Question about Fuji Printpix CX-550 Thermal Photo Printer
My printer just makes a sound that wont turn on just makes a grinding sound emplpoyee thouhgt maybe it over heated can u help m fujui cs 550
DId you find a solution to it ? I have a same issue.. Cx-550..Makes turning on noice, fan starts but there are no lights.
Thank you for your help.
Ash -
Posted on Jun 13, 2011
My car is squiealing and making grinding sound if it idles to long it will start to over heat
maybe an idler pulley getting stuck causing the water pump not to turn
Jan 24, 2013 | 1997 Ford Taurus
Aprilaire 550 makes extremely loud grinding noise when turned on
yes it should be bypass but solenoid could be trying to open but the voltage to it may be to low if you have 24v ac power at the 2 small wires. but to change shut down power to furnace and water to humidifier.you loosen the 2 compression nuts unwire they cant be reversed so dont worry then 2 mounting screws then reverse to install
Dec 17, 2009 | Aprilaire 550 Humidifier
Hplj3005n printer making a grinding noise from the rear?
The grinding sound you hear is coming from the fuser unit. From time to time they will fail before the estimated life is up and one way they fail is by binding the heat roller and that causes the gears to grind making the noise you hear. You will need to get a replacement fuser, they are available from many places on the internet.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Nov 05, 2009 | HP LaserJet P3005n Printer
Noisy Fan on Copier CS-3035
actually fan really works even at sleep mode to exhaust heat, the problem is one of the three fan located at the left side if your facing the machine, is deffective a broken blade causes it to sound bad try to remove its connector, afer all you have two more working
Nov 01, 2008 | Copystar - CS-3035 Printer
Loud groaning noise when copier is turned on.
sounds to me like the laser unit is going bad. common problem on this model.
razors
Nov 28, 2007 | Copystar CS-1510 Copier
Fuji Printpix CX-550 Thermal Photo Printer Logo
81 people viewed this question
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
