posted by pk_456 on May 05, 2008
My (reasonably new) gas range is all black with sealed burners. I've been having a heck of a time trying to clean around the burners -- it's impossible to get off the burned-on spills which get set as soon as they occur, and it almost seems as if the finish is "bubbling". I can't think of a solvent I haven't tried, and I've been tempted to get out my scrubber, but am afraid it will scratch the surface and make it worse -- but at this point, I can't imagine how much worse it can get.
Any suggestions you might have would be greatly appreciated.
Solution #1
posted on May 09, 2008
CERAMIC COOKTOP CLEANER.. its amde specifcally for it.. nothing else is needed. well exept for a good razor blade as well. clean the stove top as per the directions on the cleanre. small circular motions untill dry and then buff them out with the same circular motions, for the stubborn stains, reapply the cleaner and with the razor blade laying flat scrape of the spots, just dont use the points of the razor be sure to lay ot flat.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for GE Profile Spectra JGBP90 Gas Kitchen
Email this problem
Email this problem
Can you Help with these Kitchen Ranges problems?
GE Profile Spectra JGBP90 Gas Kitchen Range
OVEN UNABLE TO HEAT ABOVE 350...
the oven no longer goes above... Answer This...
GE XL44 igniter
GE XL44 igniter
Igniter clicks when not being... Answer This...
Mabe gas range
Mabe gas range
I bought a five burner gas... Answer This...
caloric gas range rln383ul...
caloric gas range rln383ul... Answer This...
Door locked blinking
Hi Guru, following is our... Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
Find Parts
