That sounds like the inlet valve has failed in the closed position. If you see some water coming into the washer initially, then one of two inlet valves is not working. Depending on the washer, you may have to replace the entire inlet valve assembly.
Most washers have a pressure switch or flow sensor that detects if the expected amount of water has reached the tub. If the flow isn't there, then the washer will stop. (If water goes into the washer and then gets pumped out, check the position of the drain hose. The end has to be above the highest water level in the washer.)
If you add a comment with the model number, I may be able to find the parts list for your washer. I hope this helps.
It is possible that you have a bad water valve. Turn off the water when the machine not in use if the problem stops the water is probably coming in through a defective valve.
You must get the filter out, as there is a very good chance that this is the prob, keep unscrewing it and try to move it about, then screw it back in again , and then out again, hopefully this will dislodge whatever it is that is holding the filtter in.
Plz rate thiese comments.
Thanks.
