Question about Electrical Supplies
Wires were cut to th starting system.i can get it to crank over but no fire to the plugs.
  • 3 more comments
  • malibu_frank Aug 26, 2010
    onan 6.5nh3cr712014d generator.
    the unit is not in a motorhome at this moment.i just bought it and an\m trying to start it before installing it.i connected the fused wire 0n the generator itself and the fuel pump to a hot battery wire.the engine cranks and the fuel pump runs but no fire to the plugs.the man i bought it from said it was running a few months ago.
  • malibu_frank Aug 27, 2010
    the remote wires are the ones that are cut i think.i am trying to get you some pic. but i am not too good at this.
    there is a control box. i am trrying to get a pic but i am not too good at this.to get it to crank i have to jump the solinoid and use a jumper wire on the fuel pump.
  • malibu_frank Aug 30, 2010
    did you get my pics. of the gen. switch?
  • 905 Answers
Hello Frank,
Without a manufacturer and model, it will be difficult to sort this out. If you can provide, I can help you much quicker.
Generally, an engine that has an electric start also has a shutdown method as well. This may happen using a button, switch, or be part of the keyswitch. Most engines are turned off / shutdown through the "disable" wire that goes to the ignition module. If this wire is grounded, the module turns off, and the engine slows to a stop. Look for a wire that snakes back under the cooling shroud of your engine. Follow from the shroud until it makes its connection to the harness, then disconnect it. Engine should start and you should have spark.
Note that connecting this wire to the battery very well may damage the coil (burn it out). If the wire that it was connected to has battery voltage on it, the ignition module is likely toast and will need replacement.
Posted on Aug 26, 2010
  • 2 more comments
  • Sheldon Dedek Aug 26, 2010
    I suspected that this was going to be an Onan. I have several manuals, but it will take a bit to find them.
    In the mean time, got a few questions to help narrow down / isolate where problem lies.
    How are you trying to start the generator? Are you using the switch on the generator itself, or are you trying to use a remote switch at the end of a wiring harness? If using remote, are you able to start it with the switch on the generator?
    When the generator is turning over, are you getting voltage to the fuel pump / propane solenoid?
    Is the choke closing when it is turning over?
    How was everything reconnected? did you try to match colors?
    Are you using the switch to try and start the engine, or are you jumping across the solenoid / hardwiring solenoid to the battery?
    Found the manual.
    Your fuel pump should be connected (eventually) to frame / battery negative. The other wire should goto Terminal 6 on the terminal strip. Also connected to terminal 6 should be the + terminal of the spark coil, as well as the #87 contacts of relays K2 and K3 (the 2 black relays in the control box).
    Tell me what you are trying to work with here. Is there a start switch at all, or are you just looking at a mess of wires where there was a switch before? Do you still have the 6 position plug that connects to the side of the control box, or was it cut as well?
    I can understand that wires were cut to the starting system for the remote panel. Even so, cutting those wires, as long as they are not touching / grounding out, would not stop the generator from being started using the switch on the control panel itself.
    Is the control panel / box missing altogether?
    If you could, take a picture, and attach it to your next comment.
  • Sheldon Dedek Aug 31, 2010
    Nope, no pictures present that I am able to see.
    The biggest problem though, is that you are not engaging the relay that turns on the fuel pump AND enables the ignition. Only the fuel pump is being turned on (forced).
2001 Grand Caravan 3.8 code says camshaft or crankshaft sensor how to tell which one it is van stumbles and cuts out from time to time and at low RPM occasionally stalls out
Crank and cam has the same power and ground wires tied together. The signal return are separate wires to the PCM. Guessing, I would say you have a bad/ broken wire at the crank sensor. The wires tend to break at the plugs. When you loose the cam sensor, the PCM goes into default mode. It will still fire the injectors. You just have lower gas mileage. When the crank sensor dies or can't be read. The engine will not start. No fire to the coil/s or plugs.
