Question about Panasonic Home Theater System System
Display says is locked - Panasonic Home Theater System System
    Habit-Forming:
  • 39 Answers
Your parents locked you out. They put a code on the tv, so you wouldn't watch it when you don't have permission. If you are the parent, and it was done by a child... simply unplug the television for several days to give it a chance to reset. If that doesn't' work, you'll need to open the tv set to pull out the internal battery (soldering required).
Posted on Sep 05, 2010
Key on display wont start
Your washer is in the "child lock" mode, hence it won't allow any program. Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. If nothing is pressed within 10 seconds.following this the menu will close and it will default to program in the display. Once you see that in the display, press the "select" button until "CHILD LOCK :OFF" appears in the display. Finally by pressing the start/pause button the key symbol should disappear - confirming you have successfully exited the child lock program.
Pl click if helped.
Apr 11, 2013 | Bosch Washing Machines
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
Sep 18, 2011 | Uniden BC248CLT Base Scanner
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    I have accidentally locked my microwave oven (profile performance convection oven). I was cleaning the front. Can you tell me what to do?
    Got you covered. Here you go:
    Microwave - Explanation of the Child Lock Out Feature
    Many microwave control panels can be locked to prevent accidental use or access by children.
    There are two different ways to lock the control panel:
    1. Press and hold the CLEAR/OFF pad for 3 seconds. The display will show "LOCK" and then revert to the time of day.
    A small "L" will appear in the corner of the display as a reminder that the control panel is locked. If anyone tries to use the microwave, the display will show "LOCK".
    2. On some models, press and hold the 5 and 7 pads simultaneously for 3 seconds.
    To unlock the control: Repeat the procedure which was used to lock the control. (Press and hold the CLEAR/OFF pad for about 3 seconds or hold the 5 and 7 pad simultaneously for 3 seconds.)
    That info is from GE
    Hope that does the trick.
    Regards, Farmerbear at FixYa.com
    Sep 13, 2010 | General Electric Microwave Oven
    How do I unlock the key pad? The display shows locked and I don't know how it locked.
    Here you go.
    The Child Lock shuts down the control panel pads to prevent
    unintended use of the microwave oven.
    When the control is locked, only the Vent Fan and Light pads will
    function.
    To Lock/Unlock Control: The microwave oven and Timer must
    be off. Touch and hold START for 5 seconds until 2 tones sound
    and a lock icon appears on the display. Repeat to unlock and
    remove the lock icon from display.
    May 10, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
    I was given a mitsubishi tv but the previous owner had a password lock on it. Is there any way to access the tv by rebooting or something in order to use the tv?
    1. Press the Mode button until the LOCK CODE display appears.
    2. Enter the 4-digit code using the CHANNEL SELECTOR buttons.
    3. Press the CANCEL button to cancel the previously locked channel. The LOCK CODE number display flashes.
    4. To exit the CHANNEL LOCK mode, press the MODE button until only the Time and Channel display appear.
    Secret text if the code is forgotten!
    2. Press Channel Number "9" and "QV" simultaneously. Knowledge of this procedure defeats the channel lock system.
    Nov 12, 2009 | Televison & Video
    I can't unlock touchscreen panel
    This is an safety features that prevents unwanted oven operation by children.
    To set child lock...
    Touch and hold STOP/CLEAR or 0,START until LOCKED appears in the display and two beeps are heard. If the time of day was already set, the time of day will return to the display windows. After you touch another.
    If the CHILD LOCK was already set and you touched another cooking pad, the word LOCKED shows in the display.
    Then you can cancel the CHILD LOCK according the below procedure...
    Touch and hold STOP/CLEAR or 0,START pad until LOCKED disappears in the display.
    Aftes the CHILD LOCK is turned off, the time of day will return to the display window. The oven will operate normally.
    Hope helped with this. Good luck.
    Nov 04, 2009 | GE Ovens
    Sony DAV DZ230 Child Lock
    hello You can deactivate the buttons on the unit
    (except for "/1) for preventing misoperation,
    such as child mischief (child lock function).
    When the child lock function is activated, the
    buttons on the unit are locked and “ ” lights
    up in the front panel display. (You can operate
    the system by using the remote.)
    Note
    •When you operate the buttons on the unit while the
    child lock function is on, “CHILD LOCK” appears in
    1 Press SYSTEM MENU.
    2 Press
    X/x repeatedly until “CHILD
    LOCK” appears in the front panel
    display, then press or
    c.
    3 Press
    X/x to select a setting.
    The default setting is underlined.
    • “OFF”: Child lock function off.
    • “ON”: Child lock function on.
    4 Press .
    The setting is made.
    5 Press SYSTEM MENU.
    The system menu turns off.
    Tip
    • You can activate the child lock function by pressing
    x for more than 5 seconds (“ ” lights up in the
    front panel display).
    To cancel, press x for more than 5 seconds so that
    “ ” disappears from the front panel display.
    Deactivating the Buttons
    on the Unit good luck
    shaun
    Sep 12, 2009 | Audio Players & Recorders
    My oven is in lock mode after i had cleaned it. I can't open it now and the lock light is on.
    Control panel and oven door lock
    The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked.
    To lock the control panel and both oven doors:
    1. Press and release Cancel.
    2. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
    To unlock the control panel and both oven doors:
    1. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
    Dec 22, 2008 | Jenn-Air Electric Double Oven
    Daewoo DV6T811N DVD Locked
    Your Child Lock has been turned on.
    Press the power button of the remote for about 8
    seconds. No buttons of front panel and remote can be
    operated now and Lock indicator (“LOCK”) will be
    displayed on window display.
    To release child lock,
    press the power button of the remote control for
    about 8 seconds.
    Good Luck.
    Apr 08, 2008 | Televison & Video
    Panasonic Home Theater System System Logo
    176 people viewed this question
    Top Panasonic Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Michael Kovalik III
    Michael Kovalik III
    Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
