Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
THE BRUSH DOES NOT WANT TO TURN AND THERE IS NO STRING OR ANYTHING WRONG WITH THE BRUSH, EXCEPT IT DONT WANT T0 TURN ONLY NOW AND THEN.
  • 694 Answers
Will it spin if you turn it?
I'd guess that the belt is either loose, or it's worn out and is slipping instead of turning the brush.
Solution: buy a new belt and replace it.
Posted on Aug 25, 2010
My brush works, but the vacuum doesn't work and the motor is hot
Hi Take brush out making sure string or anything like that is wrapped around brush Make sure belt is in proper setting
Nov 04, 2013 | Montgomery Ward Oreck XL Celoc...
The brush does not spin when engaged. Everything else is working fine.
When you remove the brush, the release button resets a trip fuse on the pcb. If that does not work at sounds like you have either blown the rectifier pcb or burnt out the DC motor that is in the brush head. You can get a complete replacement brush head for 70 pounds.
Jul 28, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
I have a kenmore upright direct drive vacuum. The vacuum works fine in all ways except the brush just stopped working. Any ideas?
The rubber belt which drives the brush could be broken or the brush can be clogged with string and hair etc.
Jul 15, 2010 | Kenmore Progressive 35922 Bagged Upright...
The brush is not spinning
Do you have animals or maybe picked up some string? Check the brush and see if anything is stopping it from spinning. You might have to manually turn the brush to get the string or hair out. You can cut it but be very careful.
Apr 12, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Turns on but doesn't turn over.
I would first check your filter as a dirty filter will sometimes produce this probIem. If that doesn't work take a look at the brush bar. I don't believe that these vacuums have a belt (I could be wrong about this and a broken belt will disable the brush) so the only thing that I can recommend is to unplug it, turn it over and see if there is anything obstructing the roller brush such as string, tinsel, rocks, etc. See if you can turn it with your hand without using much force. Good luck!
Mar 15, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
Brush doesn't operate when the foot switch is pressed to allow the system to engage the beater bar
I don't believe that these vacuums have a belt so the only thing that I can recommend is to unplug it, turn it over and see if there is anything obstructing the roller brush such as string, tinsel, rocks, etc. See if you can turn it with your hand without using much force. Good luck!
Mar 12, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Brush bar is not spinning
I would first check your filter as a dirty filter will sometimes produce this probIem. If that doesn't work take a look at the brush bar. I don't believe that these vacuums2_bing.gif have a belt so the only thing that I can recommend is to unplug it, turn it over and see if there is anything obstructing the roller brush such as string, tinsel, rocks, etc. See if you can turn it with your hand without using much force. Good luck!
Mar 06, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Sweeper Brush doesn't turn.
Could be that too much hair, string, or long fibers have been collecting around the roller. Remove it and clean it off. Also check the duct behind roller that goes up into the connection hose. Ther most likely is some sort of blockage.
Nov 20, 2009 | Dyson DC14 All floors Bagless Upright...
How do I take the brush out?
Most of these progressive drives have a bottom plate that you can take off, then you can get to the brush roll asm. There will be several screws.
Feb 17, 2008 | Kenmore 31913 Progressive Direct Drive...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
47 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
