Question about Thetford Norcold RV Cooler/Freezer
I have a Norcold 611 and the freezer works fine, but the refridgerator wont get cold. Any answers?
  • Thetford Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Norcold 611 freezes everything in the fridge
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Be sure the BACK COVER is in place and hasnt been accidently removed.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Apr 10, 2012 | Refrigerators
My freezer works fine but refridgerator is wont get very cold
If freezer is frosting up, check fan. if fan is not working in fridge the freezer will ice up and the fridge will not get cool air.
Feb 09, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I HAVE A NORCOLD 6162 RV FRIG AND THE FREEZER FREEZES FINE AND THE COOLER COMPARTMENT WILL GET COOL BUT NOT COLD AND THE ADJUSTMENT SWITCH IS ALL THE WAY UP. THE SAME ON GAS OR ELECTRIC. CAN YOU HELP ME....
u need to open the thermister up its located on the back on the fin also check to make sure u are getting full 12 volts to the fridge check the voltage at the fuse
Oct 16, 2009 | Thetford Norcold RV Cooler/Freezer
RV freezer cools, but fridge section doesn't
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 09, 2009 | Thetford Norcold RV Cooler/Freezer
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
Top refridgerator does not get cold but the bottom freezer works fine
Most of these have a fan that blows the cold air for the freezer into the refrigiator section. If the fan quits running you will experience your problem.
May 08, 2009 | Refrigerators
Fridge portion of my 611 is warm but freezer is still cold. Help.
The only other thing that seems could be wrong is that your freon lines are icing up and is cause you to not cool properly. Pull out your fridge and check the compressor on the bottom
Feb 07, 2009 | Sub-Zero 611 / O Bottom Freezer...
Frigidaire frige not getting cold but freezer working
my refridgerator is not getting cold but the freezer seems to be working fine. can anybody please give me some advice on what this could be. We had a new defrost element put in a few weeks ago and we now have moved house so fridge is cool but not really cold enough model E402B any help would be appreciated.
thanks pam
Apr 29, 2008 | Refrigerators
Thetford Norcold RV Cooler/Freezer Logo
743 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
