Question about Kitchen Ranges
I need to replace the battery in the Overhead Door (Model # 109130-390) remote and I can't figure out how to open it to get to get to the battery.
You need to remove the clip that holds to it the overhead visor by tugging it hard to pull it out of it's slot. Underneath there's a screw that lets you open it up to get to the battery.
Posted on Sep 19, 2013
  • Dave Skeels
    Dave Skeels Dec 09, 2013
    THANK YOU!! I fiddled with this thing for an hour, trying to pry the sides open. Of course, then I didn't have the right sized battery, but that's easily remedied.
Clicker garage door opener
I don't believe that you need to configure it.
It should be preconfigure to work.
What i think after revising the manual and from past experience with car remotes, the type of socket used for the battery inside the remote itself is often missing or broken solder. To make this more clear, the battery socket might need to be resolder on the small circuit board inside your remote.
good luck
Nov 29, 2013 | Viper Televison & Video
Looking remote chain for Legacy overhead door opener. Model #696CD/B
Legacy openers use the same remotes as Genie Intellicode 390MHZ. Should be able to get one at any lowes or home depot.
Aug 09, 2011 | General Electric GE 13-438 Overhead Garage...
I have a Liftmaster 3265-267, remotes do not work. Tried new batteries in remotes and still no work. When I get close to overhead unit and depress remote, I do hear a couple clicking noises
If the door works from the wall switch, but not from the remote, I'd suspect the battery. (s)
Since you have NEW batteries that only leaves 2 things that can be wrong. Check the program numbers for the remote and the door control board. They need to match.
If you check that and the remote still doesn't work, it could be the receiver built into the circuit board of the opener. Hopefully it's not that since it would need to be replaced.
Make sure the batteries aren't old one that were in a drawer somewhere, that despite being "new" are dead....or weak.
Feb 07, 2011 | liftmaster Chamberlain Garage Door Opener...
How can I reprogram an old style 61LM to a garage door with a learn button? Thanks!
Th?? Liftmaster 61LM remote ?? th? equivalent remote tο th? Sears Craftsman 139 model number listed above. It h?? dip switches inside th? battery compartment th?t ?ου match up w?th ?ουr existing remote tο m?k? ?t open ?ουr garage door. Th?r? ?? ???ο a set οf dip switches οn th? overhead opener itself ?f ?ου nο longer h?ν? a working remote. It ?hου?? b? easy tο find οn th? garage door opener. Th?? remote operates οn a 390 MHZ Frequency, ?n? works οn models frοm 1984-1992 essentially.
There will be a colored learn button on the motor head. Press and release this button and then press the button on the remote. That is it. Thanks BB
Mar 21, 2010 | liftmaster Chamberlain Garage Door Opener...
I need KLIK2 remote instructions
How do I connect KLIK2 to a linear with a learn button
Feb 17, 2010 | Universal Garage Wireless Keyless Entry...
Cannot get remote for garage door to work
push the green button on the opener then push your remote button
Jan 25, 2010 | Locks & Locksmithing
My remote will open the overhead door when I am standing inside garage, but not from outside
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
The first step is replacing the battery in your remote. If the range on your remote does not improve, remove the wall control wires from the overhead unit. If the range does not improve you will likely need to replace the remote control. After replacing the remote, or if you have other remotes programmed in to the opener, and the range problem still exists, please proceed to the Power Down test.
Multiple garage doors:
If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range doesn not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
Dec 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Kitchen Ranges Logo
1,236 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
