Sony television screen sometimes turns reeddish.
    President:
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try plugging in the TV through the USB on its panel to a computer or USB charger, and it may work. However, this is only a temporary solution.
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
5. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic (not same model):
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
6. The convergence IC's are kaput and you will have to get them replaced.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
THE SCREEN IS BRIGHT PINK
Could be in the set but if using a cable or sat box unplug them and wait a while and plug back---I have seen a reboot of a box cure this issue.
Jun 03, 2012 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Green edge around images (outline)
my 2002 sony wide screen projection tv has menu and pictures when turned on first thing in the morning?
Jan 30, 2010 | Mitsubishi WS-55905 55" Rear Projection...
Sony kp51hw40 projection tv screen turns blue
The blue CRT needs replacement. You can get a replacement CRT at the following link.
http://servicemanuals.vstore.ca/
Feb 02, 2009 | Sony KP-51HW40 51" Rear Projection...
Blue screen
The tech form Sony is right. The blue CRT has an intermittent short and if the TV is more than a few years old, replacing all three tubes may be necessary. The cost is prohibitive. I see a LCD flat panel in your future.
michtech
SONY REAR PROJECTOR TV
5 blinks means AKB detected. Try turning down all 3 screen adjustments slightly.
May 27, 2008 | Sony KP-53XBR200 53" Rear Projection...
Tv wont turn on -- stand by light just keeps blinking
This is very common problem for sony. Blinking light is power supply problem need to replace two voltage reulators in supply and caps and sometime horz output.
Sometimes if you adjust screen voltage adustment on flyback just slightly it will fix it.
cost if ps is 225.00
screen is 95.00
Thanks doctor video
May 17, 2008 | Sony KV-35S45 35" TV
Red, Red, Red
Remove front speaker grill and access panel......
Turn red screen control down a little...
Cause may be bad CRT.......................................T.
Nov 07, 2007 | Sony KP-51WS510 51" Rear Projection...
Sony rear projection tv
Bad green crt, this set has a problem with bad crt's
Oct 13, 2007 | Sony KP-57WS500 57" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
