How do i connect a behringer 3000 mixer to a pair of bose 802 II speakers, without the bose eq instead using a behringer eq.
SOURCE: bose speakers 800
I' ve just sold 2 pairs of 800's. The buyer(who once owned a music business) used an 802 controller to test them. He said that any bose eq would do the job with no problems.
Posted on Jan 29, 2008
SOURCE: Connect Bose 901 VI EQ to a Harmon Kardon AVR 247 Amp
Similar problem...I came up with a solution with help from Onyko. For my receiver, at least, the bottom line was that the output from the equalizer MUST go to 'Receiver, Tape In'! Since that is the ONLY input source from the equalizer, you must combine elsewhere. Part of my setup included the Radio Shack Audio/Video Selector box which costs $21.99...you might not need it, but in my case, I couldn't plug all components into the back of the receiver and have them go through the equalizer.
Since I have a satellite receiver, DVD player and TV, that I want to route through the equalizer, here is the way mine is set up and working:
Satellite receiver and DVD player out to Radio Shack audio/video selector
Audio/video selector out to VCR in.
VCR video directly to TV
VCR audio red/white (audio) out to equalizer
Equalizer out to Receiver Tape IN (Receiver Out not used)
Hope this (or a variation of it) helps.
Posted on Dec 21, 2008
dunnbiker
  • 8546 Answers
SOURCE: onkyo tx sr 705 & bose 901
No. Active Equalization is required for the 901's and not to be used with any non-901 speakers.
Posted on Apr 13, 2009
dunnbiker
  • 8546 Answers
SOURCE: Bose 901 Active EQ Loop
There's good news and bad news. The bad news is that a multichannel receiver with Bose 901's will only sound right in STEREO on stereo analog material. For one thing, the other speakers around the room are not designed to recieve its Active Equalization and for another, if you engage your Tape Monitor you will not be able to play digital sources. Tape Monitor is for analog stereo material only and on my receiver it disables any digital inputs.
The good news. I have a setup similar to what I think you're trying to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers. You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W).
Run the dbx and BSR in tandem with each through the tape monitor loop on the receiver but be advised you can only use them on analog source stero material. However, you can still employ the various DSP options to spread the sound around the room.
At my PC workstation across the room I have a stack of analog processors and sources including dbx 3bx-ds, dbx 120x-ds, BSR Spatial Enhancer, BBE 462 Sonic Maximizer, SS-525x EQ, Carver C-9, dbx-224x, JVC cassette deck, Dual 1249 Turntable running through a Garrard MRM-101 Preamp, Pioneer PDR-509 CD Recorder and the Media Center PC stereo analog channels all running through a dbx 400x Program Route Selector (a godsend) which is attached to my ONE TAPE MONITOR on my Pioneer VSX-36TX Receiver. Of course, I have some of my analog processors running in tandem, too, since the 224x only has three processor and three tape loops.
For listening/recording anything 2-channel analog I engage the stack through the Tape Monitor. For everything else I turn the Tape Monitor off. The nice thing about the stack being separate is that I can doodle with recording and use headphones while the TV/DVD/Blu-Ray do something else.
Posted on Apr 24, 2009
dunnbiker
  • 8546 Answers
SOURCE: bose 901 series 2 speakers
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great!
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Write off the Tape Out as an input if you use it to extract the Front L&R channels. DO NOT monitor it or you'll chop the 901's out of the signal path AND kill any digital source audio in the receiver.
Posted on Apr 25, 2009
My behringer xenyx 802 premium 8-input mixer worked fine for 1 day but now it sounds watery and behringer support was no help at all
Sounds like it may have failed. Yes, it is likely that it needs to be returned. Another option is to unplug all inputs and outputs. Plug in ONE device into the board, and use the headphone jack on the board. Does it sound the same? Just basic troubleshooting may help.
Oct 02, 2012 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
Bose 901 eq connect to mixer and amp
how to connect bose 901 speakers to mixer. help me
Mar 29, 2012 | Bose 901 VI Main / Stereo Speaker
Hi all i own a behringer XENYX 802 audio mixer. this device is powered by a power supply that as input to the mixer gives 18,5 x2 Ac, 150ma. i would like to know in which point of the circuit i can...
You would need TWO DC supplies as they use AC so they can create both a plus and minus 15 volt power source to run the internal op amps.
Here is a schematic for the 1202 which has same power supply configuration as the 802.
http://elektrotanya.com/behringer_xenyx_1202.pdf/download.html
Scroll down to the little link "Get Manual" and download the service manual and schematic. You will find the power input in the upper left corner of page 5.
Mar 29, 2011 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
Is there a reset button on my 802?
I do not remember if the powersupply is external or not either way there is no reset button the powersupply may not be putting out any voltage.
Dec 01, 2010 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
I want to connect two passive b212 and 6 active b215 , i will use two active b215 for monitors ..... i am using a PMP 3000 Please advice,also where can i get a detailed numbered illustrations sheet for...
