My washer is kinda old and it is starting to leak from the bottom. Is there a trans seal or something i can replace ?
  • 1 more comment
  • bobdodd Aug 25, 2010
    I lifted the machine and found out that the leak is coming from the top of the tub at the back panel. Took the panel off, The hose looks good but the unit it connects to looks kinda old. but not broken. Only noticed leak on the rinse. Trans stopped kinda hard . maybe spring for tub could have broken and tub got out of align with water chute. didnt look at that . Thanks....
  • bobdodd Aug 27, 2010
    Are you talking about a toilet ? I have a washing machine !
  • bobdodd Aug 29, 2010
    I found out that the tub is not holding itself centered. all the springs are still there on the bottom. Is there something else that holds the tub centered ?
    Genius:
  • 1,417 Answers
The problem of your washer does not need any part replacement the solution is just to give it a little service on the drum connected to the hose/water drainage
Clean tank ball and drain seat thoroughly. If leak persists, replace the worn tank ball or flapper with a Fluid-master Bull's Eye Flapper Model 500, Bull's Eye Super Flapper Model 501 or a Flusher Fixer Kit replacement seat for damaged brass, plastic or ceramic flush valve drain seats.
thank you and thanks for using fixya.
Posted on Aug 25, 2010
  • 10,319 Answers
Most likely the hose on the pump is leaking since that hose get the most use. I would replace the hose if this machine runs well. The top and the front panel would have to be removed to gain access to it.
Do i need a special tool to remove the transmission seal on a 2002 kia sportage?
Which Seal?
Have you gotten under & checked the driveaxle seals?
The big leak will be the torque converter pump seal
That requires removing the transxale
Sort of old to do that & not rebuild the trans while your at it
May 16, 2014 | 2001 Kia Sportage
Leak around the door seal
the seal might look ok but don't forget the seal could crack on the bottom, any time the washing machine stops and the water settle
there's more water at the bottom half so the bottom of the seal takes more abuse. so I would replace the sealer and if you can buy a little thicker one.
Feb 07, 2018 | Samsung WF218ANW 4.0 cu. ft. High...
I changed tranny filter and pan gasket, still leaks, possible inner seal? any suggestions?
need to identify where leak is coming from wipe clean bottom of transmission and check trans lines ,dipstick tube, rear seal ,pan for leak or drip start van and let run drive around block than park and recheck trans for leak if leak by where engine and trans meet than front seal anywhere else fix and or replace front seal two choices first can try a trans leak additive follow instructions carefully or need to pull trans to replace seal
Feb 01, 2010 | 1998 Dodge Caravan
After my daughter washed a quilt. The Washer leaks water out of the bottom. Is a seal loose? What is my best access to open the washer to see what the problem is. Thanks
The quilt had nothing to do with this problem. It is the water pump that is worn and has started to leak from old age. It needs to be replaced.
Oct 10, 2009 | Kenmore HE2 Plus Front Load Washer
My washer has had streaks of grease coming from under the agitator. It is getting on my clothes and I cannot remove it. I took the agitator off and the inside of it is coated with this grease (black,...
GE style washer Common problems: - greeseOil on the clothes or floor. In most cases a new transmission will be required. You can rebuild the Trans for oil on the floor, but I find it best just to replace the transmission with a rebuilt one = less problems and faster repair. I have a parts breakdown of the old style transmission here. How to access the washer information.
Change transmission in GE washer-Take transmission out for repairs. - Unplug washer. Remove agitator from washer by pulling straight up on it, some agitators have a bolt under the cap, remove cap and look for a bolt first. Remove the agitator bearing from transmission hub. Get top up by pressing on 2 clips located about 6 in in from side between top and cabinet. Putty knife or flat blade screwdriver works well here. Take the filter flow tube off. Lift top. Remove three bolts holding basket to hub, and use a 12 POINT 1/2" socket to remove the bolts. Lift basket out of washer. Remove the two clamps holding the black boot to the tub and to the transmission. There are six bolts holding the transmission in the washer. Remove the bolts and lift transmission out of the machine.
To replace bottom seal - Turn trans. upside down in a bucket, put in vice, etc. Remove the nut holding the drive pulley on. Take drive pulley off. You can now pry the oil seal out of the trans. bottom and replace. If you wish to put the proper amount of oil in the trans. you will need to remove the bottom cover. Unless you have lost a great deal of oil, I would bypass this. I would estimate the oil loss and put in a lesser amount through the opening where you will be putting the new seal. When replacing the pulley, do not turn the nut holding pulley on. Hold nut stationary and turn pulley in the direction that nut will tighten. This will keep you from separating the hub, torque spring, and drive collar in the transmission. If you see evidence of water in the transmission, my recommendation would be to purchase a rebuilt transmission and repair in that manner. You may wish to do this regardless of the condition of the trans. You will receive a one year warranty with the rebuilt trans. I have a parts breakdown here for the transmission if you need it.
Usually you have to only add a little oil to replace what was lost...not much...really!!
The oil used is a Non-detergent, Gear oil approximately 90 weight. The main pulley seal is WH8X281 and foam nut seal is part # WH2X671.
Jul 13, 2009 | GE WPRB8050D Top Load Washer
Washer leaking from bottom of tub
If you have the tub out the seal can be removed by taking the brass ring off the shaft, its on top of the seal, then grab the seal with a pliers or pry it out with a screwdriver etc. The new seal will cost about $40-$50. when you put the new seal in put the rubber part on first, careful to not tear it on the slot cut in the shaft to mount the basket. Next put the old brass ring on top of the new one, use this to push the new ring on, this will help get it over the notch for mounting the basket. When the new ring is ontop of the seal remove the old ring, reassemble, check for leaks.
Jun 08, 2008 | Frigidaire FWS833A Top Load Washer
Kemore 70 series
Its possible that your trans. is going to need replaced. Maybe have some bad seals on the trans. As far as the water leak goes. Could be a tub seal, maybe some worn inlet hoses, maybe a leaky inlet valve.
We hope this gives you a start on your appliance repair. Anymore questions please feel free to reply back.
Mar 26, 2008 | Kenmore 22422 Top Load Washer
Leaking Kenmore dishwasher
if you are very careful you can reseal it with a soldering iron as it should be a sealed cabinet. i have seen one seald with a cheap sealr and the cabinet turned orange.
Feb 12, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Washing Machines Logo
Top Washing Machines Experts
