Question about Poulan Pro 22" Self Propelled High Wheel Mower
Looking for 22" blade for a Poulan - PO550N22SH - PN 961120080 - where can I buy a lawnmower blade? Can find the number on the internet, but can't find a dealer that sells this product.
  • 183 Answers
Your Poulan Pro mower is made by American Yard Products and the parts will interchange directly with Craftsman 22" mowers. You should be able to find a replacement at your local Sears store. All of these part #s are also 22" AYP blades:
AYP #'s
406713
192682
157101
335256
114886
141114
Rotary #15-6236
Oregon #
95-043
95-042
95-055
95-023
95-021
95-602
The different #'s should all fit. Some of them are bagging style blades (high lift) while others are designed to mulch.
Online sources will include www.searspartsdirect.com and www.amazon.com
Good Luck!
Posted on Aug 25, 2010
How to install cable
Well I am not sure if your lawnmower is similar to mine - when I want to engage the blades, I push the lever up and lock it in place.
I just replaced my cable - took about an hour. On the other side of ther lever there is a cable attached that goes to the cam to engage the blades.
You will need to look and see how it is secured at the lever and at the cam down where the blades are.
Mine was pretty easy to remove - there was a tab that locked the cable to the lever frame where the lever is located. At the cam to engage the blades there was a pin that needed to be pulled out to release the cable.
That was pretty much it. Look on the internet for a parts diagram of your particular lawnmower. You will need to include the mfg, and model -
The parts diagram should show you where it's connected. Make sure you have the new part in hand before you start to work on it.
If you don't, you may have to wait a day or two to get the part from a local supplier - if you're lucky they may have the part in stock.
Another reason to get the parts diagram is the part numbers are listed for all parts - when you call for a part use the part number for the item you want to purchae.
Hope this info helps.
Jul 27, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Mower runs rough when blade is on
one or both blades are out of balance replace blades could have hit a rock or bottomed out on ground
Jun 19, 2014 | Poulan PO14542LT 14.5 HP 42 in. Lawnmower
Serial # 021309M 018532\r\nP0550N22SM 961120080 80 The outter housing that holds the engine down is broken, need 22 inch blade and a shaft. Where can I get these to purchase? Also need the housing.
If your looking to purchase new parts , you my find this to be a very expensive purchase. You can go to your local dealer and get an idea of price for the parts you need or you may go another route. My suggestion would be to go to your local automotive junk yard and look around there. People throw away everything. You will probably find exactly what you want and for just a few dollars. Give it a shot , you have nothing to lose. GOOD LUCK.
Jun 27, 2011 | Poulan "Poulan" Push Mower
SPARK PLUG FOR POULAN LAWNMOWER #600Y22SHP AND WHAT KIND OF OIL TO BUY. wANT TO DO MAINTIANCE.
Take the old plug out and it will have numbers on the side. Simply match them up and you can cross-reference them on the package of any other plug that looks like it fits. But I'm guessing that mower has a Brigg's and Stratton engine and the plug will probably be a RJ19LM (Champion Number), which is what 99 percent of the engines I work on take (gapped at .030). Also, most mowers today run on straight 30 weight oil (not a multi-viscosity such as 10W30, Just 30 weight). Hope this helps you and good luck. P.S. Your owner's manual will tell you what you need to know and the engine sticker will tell you the oil.
Jun 27, 2011 | Poulan Pro 22" Self Propelled High Wheel...
Put Lawnmower on its side and changed blade. Put
Most likely you have flooded the cylinder with oil. You can try this and see if it helps you out.
Remove the spark plug, clean and dry it with carb cleaner, let dry, spray carb cleaner in the spark plug hole and thoroughly flush it out. Let is sit this way for about 20 minutes. Reinstall your spark plug and see if it will start up for you. If it does you are done if not go to an auto parts store and buy some starter fluid. Spray the fluid with just short burst into the air cleaner. Try to start it. Repeat and it should stay running in a couple of tries.
Jun 15, 2010 | Poulan "Poulan" Push Mower
I hit a rock with my push lawnmower. The
Oooh boy, I know you bent the shaft, but why it is blowing oil out the carb, I don't know if I would even bother with the blade, you could go buy the same mower, then you would have some parts. Unless you just bumped it hard enough to throw oil around in there, it might settle down, but it is a long shot. I hit a stump once and bent the crank, it was lights out for that mower. Hope this helps.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
I need a muffler for it where could I find one?
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Type 2 follows:
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
Item 40 pn 530054886 $23.18
Item numbers are different for Type 1 but pn's and price are ther same.
HTH
Lou
An Internet search returned many hits, some a few $ more a couple a little less. Do not forget shipping and handling feees. GL
Dec 26, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Hydristatic slips
Try running it to warm up the fluid, drain the old stuff out and replace with a quality hydrostat fluid recomended by the mfg. Also change the filter if so equiped. you should be able to get ahold of the mfg. online or start here http://www.poulan.com/poulanpro/indexAction.do?id=default
Nov 11, 2008 | Poulan Pro 22" Self Propelled High Wheel...
Poulan Pro 22" Self Propelled High Wheel Mower Logo
352 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
