Question about Sony CDX-S2010 CD Player
I've had my Sony Xplod CDX S2010 Radio/CD player in my Jeep for years and it has all of a sudden locked up on me. The CD player will play and eject CDs, however it doesn't allow me to adjust volume or skip tracks. No other buttons work on the radio (let alone the radio itself), it's as if I locked it. I took off the face plate and hit the reset button, but it hasn't changed anything. Any help would be appreciated!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sony Master
  • 2,226 Answers
I'm not sure if there is a flexible cable that goes from the face to the motherboard. if there is, that could be the problem. it could also be a bad switch.
Posted on Aug 25, 2010
Hello, umm my CDX-GT200 sony player in my jeep as been working great.. however just the other day I was driving home with it playing the radio and all of a sudden it just powered off.. and now when I try...
hi firstly check your fuses ,remove the player from dash check all wirering especially the positive + and - negative ,should be black and red ,check with multimetre for current at these wires you can disconnect the power block from the radio if you like and check for power this way .hope this helps you goodluck
Mar 18, 2011 | Sony XPLOD CDX-GT200 CD Player
Sony xplod am/fm cd model cdx-m610 will play cds but the radio want play. i have tried to reset radio still will not play
Make sure that you have the antenna plugged in and if you have a power antenna make sure that you hook up the solid blue antenna wire behind on the radio harness to the power antenna wire from the car plug.
May 21, 2010 | Sony CDX-M610 CD Player
Cd not working but radio is
run a disc cleaner through it about 5 times and see if that works
Apr 21, 2010 | Sony Xplod CD Player w/MP3 Playback...
How do I replace a fuse on Sony CSX-S2010?
there will be a fuse on the back of the radio, you will need to keys to reove it, also check the fuses in the car fuse box.
Nov 08, 2009 | Sony CDX-S2010 CD Player
Installed the sony xplod
You may have used the dimmer wire to ground your radio and blown your fuse. First unplug your radio. This problem can be checked with a multimeter by seeing if the wire is grounded with the car off. Turn on the lights and see if it reads 12 volts on that wire. If so, use another ground wire or attach it to the truck's chassis earth.
Jul 06, 2009 | Sony XPLOD CDX-GT200 CD Player
Sony Xplod CDX-S2210S
It is more then likely your faceplate has become non functional, and if so the cd player is almost none functional. If you can remove the faceplate try cleaning the connections that clip into the cd player. But by the sounds of it, your face plate is die'ing out on you. Sorry
Good luck,
IF you need any more help just ask.
Thankyou
Aug 10, 2008 | Sony CDX-M610 CD Player
Please Help
check face plate maybe contact dirty if not well our in trouble sometime it not worth to repair it cheers
Jan 08, 2008 | Sony CDX-S2010 CD Player
Cannot play my portable audio device with Sony cdx c500x
It will only accept audio from the bus in conections when a multi changer is connected and selected.
This is how I connect my mp3 player to my sony.
Swap multichanger audio outputs at the rear of the stereo for my mp3 player, press source to select multichanger.
Remember as I said, if there is not a control cable connected to your multichanger it wont wotk!
Aug 17, 2007 | Sony CDX-C5000X
Sony CDX-S2010 CD Player Logo
426 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
