Question about Singer 8280 Mechanical Sewing Machine
My presser foot lever wont lift the presser foot all the way up on my singer
  • Anonymous Mar 30, 2014
    the foot is down not lifting
    Genius:
  • 1,788 Answers
Make sure that your needle is in the highest position, turn your handwheel towards you, not away from or else you will mess up the timing
Posted on Aug 31, 2010
Presser foot doesn't go down. Presser foot lever goes up and down but the presser foot does not. Singer sewing macine.
There may be a disconnection between the lever and the presser foot bar. Perhaps a screw has fallen out, broken, or is loose? May need to take it for service.
Sep 25, 2017 | Singer Sewing Machines
Presser foot wont connect
It is most likely the presser foot you are trying to install was not made for your machine. There are so many machines available and most of those machines have their own presser feet, which are not interchangeable. Unfortunately, even a Singer presser foot is not interchangeable with other Singers. Some have screw attachments, others have lever attachments, some have long shanks, others have short, some are straight, others are slanted. You need to figure out what style presser foot your machine takes and then search for either the presser feet that fit or a shank adapter that you can then use snap-on feet (kits are available on eBay).
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
Sewing Machine Feet eBay
Jul 17, 2016 | Sewing Machines
The presser foot won't go down.
Yes indeed, it is possible--sounds to me like a screw worked itself loose. However, I would purchase the service manual for your machine. As a bonus, it tells you how to make all kinds of useful adjustments.
Go to Sewing Parts Online and do a search under Singer Service Manuals; if they don't have it in stock, call or email them and they will be happy to order it for you. Generally takes two weeks to get it in stock.
Apr 10, 2015 | Singer 20u Sewing Machine
Pressure foot won't stay up
The presser foot lift lever on many newer janome sewing machines will wear out with use. It can easily be replaced by a sewing machine repair shop or Janome dealer. Or you can look online for a "presser foot lifter" or "presser foot lift lever" making sure to find the correct one for your machine.
Mar 03, 2014 | Janome Sewing Machines
I have a 9960 singer machine and am trying to use the buttonhole presser foot for the first time and I can not get it to sew T
the buttonhole foot snaps on to the presser bar, there's a little lever at the back of the presser bar that releases the foot, then put the buttonhole foot down on the needle plate & use the presser foot lifter (number 11) to lower the presser bar down onto the buttonhole foot & you'll hear a click sound when it snaps on & make sure to use the buttonhole lever(number 31) because the machine won't sew a buttonhole unless that lever is pulled down.
Apr 26, 2012 | Singer Sewing Machines
How do I move the presser foot on a Husqvarna Viking Emerald 116 sewing machine?
Not sure what exactly you need to know. Are you trying to lift the presser foot or change the presser foot to another one? If it is lifting, there will be a lever of some kind behind the machine. On one of my Husqvarna machines it was a big flat "paddle" shaped lever, not sure what shape it is on the Emerald machines. Lift the lever from the bottom upwards and outwards. Most Husqvarna machines have clip on-and-off feet. You just gently pull forwards on the foot (while the presser foot is raised) to remove it, then push the new one on making sure the small bar part of the presser foot goes into the clip on the presser foot ankle.
Jun 16, 2010 | Husqvarna Viking 1
Presser foot lever does not lift presser foot
If you can remove the cover on the left side you will see the presser foot bar. On the bar there will be a screw that may be loose. Turn the handwheel until the needle is all the way down and lift the foot manually until just before it makes contact with the needle clamp and tighten the screw on the presser foot bar.
That should do it.
Jan 07, 2009 | Sewing Machines
Presser foot lever stuck
You lever doesn't work because the presser foot Bar is seized from lack of use.Open the side of the machine to access the bar. Put a mixture of water and ammonia ( about 80%water 20% ammonia) on the top and bottom of the bar. Let it sit for 15-20 minutes then try to move the presser foot Up by lifting the foot with a screw driver. Do not pry so hard you break something. It should get progressively easy the more times you do this. Put some sewing machine oil on the top and bottom of the shaft and it should be good to go.
sewman7
May 31, 2008 | Singer 5062 Mechanical Sewing Machine
Singer 8280 Mechanical Sewing Machine Logo
385 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
