Question about JVC AV-27720 27" TV
Describe your jvc av-27720 Problem no power main fuse ok.
    Top Expert:
  • JVC Master
  • 14,553 Answers
Look in middle of board for C926 or location like that--it should be 1000 mfd at 35 volts--fails a lot in these sets.
Let me know if you have questions as I am here to help.
SD TECH
Posted on Aug 25, 2010
Anu po pwd na ikabit na i.c no. sa jvc model av-21mt35
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 21, 2014 | JVC AV-27720 27" TV
JVC flatscreen tv model Number AV-21mt35 with vertical interference? how to solve this problem?
It will be best to replace its Line Output Transformer [LOT]. It is not good to join the broken EHT wire. EHT arcing cannot be stopped by using glue.
Apr 04, 2013 | JVC AV-27720 27" TV
I have a JVC TV AV-21DTG2 the TV goes on protection mode as soon as I switch on the mains power
The power supply regulator section circuit has to be troubleshooted. There might be some shorted component/s. It is a skilled work. You must have sound knoledge in electronics to do this work.
Apr 24, 2012 | JVC AV-32D305 32" TV
Jvc tv power light keep blinking but tv wont turn on model av 27720
Its power regulator section circuit ahs the fault. If you want to repair this section, you must have through knoledge in electronics and work experience. Most of the components in this section are very dangerous to touch. It is fatal for an unexpereinced one to try to repair this section.
If you are confident, download the repair manual to your set from internet and follow.
Apr 23, 2012 | JVC Televison & Video
Tv has a flat light across the middle of the screen. thats all it will do.
Very common issue is bad connections on the vertical output IC. If you can tap on the main board and the picture starts working or you see it flash to a full picture intermittently then you will need to re solder the IC. The location I believe is IC1421 on it should be near a connector and wires that are yellow and green in color. Please take a moment to rate my answer. Thanks...
Nov 24, 2009 | JVC AV-27720 27" TV
No sound the speaker is good as well is the amp. what is the problem?
if your tv has audio/video inputs try watching some dvd movies ir sound is heard by using your audio/video setup the problem most likely is your sound IF section or your switching ic that selects your av/tv mode is deffective
Oct 14, 2009 | JVC AV-27720 27" TV
JVC AV-27720 TV Problem: Picture goes to horizonal white line in center.
In most cases the following parts need to be replaced I think the part location numbers are accurate
IC421 LA7832 ( vertical output IC )
Capacitor C424 100UF @35v
Zener Diode D422 MTZJ75-T2
Resistor R541 1.8ohm 2watts
Oct 23, 2008 | JVC AV-27720 27" TV
Tv wont turn on
This is a general failure indicator and can be anything from a blown fuse to a bad power supply/vertical IC/lightning strike.
There are 2 fuses, check/replace both. if they blow again, check for physical damage to the vertical IC LA7832. If its cracked or had a hole in it , you are going to need to take it in for service.
May 18, 2008 | JVC AV-27720 27" TV
JVC AV-27720 27" TV manual
GO to www.Service Manuals.net you should be able to find it there!ThankYou for using FixYA.Have a Nice Day.
Feb 17, 2008 | Televison & Video
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