The passive speakers connect to the main outputs using Speakon connectors on the back.
You will use Balanced connections (TRS) to the main L and R connections on top to the active speakers. Daisy chain 3 active on each of the L and R top connectors.
You can download a user manual if you don't have one.
http://www.behringer.com/EN/downloads/pdf/PMP1000_P0566_M_EN.pdf
ALSO PLEASE read my tip regarding a hazard when using Speakon to 1/4 inch speaker cables on channel "A" in the FIXYA tips for PMP mixers. The barrel of the channel A 1/4 inch is the HOT side of the signal to the speaker instead of the tip.
Nov 24, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
How do I connect a Bose 802 speaker controller to my Spirit 600 powerstation
If you look in the manual at the "hookups" page 1, connect the controller as if it was an EQ. This will insert the controller between the mixer and the amplifier.
Dan
Aug 29, 2010 | Audio Players & Recorders
I want to hook my bose 901 VI along with EQ to my Luxman R117 Receiver and also run other speakers from the same receiver. Is this possible?
If you are using the Bose Equalizer to optimize the sound of the 901s by going through either a tape loop or a pre-out/main-in loop, then the only way to do this without also equalizing the sound sent to the second set of speakers is to manufacture a "zone-2" output from the Luxman.
You'd probably need to split the send from the Luxman's pre-out before the EQ and send it to a second power amplifier for the second pair of speakers (if you want the Luxman's volume knob to control both speaker sets) or from a tape level output (if you wanted independent volume controls for the two speaker sets.
The whole EQ thing made 901s difficult to use on vintage equipment with only one "zone" audio outputs. Unless you want to use the Bose EQ on the second set, too, you can't do it satisfactorily without adding another stereo amplifier. But, go ahead and try it, you might find that you actually like the odd EQ that the 901s EQ gives to the second pair!
If it were my decision, I probably would not do it without a second amp, but it's all about what you like, my opinions really don't matter in your house, do they?
Have fun
Jul 24, 2010 | Bose 901 VI Main / Stereo Speaker
Hi. I would like to connect a Bose controller between a pair of Bose 802 speakers and a Studiomaster Powerhouse 300 MIXER/AMP. The diagram on the top of the controller shows the amplifier connected just...
Tech data sheet with diagrams:
http://www.bose.com/pdf/professional/802III_techdata.pdf
In a nutshell, the controller would go between any preamp Stereo OUTput and a dedicated amplifier INPUT. You really don't have much choice in the matter. The 802's and their controller are part of an inseperable system.
The Bose 802/901 family uses full-range speakers instead of traditional woofer/tweeter combinations, so they compensate for the response limitations at the extreme frequencies by using severe electronic modification of the program material. Hence, they are a system, functionally inseparable, but the results are outstanding. Consequently, they need a dedicated amplifier so they alone get the processing provided by their electronic component.
I don't have any data on your mixer/amp but if you can't insert the conroller logically between the mixer and its amps then you'll have to get separate dedicated amplification for the 802's, with the controller between the mixer and that amp.
May 17, 2009 | Bose Audio Players & Recorders
Bose 802 C series II to Yamaha rxv 459 Amp
In a nutshell, the controller would go between a preamp Stereo OUTput and a dedicated amplifier INPUT. You can't use Bose 901 or 802 EQ in a multichannel setup without separate amps for the Bose speakers.
In a vanilla stereo configuration you would just put the controller/EQ into a Tape Monitor loop but multichannel sound and digital sources won't work that way.
You should be able to draw off the (assumed) Front L&R channel preamp signal from the MD/CD-R or DVD-R Audio Out (REC) jacks (*). Run that to the Preamp In (or whatever it's labeled on the Bose EQ/Controller). DO NOT run a return RCA pair back to the Receiver as Bose-processed signals will not play well with non-Bose speakers. (*) Run the Output of the Bose EQ/Controller to a powerful separate amp for the Bose 802/901's. I use two channels on a Carver multichannel AV-406 amp but a stand-alone Carver MT-200T also works well. A good clean 100 watts/channel should suffice at home.
* If possible, choose the recorder loop you are NOT using for something else. If you're using the MD/CD-R or DVD-R Audio OUT for a recording device just get some RCA splitters to share the Stereo signal between the Bose and the device at the same time. However, once you select monitoring of that recorder two things will likely happen - 1) you'll lose the Bose and anything digital in the receiver will be disabled.
It's the nature of the digital beast that analog monitoring gets in the way of DSP.
Of course, if anyone who reads this has a receiver with individual analog Audio Outputs for the various 5.1 channels (as I do), the solution would be to draw off the Front L&R channels to the Bose EQ and downstream amplifier and the rest would be the same but without Recorder Loop limitations.
Apr 28, 2009 | Bose 901 VI Main / Stereo Speaker
Bose speakers 800
Jan 01, 2008 | Yamaha Emx88s Powered PA Mixer System
27 people viewed this question
 Grubhead
Grubhead