May 18, 2016 | Cars & Trucks
Cuts out randomly, starts again ok,rides ok,done spark plug air filter,emptied tank. wot now,is there a solenoid or something?
when it cuts off I would pull spark plug wire and crank and see if it is getting fire at the time it has cut off, if its not sparking the coil is probably getting hot and cutting out. if it is getting fire I would remove the bowl of the carburetor and clean with a wire brush and carb cleaner.. I would make sure the float is moving up and down freely, lastly I would check to make sure the air vent on the fuel system is not blocked. if you continue to have problems after checking those things.. please contact me as I would like to help you get your bike running!
Sep 28, 2015 | 2004 kawasaki Super Sherpa
I have a 2000 grand prix 3.8 non supercharged.I replaced th head/intake gaskets..plugs/wires..etc. now it cranks but won't start. I used an inline spark testlight(I dont have a helper so I connected it...
Diagnose the no spark first. Check to make sure the crankshaft position sensor is not damaged and is plugged in. Check to make sure the camshaft sensor is also plugged in . Does the car have a RPM gauge? If so, check to see if the needle moves while cranking the engine, this would indicate the crank signal is good. Also, check to make sure the ground wires got attached under the ignition module bracket. The short burst of fuel is not uncommon on an engine that is not running.
Feb 22, 2015 | 2000 Pontiac Grand Prix
2000 Toyota Sienna won't start. No spark
I parked my 04 sienna and cut it off 2 hrs latter I tried to start it and would not crank starter was fried replaced with new one now it crank but will not start I tried starting fluid same thing cecked fire to plugs fire once and quit until you turn key agin fire once agin replaced cam and crank senser no start what am I missing anyone thank ,lost..
May 30, 2012 | Toyota Sienna Cars & Trucks
My 04 1.6 renault megane struggles to start in th morning and once it does fire up you hav to rev it to ensure it wont cut out. The car then splutters and judders a bit till its warm then it tend to run...
My 05 1.6 renault megane struggles to start in th morning and once it does fire up you hav to rev it to ensure it wont cut out. The car then splutters and judders a bit till its warm then it tend to run ok. but keeps on switching off at the robots when i stop please what could it be
Sep 30, 2010 | 2003 Renault 181
97 crysler sebring convertible wont start cranks but no fire replaced the timing belt and pullys distributer cap and rotter button the plugs and wires were replaced last month it has no fire the symptoms...
Hmmmm...are you sure when you changed the timing belt that all the timing marks were ligned up correctly?
Did you check to make sure you had no damaged valves?
Nov 16, 2009 | 1997 Chrysler Sebring
My engiene cut out while driving and wont start it cranks but it wont start... i changed the ignition coil and the wires and the plugs nothing i sprayed starting fluid in the intake and nothing it cranks...
Did you check for good compression? You may have either jumped timing or have a broken timing belt. I would check engine compression first. If it's good then move on to checking your fuel and ignition systems.
Nov 03, 2009 | 2003 Dodge Neon
1997 gmc truck remote start system not letting truck start with in ,i un plug and it fires right back up,if i plug remote start in it wont start with key but will with remote ,i unplug remote key will...
IF ENGINE CRANKS BUT NOT START -, sounds like a short in the tach wire, plug remote starter in and cut the tach wire to the engine for the remote starter. if the truck starts then you remote starter module is faulty.
IF ENGINE WON'T KRANK -, then there is a starter kill hooked in with it. if you bypass this you should be fine. just follow yellow wire from ignition switch till you find where it is cut. rejoin these two yellow wires and you should be good to go
Mar 07, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
No power to fuel pump, relay is good, engine cranks over but won't start.
You need to follow a detailed troubleshooting procedure in a repair manual.
Check for spark plug fire during cranking after it dies.
No spark = ignition problem= computer will not fire injectors, and possibly cut out pump also.
Good spark = pump wonky, or power to pump system.
Also, other quick tests... when the thing dies, and then you crank,
1) Thump the fuel pump in the tank, if you can. A bad fuel pump might start up again.
2) Shoot some ether carb cleaner in the TB. If it only fires off the ether, the ignition system is no longer suspect.
Oct 13, 2008 | 1992 Dodge Dakota
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
