the power is turned on and then shut down for protection as the wattage pull is over the demand that the protectors will allow.
Blinking light indictes you are in the protective loop.
SOLUTION: 1. Disconnect the Mother Board connector, with the computer unplugged, this will allow the power supply to reset at maximum wattage upon reboot.
2. Disconnect the Hard Drive power connector and ay boot device power supply cables, this will allow the Mother Board, processors and fans to boot without an overload of the protector inside the power supply.
3. Plug in the computer and the indicator light will be solid green indicating that it is reset and out of the loop.
4. With the computer pluged in and the Power Supply fully energised, plug in the Mother Board. The computer will now boot, and the processor fan will come on and the cooling fans.
5. After computer has rebooted, shut the computer back down and connect the Hard Drive power cable and any other power cablis that were unplugged.
6. Reboot with all cables connected and you are up and running again.
Hope this helps everone with power outages and lightining strikes. It is a rather common problem and can also occure when building a computer and one missmatches the power supply with the board wattage needs. If the board wattage needs are greater than the power supply output you will get stuck in a potective loop eventually. WHEN BUILDING A COMPUTER ALWAYS MAKE SURE THE POWER SUPPLY CAN PRODUCE MORE WATTAGE THAN YOU CAN CONSUME AT THE MAXAMUM LOAD.
Have a great computing experiense.
Jan 13, 2008 | HP Media Center m7250n (ED842AA) PC...
No power no light
Could be either one, or it could be the toggle switch.
Start with the easiest first to check. Unplug the power toggle switch from the mainboard and take a screwdriver or something and short out those two pins to see if it starts the pc. if it does, then your pc case switch is just bad.
If that's not the problem, check the power supply next.
Jumper the ATX 20 pin power cable's green wire to any black, just to make sure the power supply is working. The fans in the power supply will turn on along with anything else hooked up.
To jumper the power supply use a section of wire or a bread twisty (with the insulation removed from the ends) and just connect the green wire to any black wire on the 20 / 24 pin power connector. Make sure that the power switch on the back of the power supply is switched on.
If neither of those seem to be the problem, then most likely it is the motherboard or the processor.
Dec 21, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Power problems with Dell Dimension 4600
Your mohterboard seems to be bad! If you have replaced the power supply and placed all connections in the rightful place, with no result! Your Motherboard is definetly bad!
Nov 29, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
612 people viewed this question
Alun Cox
