Question about Nintendo Video Game Consoles & Games
Nintendo ds hinge was broken so I attempted o change the case. No big problem with case change, but unit will not now power on. red charging light stays on when plugged in, and when i turn on, green light stays on about 3 secs and then goes out. Any help appreciated.
Thanx alott that really helped me fix my ds!!!
Posted on Jul 22, 2008
I just done mine and if everything is not connected properly one of the fuse's blow's.
Their are 2 fuses both situated on the pcb they can be bridged but it is fiddly.
Posted on Jul 21, 2008
The ribbon cable must be attached to the top screen before it will turn on.
Posted on Jul 13, 2008
My sons ds lite will not turn on the green light comes on and a white light flickers on bottom screen and thats all, I changed the battery and still no luck. Help! thanks
it's likely that the top screen ribbon cable has either become damaged or loose, the entire top screen will probably need replacing (along with the casing if the hinge is broken).. if you are not confident with technical or fiddley things I wouldnt recommend attempting it yourself.
Jan 08, 2010 | Nintendo DS Lite Console
Nintendo ds
First remove the new case and see what you get - if it all works fine then the case must be pinching a cable or pressing on something it shouldn't. Check the unit with AC only or battery power only. The faint click is probably the power switch membrane clicking across - probably indicating that the switch itself is fine - but check at least visually and with a meter if you can. the most likely causes of the problem if removing the case again does not get it working are; Loose connector - probably where the screen hinge is, or where those cables connect to -check anything that you could have moved. Is it an official original case? some cheap copies may be badly fitting, although I found no info on any problem like this so far. If you have a card inserted, try with a different one or without one. check nothing got in the card slot and no pins are bent - especially if you just put a card back in after replacing the case. Especially could be problem if your DS was set in Auto start-up mode before. Possibly unconnected to the case change, the power supply or battery could have failed. Check through this link and see if it helps identify if that is the problem. Do you get any power or charging lights? http://www.nintendo.com/consumer/systems/ds/trouble_power.jsp nintendo do not recommend it, but it may be worth removing and reinstalling the battery in order to reset the unit. proceed with care. Here is the link to the manual if you need it; http://www.nintendo.com/consumer/downloads/ds_english.pdf Hope this helps - please post back with more details :)
Aug 15, 2007 | Nintendo DS Console
Ds lite top screen
Yes its fixable but it depends on what has broken.
There are two possibilities the small barrel hinge has broken, this is just a case of fitting a new one by opening the case, unscrew the light and gently pulling the top of the case away till you can change the barrel hinge.
The other one is the case has broken and is not holding the barrel hinge, can bodge it with some glue sometimes but most often you need a new case.
Jul 09, 2009 | Nintendo DS Lite Console
Both screens of my DS are blank! What happened?!
Any liquid spills???
You've damaged the hinges and when that happens the cables are destroyed easily. Both of then need to be replaced.
Contact a local shop or http://www.newcorp.com
May 26, 2009 | Nintendo DS Lite
Ds lite hinge is broken is there an easy fix
There web sites where you can get a new case for your DS. When searching try using : nintendo ds lite replacement shell or nintendo ds light case modding
Feb 25, 2009 | Nintendo DS Console
Nintendo DS Lite Broken Right Hinge & failure to stay powered on
the nintendo DS IS A *******!!!!!!!!!!!!!!!!! PIECE OF **** YOU ******* ****
Feb 07, 2009 | Nintendo DS Lite Console
Nintendo ds will NOT boot up
you need a new top screen......ebay.
Sep 08, 2008 | Nintendo DS Console
Will not power up after changing the case
I found this on ebay after a lot of searching forums and other sites, and it worked for me!
"If you are one of the unlucky ones, LIKE me, you may find after taking it apart,and then putting it all back into the new case, that when you power up, bottom screen flashes, and nothing... DONT panic.. I did.. tried looking for help on the web and couldnt find any. It just means you, like me havent pushed one of the Ribbon cables fully in... took me a while to work it out, just unclip the ribbon cable again, and with both fingers gently push it all the way in, you will feel it slide into the socket more than it did before. "
Good luck Duca
Sep 14, 2007 | Nintendo DS Console
Video Game Consoles & Games Logo
85 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
