Question about Toshiba Satellite A55-S326 Notebook
Upon turning it on, I have to reset the date and time. Then just before windows finishes loading, it flashes a blue screen and then windows starts reloading. It does this cycle of loading to blue screen over and over until I just turn it off. Any ideas?
4 Suggested Answers
ta_mcguire
  • 125 Answers
SOURCE: Bios Flash running windows now dead
you have a bad flash which means you corrupted the bios you will either have to take to a repair shop and have a new chip installed or buy a new mother board
Posted on Jul 27, 2009
UpGrade
  • 113 Answers
SOURCE: when i go to start it up, it shows the Windows XP
It's called a BSOD which means blue screen of death. try to boot into safe mode by pressing F8 as soon as the computer starts hit it repeatedly, then try last known configuration that worked. If that doesn't work, reboot and try F8 again and go to safe mode, then do a system restore.
Posted on May 22, 2010
GSPOT12
  • 75 Answers
SOURCE: cannot start windows or launch
It might be just a software related issue, i suggest you boot into safe mode(tap F8 repeatedly during POST), if you are able to access safe mode without any issue, you can perform a system restore. This will allow the computer go back in time when the issue is not yet present. Hope this helps.
Posted on Apr 14, 2011
How to reset dell xps m1330
You may follow the steps mentioned below to restore the Dell XPS M1330 to its factory default:
1 Turn on the computer.
During the boot process, a blue bar with www.dell.com appears at the top of the screen.
2 Immediately upon seeing the blue bar, press <Ctrl><F11>.
If you do not press <Ctrl><F11> in time, let the computer finish starting, and then restart the
computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
3 On the next screen that appears, click Restore.
4 On the next screen, click Confirm.
The restore process takes approximately 6-10 minutes to complete.
5 When prompted, click Finish to reboot the computer.
NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot.
6 When prompted, click Yes.
The computer restarts. Because the computer is restored to its original operating state, the screens that
appear, such as the End User License Agreement, are the same ones that appeared the first time the
computer was turned on.
7 Click Next.
The System Restore screen appears and the computer restarts.
8 After the computer restarts, click OK.
9 You will need to run Windows Update as well as Live Update for your virus protection as these will be seriously out of date.
Hope this helps..
May 17, 2014 | Dell XPS M1330 Notebook
Reset bios
Installing a fresh operating system is a good option, and there might be a feature in the BIOS to restore the system to factory defaults. Information on how to do this:
Windows XP: Dell PC Restore
Using PC Restore:
1. Turn on the computer.
of the screen.
2. Immediately upon seeing the blue bar, press <Ctrl><F11>.
starting, and then restart the computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot.
3. Click Restore and click Confirm.
The restore process takes approximately 6 to 10 minutes to complete.
4. When prompted, click Finish to reboot the computer.
completely reboot.
5. When prompted, click Yes.
operating state, the screens that appear, such as the End User License
Agreement, are the same ones that appeared the first time the computer
was turned on.
6. Click Next.
7. After the computer restarts, click OK.
or
http://www.user-guides.co.uk/download/dell/delloptiplex/dell-optiplex-330-reset-bios-password.html
Aug 18, 2013 | Dell OptiPlex 330 Desktop Desktop Computer...
Laptop wont boot to windows, and flashing a blue error screen
Do a system restore/recovery to a date before this issue. Unplug, remove battery, leave battery out during this procedure, plug into AC, Start tapping the F key that will start the restore/recovery page. You didn't give OS or other info. Did you do updates? Add software/hardware? What preceded the issue?
Nov 29, 2012 | Computers & Internet
Time and date keeps reseting even though I changed CMOS battery, battery is ok, tried it on another PC
a. Click Start, type services.msc and hit ENTER.
b. Locate Windows Time.
c. Right-click and select Restart.
hope it helps
Apr 27, 2012 | HP Compaq dc7600 Small Form Factor PC...
Emachines t5274 vertical blue lines during startup/XP.
It looks like you've got two issues. If you tried a different monitor and it too have vertical blue lines your video card might be bad, but hold that thought. I'm thinking you need to reload the operating system because you can't boot all the way up which is the second issue.
Have you tried to boot up in Safe Mode and do a System Restore? Turn the computer off, then turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Select the Safe Mode option. When it boots, if it boots successfully things will look different in Safe Mode. The screen will be darker and icons bigger, but that's normal. If you get into the desktop successfully, click Start/Programs/Accessories/System Tools/System Restore. Select a restore point (date and time) that is before you started having problems. If the system tells you that you have no restore points, then you will have to either Reload the Operating System or do a System Recovery. By the way, System Restore does not lose your data, documents, music, pictures, videos, or programs unless the program was installed after the restore date. System Recovery LOSES EVERYTHING, it sets your system back to when you first purchased it.
Mar 26, 2012 | eMachines T5274 Desktop PC
I turn on my laptop and it beings to load. Once the loading windows screen appears, the logo doesnt show, only the loading box at the bottom. The nothing else happens and the computer stays this...
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
please restart the system and tap the F8 key on initial system logo.
in the advanced menu select the safe mode option.
login as an administrator
if you are able to login, perform a system restore
click start...in the search box type system restore
in the window that appears, restore computer to earlier date and time and click next
select a date may be a week or 2 back when system was running fine and click next
follow the onscreen steps
in case you are not able to logon then you need to perform a repair of windows.
Please let me know the operating system you are using xp,vista or windows 7 so that i can accordingly share the repair steps with you.
Nov 29, 2010 | Dell Inspiron 1525 Notebook
Blue screen
Please press f1 ,it will take u to bios ,reset that with f5.......
and also after that remove each and evry cable and then press power button for 1 min and then replug the cable
May 01, 2010 | Microsoft Windows XP Professional SP2
Gateway laptop mx3414-black screen cannot load windows
Try going into safe mode upon startup by hitting the F8 button. If it does then hit safe mode to get into your computer. Go to start>accessories>system tools>system restore. Follow the wizard to restore your computer to a date earlier than when you started having problems. Let me know if you have any problems or questions.
Mar 19, 2009 | Gateway MX3414 Notebook
The word ''Acers'' apperas on the screen and its not loading
if you can find the motherboard battery, remove it and leave it out for around 2 mins, this should reset the CMOS (date,time, settings etc) make sure the laptop battery is out and its not plugged into the mains, the other way is to flash the bios by downloading the latest bios version for you machine providing that it boots to windows, the only other option is to flash via floppy with AC power on!!! NOT RECOMENDED as if it goes wrong your pc will be permanantly dead
good luck
Nov 13, 2008 | Acer Aspire 5610-4648 Notebook
Toshiba Satellite A55-S326 Notebook Logo
44 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
