Question about Compaq TFT450 14" LCD Monitor
Please how can i identify 5v and 12v terminal on the circuit board?
  • 11,361 Answers
<P>Is the monitor working/ If it does you can measure the DC voltages on the DC secondary side, the 5vdc will usually use 10~16vdc cap, the 12vdc will use 16~25 vdc caps.</P><P>If you can post the picture of the circuit board then I can tell you where they are at, I will need both sides of the board.</P><P style="tab-stops: center 3.25in left 255.75pt"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A rel='nofollow' href="http://s807.photobucket.com/home/budm/allalbums"><FONT color=#800080>http://s807.photobucket.com/home/budm/allalbums</FONT></A><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A rel='nofollow' href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</A><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <A rel='nofollow' href="http://lcdalternatives.auctivacommerce.com/Viewsonic-C196320.aspx"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>http://lcdalternatives.auctivacommerce.com/</A><SPAN style="mso-spacerun: yes">&nbsp; </SPAN>he can make you a set of caps for you.<o:p></o:p></SPAN></P><P>&nbsp;</P>
Posted on Aug 25, 2010
Can I tap a -5v into a BESTEC atx-250-12z-rev d2 power supply ?
The output from the power supply is
Output Max. Load +5Vsb 2A -12V 0.3A +12V 13A +5V 30A -5V 0.3A +3.3V 20A Pin 18 out of 20 white -5 volts (optional)
20 out of 24 white -5 volts (optional) See the definitive connector definition.
All about the various PC power supply cables and connectors
Mar 05, 2015 | Computers & Internet
Samsung french door fridge, bottom freezer
It might be a power supply problem. My RF265AABP model has +5V and +12V from the power supply board located in the compartment with the control board.
Jul 09, 2013 | Samsung Refrigerator PCB Board -...
Mapsenor
Hi there:Test the MAP Sensor output voltage at the MAP Sensor connector terminal B (as marked on the sensor body). This is done with the ignition switch ON and the engine OFF. Output voltage should be 4-5 volts.
The voltage should drop to 1.5-2.1 volts with a hot, neutral idle speed condition.
Test engine controller (terminal 5) for the same voltage as described above to verify the wire harness condition. Repair as necessary.
Test MAP Sensor supply voltage at sensor connector (terminal C) with the ignition ON. The voltage should be approximately 5V (+/- 0.5V). 5V (+/- 0.5V) should also be at terminal 6 of the engine controller wire harness connector.
Test the MAP Sensor ground circuit at the sensor connector (terminal A) and the engine controller connector (terminal 4).
Test the MAP Sensor ground circuit at the engine controller connector between terminal 4 and terminal 11 with an ohmmeter. If the ohmmeter indicates an open circuit, inspect for a defective sensor ground connection. This connection is located on the right side of the cylinder block, at the oil dipstick tube mounting stud. If the ground connection is good, replace the engine controller. If terminal 4 has a short circuit to 12V, correct this condition before replacing the engine controller.
Also could check this video...
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
May 07, 2012 | 1998 GMC Jimmy
I had a Bernina Aurora 440 given to me to repair the machine runs for about 20-30 mins then the screen goes off. When you take the front cover off you can see 3 leds a 30v 12v and a 5v. The 5v led goes...
This is a problem with the particular model. Bernina has a servi ce bulletin out on that issue and it should be under warranty. It needs a new power supply, or L-Print as Bernina calls it.
Apr 21, 2010 | Bernina Sewing Machines
Won't power on
Toss this junk to the garbage can, this is how I solved my frustrations with my two units
Dec 29, 2009 | Cyberhome CH-DVD 300 DVD Player
My computer isnt powering up, what should i do?
r u a professional..??
assuming that ur bios is not flashed, in a wrong way..
all fuses to mains supply are ok, including all wiring circuitry..
if so check--
the system battery for above 3.0v
all smps output signals are ok..ps-on(green +5v);
pg(violet~+5v) & sb(grey~+5v); (orange~+3.3v);
yellow (+12v); red (+5v); white (-5v); blue (-12v);
ground (black~ 0v)..
the cpu..
..replace the smps/cpu/battery with standby n check..
..contact ur system admin/vendor....
Oct 27, 2009 | Intel D865GSA (BOXD865GSAL) Motherboard
Hi, where to buy parts for Maxent LCT TV
I have one screen for the model l271170w1 please let me know if you want it. to set up pricing. jribot@gmail.com jribotatgmaildotcom
Sep 22, 2008 | Televison & Video
Cyberhome CH-DVD 300 DVD - YELLOW light indicator of what problem?
Marlin P Jones & Assoc. Inc.. has a 5V 2.2A /12V 1.5A cord power supply that will fit into the space where the original power supply was! Lists for $6.95 but online price was $2.95. Works great! Connect 12V supply to the yellow lead and the 5V to the red lead of the output connector, black is ground, common to both supplies. Use QC terminals to the power cord input terminals, remove the cable clamp and the power supply will nestle beautifully in the space without need for support. (Remove the old circuit board plastic (3) and rear brass standoffs and use the front brass standoff for the output cable shield ground connection. (Part No. is 15955-PS) I bought two because I have a 2nd Cyberhome CD-DVD 300 which hasn't crapped out yet.
May 15, 2008 | Cyberhome CH-DVD 300 DVD Player
Older AWR1-1W not series III
when you have the back up what suggestion you are asking from us sir?
sir please be specific with what you want
Mar 14, 2008 | Bose Wave Radio
Carrier Window AC 19,600 BTU with Remote / Model is APX195BA
Hi,The PCB Transformer use for the relay switch 12v ,The Term.# 5,6,7 is for the Fan Motor speed Low,Med,High 220v .
Jan 08, 2008 | Heating & Cooling
Compaq TFT450 14" LCD Monitor Logo
50 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
