Question about Whirlpool Dryers
My dryer has heat but is not drying my towels. There is nothing showing in the lint trap. It is a Whirlpool Model GEQ9800PW2
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
Whirlpool duet dryer
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Oct 15, 2013 | Dryers
Clothes not getting dry
sounds like perhaps you are losing your heating element...could be electronic, but it's most likely the actual element needs to be replaced...
Apr 25, 2008 | Whirlpool GGQ8831L Gas Dryer
My dryer heats up but does not dry clothes. I check ventilation and lint trap, there is no buildup. what could cause it to take forever to dry clothes?
If the drum gets hot to a real degree it has to be a blockage between the drum to where the air exits the home.
They do make a brush designed to go into the area where the lint trap is and be long enough to come out the rear of the unit---A lot of places will come out and professionally clean from trap to vent outlet
A blockage can be dangerous as hundreds of fires happen each year from the lint catching fire in the dryer.
The tube to the outside may seem clear but if blockage anywhere from lint trap to it, that will cause this problem and present a possible fire hazard.
Its not unlike having your vac not pick things up very well...except there is rarely a fire with that.
Dec 16, 2012 | Kenmore Dryers
Clothes will not dry tried 5 times to dry them even cleaned out the lint trap and tube still will not dry clothes or towels
Bob you will probably have to change the limits or also called thermostats if you want to try this yourself. There is probably two of them, they are located down by the burner/blower assemble and not more than 1 1/2 around with two wires going to them
Unplug the dryer
locate the thermostats close to the burner . You may be able to remove the lint trap and lint trap cover. remove the wires from the thermostats and using an ohmmeter ohm across the thermostats . The needle on the ohm meter should peg all the way across if they are good. If you get nothing the thermostat is open and needs replacing. I hope this helps you , you are probably tires of working on it by now. Also there is a sight, www.ehow.com that may help you even more. Good luck, Mark
Apr 19, 2011 | Whirlpool Dryers
I have an electric dryer that is not drying my clothes- the drum does heat up.. but, taking several attempts to dry them- almost 8hrs for towels- the lint trap has lint that fell back into that trap,...
I worked on a similar dryer just the other day. Unplug it and take it outside
Make sure your vent ain't clogged or restricted.
Give it a good clean:
Next remove the back cover:
Get that filter chute off and inspect the blower:
Wash that dude out real good. That buildup in there slows down the drying time.
themobilian_990.jpgThis oil is safe for dryers. Use it on them rollers and idler.
She oughta work like brand new and the best thing is no parts were needed!.
I have a service manual and more info with videos HERE
Jan 21, 2011 | Whirlpool Dryers
I have a whirlpool dryer (LER7646EQ2) that is heating but clothes take forever to dry and the lint trap appears to be trapping less lint
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 20, 2011 | Whirlpool Dryers
Gas dryer quit heating
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Nov 01, 2009 | Whirlpool GGQ8831L Gas Dryer
Takes hours to dry small load
You have a build of of lint inside the unitm which is cutting air flow. Look outside at your exhaust. clean it and check how much air flows out.
Aug 30, 2009 | Whirlpool GEW9250 Electric Dryer
Lint fell back into lint trap. how can i get it out? already looked in back.
An appliance store can sell you a brush that is attached to a long wire. It is made specifically for removing lint from dryers. I have seen them at walmart and other places but for sure at an appliance store. Good luck.
Apr 20, 2009 | Whirlpool WED5100SQ Front-Load Electric...
My Whirlpool Clean Touch electric dryer is not drying clothes very well. It is not getting real hot, and it takes two cycles to get most things dry. Towels and jeans take part of a third to dry. I clean...
IF YOUR DRYER HEATS AT ALL, BUT WON'T DRY THE CLOTHES, 99 PERCENT OF THE TIME THERE IS A RESTRICTION IN THE AIR FLOW. PULL THE EXHAUST OFF OF THE BACK OF THE DRYER AND DRY ONE LOAD. IF IT DRIES O.K., THERE IS A RESTRICTION IN THE DUCT WORK.
CLEAN OUT THE LINT FROM THE DUCT WORK. IF THE DUCT WORK IS FLEXIBLE MATERIAL, REPLACE IT WITH RIGID 4 INCH METAL DUCT.
Apr 16, 2008 | Dryers
Dryers Logo
113 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
